    Klicky Probe Accurcy
    302
    • JADoglioundefined
      JADoglio
      As always, I am never quite sure where to ask questions. So, if this is the wrong group, please point me in the right direction. I built a new klicky probe for my Voron 2.4 running Duet 3 Mini 5+ hardware and DWC 3.4.6. I bought cheap Chinese switches instead of the Omron (my mistake). The switches seem to be less accurate than the Omron I was using , as it seems to often take more probe attempts to get a good reading.
      I did a probe repeatability and got these results;
      M292 G32 bed probe heights: -0.090 -0.094 -0.094 -0.097 -0.097 -0.097 -0.090 -0.090 -0.094 -0.094 -0.094 -0.094 -0.092 -0.094 -0.094 -0.097 -0.099 -0.097 -0.094 -0.092 -0.090 -0.092 -0.096 -0.094 -0.097 -0.094 -0.092, mean -0.094, deviation from mean 0.003. These results seem pretty good to me, but if anyone can confirm that, or tell me what they should, be that would be appreciated.
      moth4017undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @JADoglio
        @JADoglio here are my results from an omron micro switch
        G32 bed probe heights: 0.010 0.011 0.010 0.009 0.009 0.009 0.009 0.008 0.008 0.008, mean 0.009, deviation from mean 0.001
        JADoglioundefined 1 Reply Last reply Reply Quote 0
        • JADoglioundefined
          JADoglio @moth4017
          @moth4017 Thanks. That pretty well answers the question. I am buying an Omron and will start over. I suspect it will help.
          moth4017undefined 1 Reply Last reply Reply Quote 0
          • moth4017undefined
            moth4017 @JADoglio
            @JADoglio your values are good enough but buying the omron will most likely be more repeatable over time, mine is nearly 18months old and it gets used in a heated chamber too
              dc42 administrators @JADoglio
              @JADoglio what is the resolution of your Z axis? Have you tried reducing the probing speed?
              • moth4017undefined
                moth4017 @dc42
                @dc42 speed makes a litle differance
                  dc42 administrators @moth4017
                  @moth4017 have you configured the probe as type 5 or type 8 ? Type 8 is likely to be less sensitive to speed than type 5.
                  • moth4017undefined
                    moth4017 @dc42
                    @dc42 type 5
                    type 5 test
                    G32 bed probe heights: 0.022 0.028 0.019 0.022 0.032 0.030 0.027 0.026 0.032 0.030 0.024 0.025 0.026 0.020 0.027 0.022 0.026 0.024 0.019 0.023, mean 0.025, deviation from mean 0.004
                    type 8 test
                    G32 bed probe heights: 6.100 6.104 6.102 6.101 6.093 6.095 6.097 6.096 6.091 6.092 6.097 6.101 6.089 6.095 6.091 6.096 6.090 6.090 6.095 6.091, mean 6.095, deviation from mean 0.003
                    • oliofundefined
                      oliof @moth4017
                      @moth4017 those are both excellent results?
                      • moth4017undefined
                        moth4017 @oliof
                        @oliof Thanks , it took a while to design the probe .
                        now just weeks of testing
                        VID_20240404_144948.mp4
