    Toolboard 1LC troubles
    928
    • Arminasundefined
      Arminas
      I assume I have something wrong with my 1LC. Everything was fine, until one day I came to work and I saw that my print has failed. Now when I try to heat up the hotend, it says "offline" in DWC and temperature is 2000 C. Not sure where to start looking for the problem, physically 1LC looks good.
      Also, one more strange thing - blower fan turns 100% on when hotend goes to "offline" state.
      Since I need to solve it asap, I have created this topic and I will try to google it in the meantime..
        droftarts administrators @Arminas
        @Arminas It sound like the fan may be shorting through the thermistor wiring. The 2000C temperature indicates a dead short on the thermistor wiring. Check the wiring on the fan and thermistor, disconnect the fan and see if the thermistor reports the correct temperature.
        TronXY X5S with Duet 3 MB6HC and Roto toolboard : Cartesian bed-slinger with Duet 3 Mini 5+ WiFi and 1LC : RRP Fisher Delta v1 with Duet 2 Maestro : Polargraph with Duet 2 WiFi
        Arminasundefined 1 Reply Last reply Reply Quote 0
        • Arminasundefined
          Arminas @droftarts
          @droftarts while fan is unplugged, I get same "offline" state during the hotend heating process. Is it possible that it's just a broken thermistor?
          • oliofundefined
            oliof @Arminas
            @Arminas it's either a broken thermistor (you can check with a multimeter) or the CAN-FD connection has an issue
            • Arminasundefined Arminas marked this topic as a question
            • Arminasundefined Arminas has marked this topic as solved
            • Arminasundefined Arminas has marked this topic as unsolved
            • Arminasundefined
              Arminas @oliof
              @oliof Okay I thought I have eliminated the problem, but I don't. Now extruder motor starts doing weird stuff during the printing process. It jams, and it's very hot. Any more ideas?
              • oliofundefined
                oliof @Arminas
                @Arminas would need to know what extruder and specific motor it is, and see the config.g
                • Arminasundefined
                  Arminas @oliof
                  @oliof it's Bondtech BMG with Bondtech pancake motor (https://www.bondtech.se/product/nema17-pancake-stepper-25mm/). Never had issue with it, but now motor does not extrude consistently.
                  G90                                                    ; send absolute coordinates...
                  M83                                                    ; ...but relative extruder moves
                  M550 P"V-Core - 1"                                     ; set printer name
                  M669 K1                                                ; CoreXY
                  G21                                                    ; Set Units to Millimeters
                  G4 S2												   ; wait for expansion boards to start
                  M552 S1                                                ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1                                             ; enable HTTP
                  M586 P1 S0                                             ; disable FTP
                  M586 P2 S0                                             ; disable Telnet
                  M569 P0.0 S0 D3                                         ; physical Z1 drive 0 goes forwards
                  M569 P0.1 S0 D3                                         ; physical Z2 drive 1 goes forwards
                  M569 P0.2 S0 D3                                         ; physical Z3 drive 2 goes forwards
                  M569 P0.3 S1 D3                                         ; physical Y1 drive 3 goes backwards
                  M569 P0.4 S1 D3                                         ; physical X1 drive 4 goes backwards
                  M569 P121.0 S0 D3                                       ; physical E  drive 121.0 goes forwards
                  M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0			   			; set drive mapping
                  M350 X16 Y16 Z16 E16 I1                                 ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z800.00 E415.00                      ; set steps per mm
                  M906 X1700 Y1700 Z1700 E700 I30                        ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                                ; Set idle timeout
                  M205 X5.00 Y5.00 Z1.00 E60.00 P1                       ; set maximum instantaneous speed changes (mm/s)
                  M203 X30000.00 Y30000.00 Z3600.00 E10800.00            ; set maximum speeds (mm/min)
                  M201 X6000.00 Y6000.00 Z100.00 E10000.00               ; set maximum accelerations (mm/s^2)
                  M204 P3000 T6000                                       ; set printing and travel acceleration
                  M208 X0 Y0 Z-1 S1                                      ; set axis minima
                  M208 X413 Y405 Z405 S0                                 ; set axis maxima
                  M671 X0:203.5:408.7 Y0.5:409:0.5 S5                    ; define positions of Z leadscrews or bed levelling screws
                  M556 S100 X0.45 Y0 Z0                                  ; axis skew compensation
                  M574 X1 S1 P"121.io2.in"                               ; configure active low endstops
                  M574 Y2 S1 P"io0.in"                                   ; configure active high endstops
                  M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
                  M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0 Q50                                 ; create bed heater output on out0 and map it to sensor 0
                  M307 H0 R0.698 K0.390:0.000 D5.08 E1.35 S1.00 B0       ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                ; map heated bed to heater 0
                  M143 H0 S110                                           ; set temperature limit for heater 0 to 110C
                  M563 P0 D0 H1 F1                                       ; define tool 0
                  G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                  G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                  M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"
                  M950 H1 C"121.out0" T1                                 ; create nozzle heater output on out2 and map it to sensor 1
                  M307 H1 R1.774 K0.362:0.276 D6.68 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit
                  M143 H1 S285                                           ; set the maximum temperature in C for heater
                  M950 F0 C"121.!out1+out1.tach" Q500                    ; create fan 1 on pin out4 and set its frequency
                  M106 P0 C"Layer Fan" S0 H-1                            ; set fan 1 name and value. Thermostatic control is turned off
                  M950 F1 C"121.out2" Q500                               ; create fan 0 on pin out3 and set its frequency
                  M106 P1 C"Hotend Fan" S1 H1 T45                        ; set fan 0 name and value. Thermostatic control turned on for Hotend
                  M950 F2 C"out6" Q500                                   ; create fan 2 on pin out6 and set its frequency
                  M106 P2 C"Duet fan" S1 H-1                             ; set fan 2 value. Thermostatic control is turned off
                  ; BLTouch
                  M950 S0 C"121.^io0.out"                                ; Create a servo pin on 121.io0
                  M558 P9 C"121.^io0.in" H5 F240 T10800 A5               ; set Z probe type to unmodulated and the dive height + speeds
                  G31 P25 X-30 Y-14.50 Z1.9                              ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
                  ; Accelerometer LIS3DH and Input shaping
                  M955 P121.0 I05 ; specify orientation of accelerometer on Toolboard 1LC with CAN address 121
                  M593 P"zvd" F50
                  M404 N1.75 D0.4                                        ; Filament width and nozzle diameter
                  T0
                  ; Pressure Advance
                  M572 D0 S0.04
                  • oliofundefined
                    oliof @Arminas
                    @Arminas the TDS gives peak value of 0.7A, so I would set it to something from 550 to 600 mA in RRF. If that does not improve its behavior, measure the resistance of both phases; if they differ too much the motor may be toast.
                    Arminasundefined 4 Replies Last reply Reply Quote 0
                    • Arminasundefined
                      Arminas @oliof
                      @oliof both phases has 4.6 ohms, although it's written that it should be 4.2. Is that an issue?
                      • Arminasundefined
                        Arminas @oliof
                        @oliof But if I connect the wire and measure phase on the loose end of wire, one phase is 4.6, another is 4.9
                        • Arminasundefined
                          Arminas @oliof
                          @oliof After a few layers extruder starts to skip the steps, and it gets extremely hot, I can't keep my fingers on it. So I guess it's motor fault?
                          I tried to swap to another motor, will see how it goes.
                          • Arminasundefined
                            Arminas @oliof
                            @oliof @droftarts same issue with other motor - during the print, something happened and blower fan started to blow 100% instead of 20% and I got an error "M106 board 121 does not have fan 0".
                            Here is m122:
                            m122
                            RepRapFirmware for Duet 3 Mini 5+ version 3.4.6 (2023-07-21 14:09:13) running on Duet 3 Mini5plus WiFi (standalone mode)
                            Board ID: U51SX-F396U-D65J0-40KMW-M603Z-ZFNKD
                            Used output buffers: 1 of 40 (24 max)
                            Static ram: 103712
                            Dynamic ram: 110488 of which 36 recycled
                            Never used RAM 23804, free system stack 118 words
                            Tasks: NETWORK(notifyWait,14.3%,240) HEAT(notifyWait,0.0%,336) Move(notifyWait,1.5%,235) CanReceiv(notifyWait,0.0%,796) CanSender(notifyWait,0.0%,325) CanClock(delaying,0.0%,349) TMC(notifyWait,0.7%,106) MAIN(running,82.5%,417) IDLE(ready,0.1%,30) AIN(delaying,0.9%,263), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:47:07 ago, cause: software
                            Last software reset at 2024-04-07 22:10, reason: User, GCodes spinning, available RAM 27692, slot 0
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                            Error status: 0x00
                            MCU revision 3, ADC conversions started 2827072, completed 2827071, timed out 0, errs 0
                            Step timer max interval 1490
                            MCU temperature: min 28.0, current 35.4, max 37.4
                            Supply voltage: min 23.5, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
                            Events: 0 queued, 0 completed
                            Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 17656, writes 15, timeouts 0, DMA errors 0, CC errors 0
                            Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 17656, writes 15, timeouts 0, DMA errors 0, CC errors 0
                            Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 17655, writes 15, timeouts 0, DMA errors 0, CC errors 0
                            Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 17655, writes 15, timeouts 0, DMA errors 0, CC errors 0
                            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 41, reads 17656, writes 15, timeouts 0, DMA errors 0, CC errors 0
                            Driver 5: not present
                            Driver 6: not present
                            Date/time: 2024-04-07 22:58:07
                            Slowest loop: 219.05ms; fastest: 0.07ms
                            === Storage ===
                            Free file entries: 9
                            SD card longest read time 6.4ms, write time 2.1ms, max retries 0
                            DMs created 83, segments created 34, maxWait 130698ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 17036, completed 17036, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                            === AuxDDARing ===
                            Heater 0 is on, I-accum = 0.2
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            SBC is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Aux2 is idle in state(s) 0
                            Code queue is empty
                            === CAN ===
                            Messages queued 41267, received 55885, lost 0, boc 0
                            Longest wait 2ms for reply type 6026, peak Tx sync delay 6729, free buffers 18 (min 17), ts 14136/14135/0
                            Tx timeouts 0,0,0,0,0,0
                            === Network ===
                            Slowest loop: 183.57ms; fastest: 0.00ms
                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                            HTTP sessions: 2 of 8
                            = WiFi =
                            Interface state: active
                            WiFi firmware version 1.26
                            WiFi MAC address f0:08:d1:03:81:a2
                            WiFi Vcc 3.38, reset reason Power up
                            WiFi flash size 2097152, free heap 25616
                            WiFi IP address 192.168.32.177
                            WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                            • oliofundefined
                              oliof @Arminas
                              @Arminas what does M122 B121 report when the fan goes missing?
                              • Arminasundefined
                                Arminas @oliof
                                @oliof So I tried to print one more time. This time there is no fan error, but extruder motor started to skip steps and it's over extruding a lot, line width looks at least 2x wider than it should be. Now I am thinking that it skips steps because of the huge over extrusion.
                                M122 B121:
                                M122 B121
                                Diagnostics for board 121:
                                Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33)
                                Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
                                All averaging filters OK
                                Never used RAM 2532, free system stack 41 words
                                Tasks: Move(notifyWait,0.2%,99) HEAT(notifyWait,0.5%,83) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,74) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.2%,351) IDLE(ready,0.0%,26) AIN(delaying,5.0%,142), total 100.0%
                                Last reset 00:24:55 ago, cause: power up
                                Last software reset data not available
                                Driver 0: pos 1710258, 415.0 steps/mm,ok, SG min 0, read errors 0, write errors 2, ifcnt 78, reads 15080, writes 6499, timeouts 35, DMA errors 0, CC errors 6477, failedOp 0x6a, steps req 2007480 done 2007461
                                Moves scheduled 6321, completed 6320, in progress 1, hiccups 2, step errors 0, maxPrep 690, maxOverdue 115, maxInc 113, mcErrs 0, gcmErrs 0
                                Peak sync jitter -3/10, peak Rx sync delay 215, resyncs 0/0, next step interrupt due in 439 ticks, enabled
                                VIN voltage: min 7.7, current 23.7, max 24.3
                                MCU temperature: min 45.8C, current 67.7C, max 70.7C
                                Last sensors broadcast 0x00000002 found 1 161 ticks ago, 0 ordering errs, loop time 1
                                CAN messages queued 29964, send timeouts 0, received 19829, lost 0, free buffers 37, min 36, error reg 0
                                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 537, adv 18383/74651
                                Accelerometer: LIS3DH, status: 00
                                I2C bus errors 0, naks 3, other errors 0
                                • Arminasundefined
                                  Arminas @Arminas
                                  @dc42 maybe you have any insights?
                                    dc42 administrators @Arminas
                                    @Arminas is the blower fan that goes to 100% the hot end heatsink fan, or the print cooling fan? If there is a temperature reading error on the hot end then it's normal for the hot end heatsink fan to go to 100%. The firmware does that because it doesn't know what the temperature is, and having the heatsink fan on may prevent the hot end from clogging or getting damaged.
                                    My best guess is that either there is a problem with the temperature sensor, or the temperature reading input on the tool board has been damaged by either a short circuit between the thermistor and heater wires, or by electrostatic discharge. So I suggest you start by checking the thermistor using a multimeter. Check that its resistance at room temperature is as expected, and check that there is no continuity between it and the heater wires. If that looks OK, try using the second temperature connector on the tool board. Make sure that the hot end metalwork is connected to Duet ground, either directly or through a resistor, to prevent static charge from building up.
                                    Arminasundefined 3 Replies Last reply Reply Quote 0
                                    • Arminasundefined
                                      Arminas @dc42
                                      @dc42 it's the blower fan. Temp sensor is good by checking it with multimeter. Is it possible that toolboard temp reading input is damaged and it causes the toolboard to do weird things, like over extrusion and etc.?
                                      What do you mean by checking the continuity between temp sensor and heater wires?
                                      Hot end metalwork is not grounded I guess. How do I do that?
                                      • Arminasundefined
                                        Arminas @dc42
                                        @dc42 Same happens with second temperature connector. It just starts over extruding out of nowhere..
                                        idk if this helps, but here is M122 B121:
                                        M122 B121
                                        Never used RAM 2532, free system stack 31 words
                                        Tasks: Move(notifyWait,3.1%,99) HEAT(notifyWait,10.7%,75) CanAsync(notifyWait,0.0%,59) CanRecv(notifyWait,0.8%,74) CanClock(notifyWait,0.5%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,84.4%,57) MAIN(running,22.1%,351) IDLE(ready,0.0%,26) AIN(delaying,138.0%,142), total 259.6%
                                        Last reset 28:02:20 ago, cause: software
                                        Driver 0: pos 7263403, 415.0 steps/mm,standstill, SG min 0, read errors 3, write errors 2, ifcnt 20, reads 18793, writes 6440, timeouts 12343, DMA errors 0, CC errors 6419, failedOp 0x06, steps req 17729885 done 17729885
                                        Moves scheduled 269100, completed 269100, in progress 0, hiccups 13, step errors 0, maxPrep 747, maxOverdue 130, maxInc 67, mcErrs 0, gcmErrs 0
                                        Peak sync jitter -5/13, peak Rx sync delay 225, resyncs 0/0, no step interrupt scheduled
                                        VIN voltage: min 20.9, current 23.7, max 24.3
                                        MCU temperature: min 41.9C, current 71.1C, max 76.4C
                                        Last sensors broadcast 0x00000002 found 1 157 ticks ago, 0 ordering errs, loop time 1
                                        CAN messages queued 2019442, send timeouts 0, received 1178017, lost 0, free buffers 37, min 34, error reg 110000
                                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 974, adv 15860/74653
                                          @Arminas said in Toolboard 1LC troubles:
                                          Are you using a heated chamber?
                                          • Arminasundefined
                                            Arminas @Phaedrux
                                            @Phaedrux no, this printer is not enclosed. And I have one more RatRig Vcore 400 printer with 1LC, but this one is enclosed and there are no problems
                                            1LC temp readings on enclosed printer are the same:
                                            MCU temperature: min 19.6C, current 72.4C, max 75.2C
