    File2 is not a valid CodeChannel
    DSF Development
    513
    • Ant1undefined
      Ant1
      Ahaaa, I managed to see wher the issue comes from !
      It seems like File2 was added in DSF 3.5, and I have a mismatch between the DSF version and the python bindings.
      To try and fix that, I added the following requirement in the plugin.json file:
        "sbcPythonDependencies": [..., "dsf-python>=3.5.0.2rc2"],
      But the plugin still fails, so I have the impression that the dsf-python package is not installed with the correct version.
      Ant1undefined 1 Reply Last reply Reply Quote 0
      • Ant1undefined
        Ant1 @Ant1
        Looking at the installation code from the Duet Software Framework repository, I feel like that this line might be wrong, with the comparison inverted:
        comparison = 'version("' + installedVersion + '")' + mCompare + 'version("' + mVersion + '")' # version numbers are strings
        https://github.com/Duet3D/DuetSoftwareFramework/blob/04486410a79a75e443ea9f81def4c55b6d8b35b1/pkg/common/duetpluginservice/opt/dsf/bin/pip3_install.py#L125C87-L125C95
        Could this come from here ?
          jay_s_uk @Ant1
          @Ant1 one for @chrishamm
          • chrishammundefined
            chrishamm administrators @jay_s_uk
            @stuartofmt any idea?
            Duet software engineer
            • Ant1undefined
              Ant1 @chrishamm
              @chrishamm @stuartofmt I also find a bit dangerous / weird to use exec(...) to compare the versions, as it can very easily lead to code injection, even though it is probably not the intent of people writing plugins.
              Edit: the allowed characters are limited (for example, no parentheses), so this is probably not possible.
              Falcounetundefined stuartofmtundefined 2 Replies Last reply Reply Quote 1
              • Falcounetundefined
                Falcounet @Ant1
                @Ant1 @chrishamm @stuartofmt I think the issue here is that the version of dsf-python is flagged as beta (rc) and pip3 install dsf-python>=version installs the last stable version.
                To make it to work, you either need to use equal : pip3 install dsf-python==version or to add the --pre argument : pip3 install --pre dsf-python>=version although, I'm not sure this is recommended as it may install unwanted beta versions.
                • stuartofmtundefined
                  stuartofmt @Ant1
                  @Ant1 @chrishamm @Falcounet
                  Sorry - for some reason I have not been getting notifications about this thread until today.
                  I will take a look at the installation script to see if it can be improved but ...
                  Please note that it's all a bit "vague". By that I mean there is no sure-fire way to check versions across all libraries. It depends too much on how the author chose to identify (or not) versions.
                  Regarding the use of exec. I was being a bit lazy but at the same time its limited to calling version. I'll take a closer look.
                  stuartofmtundefined 1 Reply Last reply Reply Quote 0
                    stuartofmt @stuartofmt
                    It looks like I have some work to do. I've not dug deeply into it yet but it seems Bookworm does not like pip3 and would prefer / needs to use pipx.
                    I can check versions of Debian and make the appropriate differences transparent to the install program. I just need a few days to carve out some spare time and then it will mostly be testing.
                    EDIT: Looks like using apt is the prefered way ...
                    If I'm missing something obvious here, that you have already encountered / resolved, please let me know.
                      I've created a chatroom to take any implementation discussion off-line. I'm progressing on the basis of providing each python plugin with its own virtual environment.
                        chrishamm administrators @Ant1
                        @Ant1 You can now install the python3-dsf-python Debian package or reference it in your plugin provided you're on v3.5 or newer. This package was gratefully provided by @Falcounet.
