Z-Probe?
I probe with the euclid the last tiem with this settings:
set global.probe_settingsH=0.5 set global.probe_settingsA=30 M558 P8 H{global.probe_settingsH} A{global.probe_settingsA} S0.003 F700:120 C"^121.io2.in" T8000 B0 R0
I have the feeling that it is getting worth over the print times. It seems to me that the thermal expansion of the toolhead and the micro switch etc come into play here. Not sure if there is any way to tackle that. But it is a nightmare to be honest. I print a lot of small parts with one of my printer so I run into that problem over and over again.
Cheers, Chriss
@Chriss how much variation are you seeing and what Temperature is your chamber
Hard to tell, but I would say that I need to babystep down up to 0.06mm. It is so bad that the button layer has real gabs. The chamber is up to 50-55°C.
Cheers, Chriss
@Chriss 0.06 would be normal for most printers I've worked with you can either do your homing when the printer temperature has become stable this could be 15 to 30 minutes depending on the printer all just make your first layer thicker to compensate. If it's always the same amount of offset just add it to your config file.
And here does the problem starts. The first 2-3 prints (10min ruffly) are OK, it starts afterwards to get messy and I need to readjust. I have the hope to find a better way for probing than waiting 30 minutes to prewarm a printer which prints 10 minutes only in the worst case scenario.
This z-Probe issue seems to be an endless story I fight with since 5+ years. Still have the hope to find a better way to get rid of that thermal issue.
Cheers, Chriss
@Chriss you will need to find what is moving, if you can get hold of a dial gauge you can use that to see what is moving .
@moth4017 I think that is not sooo easy here. The dial gauge will be infected by the rise of the temperature too. Maybe with a laser which crosses the chamber.... I have to think a bit more about it.
@Chriss laser wont be accurate enough . most dial gauges are ok up to 40C , you just need to use the same reference point on the frame to see what moves
the most . -
@Chriss do you have a carbon fiber x axis , if so do some checks of the z offset in the middle and at one end , as depending on the quality of the carbon tube then do move
@moth4017 Nope, it is still alu extrusion. And I z home always at the same place, so this should not be the problem. I strongly believe that the change of the offset come from the thermal expansion if the switch itself and all other parts which connect the upper part of the hotend and the switch.
The hotend expands too but I'm sure that the hotend and the plastic does not have the same expansion per K.
