    sd card almost full .. new printer set up
    368
    • Richard Fundefined
      Richard F
      I'm using the sd card that came with the mini 5 + wifi
      all I've done is update firmware, and added config file. i looked at the card and in boot volume there's about 200mb free
      the other Partitions are empty
      its a new board and first setup
      any help i would be grateful 🙂
      Richard Fundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        Richard F @Richard F
        @Richard-F Screenshot 2024-03-05 213051.png Screenshot 2024-03-05 212723.png Screenshot 2024-03-05 212813.png Screenshot 2024-03-05 212853.png Screenshot 2024-03-05 213013.png
          droftarts administrators @Richard F
          @Richard-F SD cards are supplied (at least at the moment) with a FAT32 partition, and a partition for a Single Board Computer (SBC, or Raspberry Pi) installation. If you're using your Duet in standalone, you can delete the SBC partition, or backup the configuration and erase/reformat the SD card. For guidance, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
          You can send M39 to report the current state of the SD card.
            @Richard-F Screenshot 2024-03-05 213955.png Screenshot 2024-03-05 213915.png
              @Richard-F The FAT32 partition is also used to boot the SBC/Raspberry Pi partition, so you only need to back up the /filaments, /firmware, /gcodes, /macros, /menu, /sys, and /www folders. Erase the SD card, then restore those folders to the SD card.
              Richard Fundefined 1 Reply Last reply Reply Quote 0
                Richard F @droftarts
                  This post is deleted!
                    ive no idea if its safe to delete the bin files
                    im just setting up a 3 axis
                    no add-ons no sbc , just 3 steppers
                      Richard F
                        sys dir
                          is it safe to delete these files .. thanks
                            @Richard-F
                            ok im doing a override format and try and figure it out myself 🙂
                            jens55undefined 1 Reply Last reply Reply Quote 0
                            • jens55undefined
                              jens55 @Richard F
                              @Richard-F
                              NOOOO!
                                Richard F @jens55
                                @jens55 lol woops then
                                Richard Fundefined jens55undefined 2 Replies Last reply Reply Quote 0
                                  droftartsundefined Richard Fundefined 2 Replies Last reply Reply Quote 0
                                    @Richard-F It's fine to use the Quick format option with the SD Card Formatter.
                                      ok i re-formatted copied files back on .. eveything seem ok no error msgs
                                      • jens55undefined
                                        jens55 @Richard F
                                        @Richard-F
                                        If you deleted any .bin files that have 'mini5plus' in the title then you need to replace them from the release files.
                                        What was suggested was to back up all the files, reformat the SD card, set up a single partition (boot) and restore all the files. This will give you another 6 gig of usable drive space.
                                        If it was me, I would leave the original card alone, squirrel it away for a rainy day, get a 32 GB card and format it as a single partion. Re-install all the files and Bob is your uncle ....
                                        Richard Fundefined jens55undefined 3 Replies Last reply Reply Quote 1
                                          Richard F @jens55
                                          • jens55undefined
                                            jens55 @jens55
                                            Ahhh I see you are back in business - excellent!
                                            Keep in mind that all the print files you send to the printer are stored on the card so look at the old 'jobs' files and do some house cleaning on occasion.
