Duet dementia
Upon starting a print on my Duet 2 delta the nozzle crashed into the bed - violently. It had been printing perfectly and no adjustments of any kind were made. Trouble shooting homed correctly. Using the PanelDue move screen Zup/down was perfect. However, commanding a +X100mm move caused a large move to (estimate) X85 Y30 Z30. Other moves similarly goofy. Steppers and pulleys rock solid - belts tight etc etc. Any ideas?
@Ethelred sounds like the kinematics in config.g has changed/been lost/been overridden in some way. Can you post your config.g please
Now as well, I'm unable to log onto the printer via the web interface. So I removed and read the SD card on the computer. Did a line-by-line visual compare of SD-config.g (below) with a same date backup copy on the computer. Exact match !
; Configuration file for Duet WiFi (firmware version 3.4)
; EDITED RAB 02/22/2024 // Chg ExtFeed to P4 was P3 // Deleted PurgeMotor //; General preferences
; M550 P ; set printer name
M665 R212.69 L380 B135 H278.937 ; Set R=delta radius, L=diagonal rod length, B-printable radius and H-homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M550 P# FOLLY ; Set machine name
; M551 P ; Set password
M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
M552 S1
; M552 P"0.10.0.0.173" ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y1 Z2 E4 ; set drive mapping (WAS E3)
M92 X160.00 Y160.00 Z160.00 E509.93 ; set steps per mm
M566 X750.00 Y750.00 Z750.00 E2000 ; set max instant speed chg (mm/min) chg 09/09 was 600XYZ
M203 X30000.00 Y30000.00 Z30000.00 E9000.00 ; set maximum speeds (mm/min)
M201 X2836.33 Y2836.33 Z2836.33 E3000.00 ; set accelerations (mm/s^2)
; Input Shaping
; M955 P0 C"spi.cs4+spi.cs3" ; Accelerometer
M593 P"ZVD" F36 ; Input shaping / Frequency
M572 D0 S0.055 ; SET PRESSURE ADVANCE
M906 X1200 Y1200 Z1200 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M84 S2 ; Set idle timeout; Axis Limits
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
M666 X0.29 Y-0.46 Z0.17 ; Endstop offset; Z-Probe
M558 P1 C"zprobe.in" H3.5 A5 S0.01 R1 F120 T4500 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y-20.3 Z2.92 ; set Z probe trigger value, offset and trigger height
M557 R130 S50 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 A"BED H0" ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bedheat" T0 ; create bed heater output on bedheat
M307 H0 R0.146 K0.089:0.000 D29.12 E1.35 S1.00 B0 ; Set PID for 100C HPB Heater
M143 H0 S130 ; set temperature limit for heater 0 to 130CM308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 A"E0 heater" ; configure sensor 1 as thermistor on pin e0temp
M307 H1 R1.497 K0.440:0.000 D7.74 E1.35 S1.00 B0 V23.9 ; H1 Extruder PID parameters // 230 (NOTE - FUSED @ 165C)
M143 H1 S286 ; Set MAXIMUM OVERSHOOT TEMP limit for H-1 WORKING TEMP = 280C w; Fans
M950 F0 C"fan0" Q250 ; PARTFAN on pin fan0 and set its frequency
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
M563 P0 S"EXTRUDER" D0 H1 ; define tool 0 Extruder heater
M563 P1 S"EXTRUDER" D0 H1 ; define tool 1 Extruder heater (Added 06-23 for dual filament extrusion)
G10 P0 R0 S0 ; set initial tool 0 active >>>> was P99; Miscellaneous
T0 ; select first tool -
@Ethelred Sounds like a failing SD card. Connect via USB and send M122, and post the response. You should be able to test the SD card via USB too, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
Backup the card to your PC. Then either reformat it, or replace it. Then copy the backup to the SD card and try again.
No joy - SDformatter. Copied full system back and exact same behavior.
@Ethelred said in Duet dementia:
M540 PBE:EF:DE:AD:FE:ED ; Set MAC addressThat M550 command is wrong, and I don't know the effect of the format you have used. It should be
M550 P"FOLLY"
.M540 is also redundant, see https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m540-set-mac-address
On WiFi-equipped Duet boards (Duet 3 Mini 5+ WiFi and Duet 2 WiFi) the MAC address is unique and set on the WiFi Module so this command has no effect.
Please post the response to M122. Also the response to the SD card troubleshooting commands: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
Reformatted old SD. Ethernet board. M122 and M39 appear ok to these old eyes.
console.txt -
Can you update your firmware/dwc/etc to 3.5.1?
https://github.com/Duet3D/RepRapFirmware/releases -
@Ethelred did you make the changes I suggested to config.g?
Changes made to config file as suggested and 3.5.1 update installed.
Strange behavior persists. !!! -
Reformatted old SD.
Do you have a fresh sd card to try?
Can you send M98 P"config.g" and report the results?
Can you post your config-override.g?
@Phaedrux
Config-overide. Sorry to be so unresponsive but what with cleaning out and moving house priorities get confused. Hopefully new SD tomorrow. -
yes I'm curious to see if it makes a difference.
Also, can you please post your tool change files if they exist?
tpre0.g tpost0.g
Can you upload the actual files as well for config.g, config-override.g, tool change files, etc?
@Phaedrux New, fast, big SD same behavior. No tpre0.g tpost0.g files.
I'm thinking a controller board glitch. Initial fail followed a perfect print with NO changes whatsoever. My problem (one of many) is that I'm electronically and software challenged. I'm tempted to buy a new board or take up golf.
Can you give a run down of the issues you're currently seeing?
Same as original post.. To recap
The printer homes normally. Don't know if thehoming offset leaves the nozzle in the correct location (no way to measure that). If, for example I command a simple G1 X100 the nozzle scoots away in an approximately 45 deg angle for perhaps 80-100mm and the Z ht looks to drop perhaps 20mm. If I reverse with a G1 X-100 it appears to return to the original position. Crazy.
