    12V Laser Connection with 5v pwm - 3 pin laser
    My Duet controlled machine
    • adhanabalundefined
      adhanabal
      I have 5W diode laser which has 3 pins , 12v Power, Pwm pin and GND pin, how to connect to duet 3 6hc board?
      Is it correct?,
      adhanabalundefined 1 Reply Last reply Reply Quote 0
        adhanabal @adhanabal
        @dc42 can you please answer thisa
          dc42 administrators @adhanabal
          @adhanabal the PWM and ground connections are as you have shown them but you will need to leave the 5V pin on the Duet not connected. Connect the laser 12V and ground pins to a 12V power supply.
            adhanabal @dc42
            @dc42 if I connect with 12v and ground I'm getting under voltage ⚡ warning. Should I use separate 12v power supply?
            • o_lampeundefined
              o_lampe @adhanabal
              People with such a short attention span shouldn't play with lasers... just my 2 cent
