    confusion with emergency stop and a Z homing failsafe
    304
    • appjawsundefined
      appjaws
      I have the following in my config:-
      ;Endstops
      M574 U1 S1 P"e0stop" ; configure active-high endstop for low end on U via pin ustop
      M574 V1 S1 P"e1stop" ; configure active-high endstop for low end on V via pin vstop
      M574 Z1 S1 P"zstop" ; configure Z-probe endstop for low end on Z
      M574 E2 S1 P"Emgstop" ; configure Emergency stop button
      M581 P"zstop" T2 R0 ; Set Z stop as fail safe for Z zeroing and run /sys/trigger2.g
      M581 P"Emgstop" T3 R0 ; Set Emergency stop and run/sys/trigger3.g
      The failsafe and Emgstop do not work, reading the GCode dictionary I got completely lost as to how these 2 lines should be configured.
      Could some bright person please provide the correct solution.
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        jay_s_uk @appjaws
        @appjaws you should configure the inputs using M950 not M574
        appjawsundefined 1 Reply Last reply Reply Quote 0
        • appjawsundefined
          appjaws @jay_s_uk
          @jay_s_uk
          Would that be inputs or outputs?
          M950 P6 C"zfailsafe"
          M581 P6 T2 R0
          M950 P7 C"emgstop"
          M581 P7 T3 R0
          Error: Unknown pin name 'zfailsafe'
          Error: Unknown pin name 'emgstop'
          I don't think that's right, still confused, could you provide an example so that trigger2 runs please
          Simplify3D 5.1.2
            jay_s_uk @appjaws
            @appjaws you'd use the same pin names such as "zstop"
            • appjawsundefined
              appjaws @jay_s_uk
              @jay_s_uk
              M574 E2 S1 P"emgstop" ; configure Emergency stop button
              M950 P6 C"zstop"
              M581 P6 T2 R0
              M950 P7 C"emgstop"
              M581 P7 T3 R0
              The z stop worked but the emgstop has an error
              nearly there
              Simplify3D 5.1.2
                jay_s_uk @appjaws
                @appjaws where are you plugging the "emgstop" into?
                • appjawsundefined
                  appjaws @jay_s_uk
                  @jay_s_uk
                  Thanks Jay,
                  I thought it was connected to E2 but I will need to take covers off and physically check.
                  Sorry for the delay.
                  The emergency stop button is connected to the duex5 expansion board, connected to E2 Stop
                  just noticed the error Pin 'zstop' is not free
                  Simplify3D 5.1.2
                  • appjawsundefined
                    appjaws @appjaws
                    @appjaws
                    this is what I have at the moment
                    M950 P6 C"zstop"
                    M581 P6 T2 R0 ; Set Z stop as fail safe for Z zeroing and run /sys/trigger2.g
                    M950 P7 C"e2stop"
                    M581 P7 T3 R0 ; Set Emergency stop and run/sys/trigger3.g
                    Error: Pin 'zstop' is not free
                    Error: Unknown pin name 'e2stop'
                    Simplify3D 5.1.2
                    jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                      jay_s_uk @appjaws
                      @appjaws zstop won't be free if you have the M574 line calling it earlier.
                      What board are you running this on? a duet 2 by itself doesn't have an e2stop
                        droftarts administrators @appjaws
                        @appjaws It's M950 with J parameter to create inputs/triggers, not P, which is for outputs. So should be:
                        M950 J6 C"zstop"
                        M950 J7 C"e2stop"
                        Make sure zstop and e2stop are not defined anywhere else.
                        appjawsundefined 2 Replies Last reply Reply Quote 1
                        • appjawsundefined
                          appjaws @droftarts
                          @droftarts
                          Thanks for the info, I am running a duet2 plus duex5.
                          Simplify3D 5.1.2
                          • appjawsundefined
                            appjaws @droftarts
                            @droftarts
                            Thank you, all working properly now that I realized that the emergency stop pin should have been duex.e2stop
                            Simplify3D 5.1.2
