    Stop current move without losing position
    • Depundefined
      Dep
      Hello everybody,
      Is there a GCode command or some way to stop the current movement? I need to stop movement by pressing a physical button.
      So to have a smooth stop without losing the current position?
      moth4017undefined 1 Reply Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @Dep
        @Dep Hi the only way i know how to do this is use a button to trigger a macro "pause.g" then run "resume.g"
        https://docs.duet3d.com/User_manual/Reference/Gcodes#m581-configure-external-trigger
        Depundefined 1 Reply Last reply Reply Quote 0
        • Depundefined
          Dep @moth4017
          @moth4017 No, I need to interrupt the current movement. Without losing position.
            I think something like feed hold is in the works.
            Depundefined 1 Reply Last reply Reply Quote 1
            • Depundefined
              Dep @Phaedrux
              @Phaedrux Thank you! I really want to try it! Very necessary.
