    Dual motor axis end stop woes
    CNC
    750
    • tierodundefined
      tierod
      Hi everyone, I’m using a duet2 Ethernet with version 3.4.4. I have a dual motor axis with an end stop for each motor and It works as normal. Each motor stops as each end stop is hit, all good and have been using it for awhile now. I use normally closed switch arrangement as I thought if wiring fails it wouldn’t home, wrong! I had a stuck micro switch on one side(open circuit) poor quality? Anyway I hit home only one side of the gantry started moving, luckily I was able to hit the e stop before it did any damage. I don’t have access to my config right now but it’s the standard m574 x1 s1 P”x stop+e0stop” that I’ve been using for awhile. I also just use x,y,z without the u axis in my homing files but I thought that was how it’s done. What am I missing?
      Rod
      tierodundefined droftartsundefined jay_s_ukundefined 3 Replies Last reply Reply Quote 0
      • tierodundefined
        tierod @tierod
        Forgot to add I use m584 x5:6 u6 y7 z8 for mapping
          droftarts administrators @tierod
          @tierod please post your full config.g and the homing macro you were running. Please also send M115 in the console and post the response.
            @tierod Reading your issue again (and not on my phone) I understand what happened. With the stuck endstop, the machine thought that side was homed, and continued to home the other side. Lucky you caught it! Currently, there is no mechanism to stop the other side automatically, but @jay_s_uk has suggested that we make this configurable, e.g. limit the movement of the second side to 5mm. I've asked @dc42 for his thoughts.
            I think your setup is fine. I don't think there's any advantage using Normally Open rather than Normally Closed switches; I would guess the failure mode is still possible.
            There may be a way of checking both switches repeatedly, with a short homing move between, but I expect it would require splitting the Y axis into two separate axes, and homing them together in short movements.
              jay_s_uk @tierod
              @tierod i've talked about this a little more with @droftarts and we think we have a solution.
              here is an example check I do on one of my printers in the homing file before any other movement
              if sensors.endstops[0].triggered = true     ; if we're hard against the endstop we need to move away
              	M564 H0 S0
              	G1 X-20 F1200
              	M564 H1 S1
              	M400
              		abort "X Endstop appears to be faulty.  Still in triggered state."
              this checks the endstop status on a single axis and if its triggered, moves the axis away and checks the status again, eventually ending up in an abort if its still showing triggered.
              you'll just need to modify it to include an "or" for the second endstop (you can get the right sensor number from the object model browser plugin) and to reduce the movement before the second endstop check
              tierodundefined 1 Reply Last reply Reply Quote 3
              • tierodundefined
                tierod @jay_s_uk
                @jay_s_uk
                That’s awesome! Thank you guys very much. I’ll implement that and see how it works but may take me a while, never used object model before. I’ll let you know how it goes.
                Again, thank you very much for your help!😀
                Rod.
                tierodundefined 1 Reply Last reply Reply Quote 1
                • tierodundefined
                  tierod @tierod
                  @tierod
                  hi again, i havent been able to get to my cnc yet but does the homeall have to look something like this?
                  ; homeall.g
                  ; called to home all axes
                  G91 ; relative positioning
                  if sensors.endstops[0].triggered = true ;if were hard against endstop or wiring faulty
                  or sensors.endstops[1].triggered = true ;as above
                  m564 h0 s0
                  g1 x-2 f1200
                  m564 h1 s1
                  m400
                  abort "x endstop appears to be faulty. still in triggered state"
                  or sensors.endstops[1].triggered = true abort "u endstop appears to be faulty. still in triggered state"
                  G1 H1 X-700 Y-400 F12000 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X5 Y5 F6000 ; go back a few mm
                  G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G1 H1 Z155 F360 ; move Z up stopping at the endstop
                  G90 ; absolute positioning
                  g92 x0 y0
                  g1 x5 y5
                  g92 x0 y0
                  im clueless when it comes to anything about meta commands etc. i can sort of get around simple gcode
                  thanks😕
                    jay_s_uk @tierod
                    @tierod no, that wouldn't be correct.
                    firstly, you need to maintain the indentation, otherwise the code won't work
                    for the or part we can probably simplify it slightly
                    if sensors.endstops[0].triggered || sensors.endstops[1].triggered
                        M564 H0 S0
                        G1 X-2 F1200
                        M564 H1 S1
                        M400
                    tierodundefined 1 Reply Last reply Reply Quote 0
                    • tierodundefined
                      tierod @jay_s_uk
                      @jay_s_uk
                      Right, that makes perfect sense (says the guy who hasn’t got a clue)😁
                      Once again, thank you very much!
                      The dual motor axis end stops configuration has always worried me because of the potential for disaster, (ask me how I know ) so this issue caught me off guard. I’ll implement it, test it and let you know how it goes. Cheers!
                      Rod
                      • tierodundefined
                        tierod @tierod
                        @tierod
                        it works! so awesome!
                        had to make a few changes, after trying this and that this is what i ended up with. dont know if it can be improved on but a couple things to note: will not work if you have the previous homing file stopping with the endstops triggered and it gives the warning :not sufficient axis homed" even when it works, not sure why? i would prefer have the original message you wrote. no idea how to fix that. could you give me your thoughts on the file? by the way, line 2 to 7 is indented, not sure why it comes up not
                        ; homeall.g
                        if sensors.endstops[0].triggered || sensors.endstops[1].triggered = true
                        ^abort "X Endstop appears to be faulty. still in triggered state"
                        ^m564 h1 s1
                        ^g1 x-5 f1200
                        ^m564 h0 s0
                        ^m400
                        ^if sensors.endstops[0].triggered || sensors.endstops[1].triggered = true
                        G1 H1 Z95 F3000 ; lift Z relative to current position
                        g1 h2 z-5 f300 ; move away from endstop
                        g1 h1 z10 f300 ;move Z up stopping at the endstop
                        g1 h2 z-5
                        G1 H1 X-1190 Y-1190 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 H2 X10 Y10 f300 ; go back a few mm
                        G1 H1 X-15 Y-12 F360 ; move slowly to X and Y axis endstops once more (second pass)
                        g1 h2 x10 y10
                        G92 x0y0z0 ; set xyz position to axis minimum
                        thanks!
                        Rod
                        o_lampeundefined 1 Reply Last reply Reply Quote 1
                        • o_lampeundefined
                          o_lampe @tierod
                          @tierod said in Dual motor axis end stop woes:
                          if sensors.endstops[0].triggered || sensors.endstops[1].triggered = false
                          You should check for "true" state in both cases.
                          Put your code in </> brackets to show the indention. The </> symbol is on top of the editor window
                          • tierodundefined
                            tierod @o_lampe
                            @o_lampe
                            Thanks for that.
                            Edited the last post, is correct and works giving the proper warning now, just had to move the warning behind the first if statement. Sorry about the weird indentation! Oh and I also looked at the object model for the first time ☺️. What a great tool! I double checked the operation and it works with both left and right micro switches. I am so, so happy with this feature and I really think that all the people that help on this forum are number one in my books!! I believe this code should be made known somewhere easy to find, I can’t be the only one that has run into this issue. Again, thank you guys for your help!! Problem solved!
                            Rod
                            droftartsundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                              @tierod great, glad it works for you. I’ll add it to the endstop page of the wiki.
                              • o_lampeundefined
                                o_lampe @tierod
                                @tierod I must apologize for my "true/false" mistake:
                                You are using normally closed endstops and have to check both if statements for false
                                Then you can move the error warning behind the second if-line.
                                • tierodundefined
                                  tierod @o_lampe
                                  @o_lampe
                                  No problem, I’ll do that, thanks!
                                  Rod
                                  • tierodundefined
                                    tierod @tierod
                                    @tierod
                                    hi all, just an update on this script
                                    after changing the if statements to false, with the warning at the end it still gave me the red warning endstops not homed. so i moved it back behind the first if statement and it then gave me the correct blue error message.
                                    it works perfectly this way so unless this is a bad move i’m going to leave it this way.
                                    to reiterate, do NOT have your homing stop on the endstops as it will refuse to move, even 5mm off the endstops and all good.
                                    again, thank you guys for this script!
