    IDEX BOTH ON CORE XY
    MultiAxis Printing
    8.3k
    • dwuk3dundefined
      dwuk3d
      @properprinting hot plate double gantry version of Animations created.
      IDEX Part 12 - Double Gantry Fixed Bed IDEX Youtube Video
      • dwuk3dundefined
        dwuk3d
        Upgrading virtual printer to a bigger platform (thanks to @UncleJessy for the Orangestorm Giga model on Printables). 800x800 build plate - should give plenty of room for at least 4 gantries - with 2 or more heads per gantry.
        Pictured next to the Ratrig VCore 4 IDEX 400x400 I have been using - so exactly double the size.
        Weight of the Z Axis could be a problem though.
        • JVanundefined
          JVan @dwuk3d
          @dwuk This is not quite what I meant. I meant a interlacing pattern, wide enougth to weld together the sparse infill: Result 7.png
          This way you should retain close to full part strength and can put all perimeters in a single thread for optimal surface quality. Scince the sparse infill appears to be generated in relation to a global origin, this should work for arbitrary models and infill patterns when in parallel printing mode. For parallel mirror mode, you need a infill pattern that is and stays symmetrical to your mirror plane regardless of z-height. From the more performant infill patterns, cubic appears to work, when angle is changed to zero:Symmetry and Measurement.png
          You can ignore the d-dimension. I dont know why I thought having the interlacing that wide would have been critical. I put my files on a printabels site, if you want to take a look, but cant post the link here due to lack of reputation. Ill put it in a Youtube comment for now.
          dwuk3dundefined 2 Replies Last reply Reply Quote 1
          • dwuk3dundefined
            dwuk3d @JVan
            @JVan thanks for the clarification. Will add this into the y direction segmentation gcode processor and when I create X direction mirror and duplicate mode separator will add in alternate interlacing of layers based on the support pattern.
            It will mean widening the minimum gaps slightly to avoid head clashes - but I should be able to mitigate this by optimising the placement of nozzles on extruders.
            • o_lampeundefined
              o_lampe @dwuk3d
              @dwuk Talking about interleaving infill reminded me of my regular CoreXYU, where I had one small nozzle for perimeters and a big nozzle for infill. I safed a lot of time doing "infill every n layers"
              A four-head printer could have one big infill nozzle and three finer nozzles with different colours, I guess?
              dwuk3dundefined 1 Reply Last reply Reply Quote 0
              • dwuk3dundefined
                dwuk3d @o_lampe
                @o_lampe. Interesting, I am intending to include some example print time comparisons with nozzles of different sizes in the same print. Is infill every N layers something that is available in any of the prusaslicer based slicers - as when I tried some comparisons (by using prusa XL profiles) it looked that you have to use the same layer height for the different nozzle sizes - which still brought some good savings.
                JVanundefined 1 Reply Last reply Reply Quote 0
                • JVanundefined
                  JVan @dwuk3d
                  @dwuk Its this setting. Setting it to 2 will result in double height infill lines: 309a65fe-c641-45cf-adc1-c09a683e43af-grafik.png
                  On Orca and (probably) Bambu its this. Here you set infill layer heigth directly. Either as mm or as % times nozzle diameter:
                  dwuk3dundefined 1 Reply Last reply Reply Quote 1
                  • dwuk3dundefined
                    dwuk3d @JVan
                    @JVan Added an option to colour each segment differently so that that they are easier to see.
                    Then for the parallel print segmentation I have simply offset all of the segments on alternate layers by a specified amount and I think it works quite well - so great idea thanks.
                    Screenshot with outer walls segmented - so that it is easier to see the offset joins
                    Or with the outer walls non segmented -
                    Will do the same to the mirrored segmented version next - will need to grow the width of the non mirrored section in the middle on both sides on alternate layers to get the same effect.
                    • dwuk3dundefined
                      dwuk3d @JVan
                      @JVan thanks - will try those options out.
                      My Blender simulator doesn't currently support multiple nozzle sizes - but should be fairly easy to add.
                      • o_lampeundefined
                        o_lampe @dwuk3d
                        @dwuk said in IDEX BOTH ON CORE XY:
                        In the meantime, for simulation you can reduce infill to 25% of the actual value when you plan to use double layer thickness and twice the nozzle diameter.
                        • dwuk3dundefined
                          dwuk3d
                          Trying to improve my algorithm for sizing the Y Axis segments when a) Up to 4 gantries are available and b) where the amount of extrusion time is unevenly spread across the print area.
                          In the first instance there are fairly big constraints on the minimum size of the segments due to the need to avoid head clashes.
                          Only when segments have reached their minimum sizes is there any benefit in using additional gantries in parallel.
                          And also it is only feasible to vary the start points and sizes of the segments to match better with where the extrusion is happening once the minimum sizes are all reached.
                          The attached is my attempt at working out (based on a minimum gap in the example of 3 or xxx) when it is worth starting to use extra gantries - which is highlighted in yellow.
                          The pink highlighted segments are then marked as the ones that can be varied in sized in order to better spread them over where the most work is needed on each layer.
                          I have changed my post processor to in its first pass collect an approximation of how much work is needed in each Y integer dimension in terms of raw extruding time - by dividing the length of the extruded move by the rate ( I know this is not completely accurate due to acceleration and deceleration) - and then dividing this by the Y movement and spreading these extrusions out evenly over each integer dimension in the range.
                          Will then try to use these calculated figures to help decide how the segments can be shifted around in order to make them as balanced as possible in each of the two passes.
                          Will then also consider slowing down the rates slightly in the segments that have the least work - so that ideally all print heads are in use for most of the time - rather than being intermittently idle and therefore causing oozing.
                          • o_lampeundefined
                            o_lampe @dwuk3d
                            @dwuk It seems the post processor is pretty busy. Munching through GBs of gcode is much harder than splitting an .stl file of several MB.
                            Do you use an SBC or external CPU? It would be cool, if you could process layer by layer, while already printing.
                            You don't want the whole processing take longer than reducing printing time ...
                            PS: Maybe you'll find a ready to use "center of gravity" calculation code? To me this is a close enough approximation for the best coordinate, where to put the cut. Would only work when cutting the .stl file I guess.... But maybe that's the right way of processing:
                            • decide where to place and cut the object , based on the stl file
                            • then do the cut in the gcode file
                            • dwuk3dundefined
                              dwuk3d @o_lampe
                              @o_lampe Yes the code is getting a fair bit more complex. So far I don't think there any cross layer calculations so it could potentially be done just in time layer by layer, however ultimately I think it would best be done on the CPU that is doing the slicing (or as part of the slicer).
                              A present I am doing the processing on a MacBook Air in python.
                              I found an error in the segmentation of the early examples where I was using an X rather than Y coordinate - correcting this is making the segmented models look a look more evenly split.
                              Just now need to address the slightly shifting around of segments for more efficient splitting - or for example the front (Green/Grey/Orange) and back (Black and Blue) of the cab in the attached 8 way segmented example (Shown without outer wall single threaded)
                              Version with layers alternately offset (probably a bit too far) for improved strength.
                              Will consider whether working the segments out from the centre (or most dense area) has any benefits when I am working on tweaking the segment boundaries for more efficient splits for parallel printing.
                              • dwuk3dundefined
                                dwuk3d @dwuk3d
                                @dwuk Illustrated a bit better on this version with pass1 4xgantry nozzles all in white, with pass2 in multi colour - the issue I would like to address is the really thin (and therefore inefficient) green and red sections at the bottom front of the cab and white and the back of the cab.
                                • dwuk3dundefined
                                  dwuk3d @dwuk3d
                                  @dwuk Going down a bit of a rabbit hole with the tweaking - decided to try accurately calculating the time for extrusions - including acceleration and deceleration etc - not sure if these calculations are correct - but probably doesn't matter too much at this stage.
                                  Then used this to select passes with segments in them which quite a big print time difference and then have simply taken the segment with the longest time and either reduced its size down to the minimum size it can be for head clash avoidance, or halved its size. I have then added this adjustment onto the segment with the shortest time.
                                  It didn't select the layers I expected - probably because the segments in the cab are already at minimum size.
                                  It makes the print look a bit more messy - but at least I can pick out the adjusted layers quite easily,
                                  Will run some prints through my simulations with and without the adjustments to see if the layers that have been adjusted print any more efficiently.
                                  Example 3 gantry print shown - with pass1 heads shown in white and pass2 multi colour.
                                  o_lampeundefined 1 Reply Last reply Reply Quote 2
                                  • o_lampeundefined
                                    o_lampe @dwuk3d
                                    @dwuk I'm impressed, you came quite far with simulating all the different splitting algorythms.
                                    But isn't it time to make split versions for one tool head? Just to see the real world output of your mods with inner layers overlapping and tons of retracts...
                                    I can think of several things that can go wrong trying to print the first layer. It's already nerve-wracking with a single object, although print surface and bed-adhesion has improved a lot.
                                    We know from former dual tool printers, how hard it is to find the sweet spot regarding z-height (and without mesh levelling)
                                    Somehow the second tool always scratched off the freshly laid tracks of tool one...
                                    dwuk3dundefined 2 Replies Last reply Reply Quote 0
                                    • dwuk3dundefined
                                      dwuk3d @o_lampe
                                      @o_lampe Thanks and agreed - will be interesting to see some actual single print head test prints to see what I need to do in terms of retractions and zHopping etc. to get them to work. Printers currently out of action due to house guests - but hope to be able to get access again at the back end of the week.
                                      • dwuk3dundefined
                                        dwuk3d
                                        Have been working on some realistic timings to gauge the benefits on additional gantries.
                                        Findings for the benchy model segmented into 4, 6 and 8 - for 2, 4 & 6 parallel gantries.
                                        Doing outer walls in a single pass drops the percentage saving quite a bit (14-17% additional savings in these examples) - but I still think it is probably going to be worth doing for models that need to look good.
                                        F1FD3989-75AA-4DC9-91F9-5917EC7709A3.png 0CF50B54-59DD-42AE-A816-80D1FE182F31.png 2AE57EB0-CE87-47EB-AE89-C4B48C004494.png
                                        • JVanundefined
                                          JVan @dwuk3d
                                          @dwuk I have a question regarding your segment width: From your last screenshot I guestimated in relation to your buildplate grid, that your minimal segment width is about 20mm. If I undestand correctly, you print every other segment simultaniously (like darker grey, green, red and blue) and then switch to the other half of the segments (the white ones) to ideally never have to park a gantry. My question would be, if those 20mm are a realistic assumption: If you have only two gantries, you can probably design a extruder, that has the nozzle axis quite close to one side (like the J1 Extruders but rotated), allowing you to put the nozzle axis planes of two gantrys about 20mm apart with additional hardware sticking out further to the front and the back. But if you have more then two gantries, the whole gantry width is relevant including aluminum profile, linear rail and carriage, motor, fan etc ... So, do I misunderstand something, are you using stand in values or is the buildplate texture differently scaled?
                                          • dwuk3dundefined
                                            dwuk3d @JVan
                                            @JVan Well spotted - in the example the minimum segment depth is as you surmised only 20mm on a 256mm Y AXIS which isn't really practical for anything above 2 gantries (where you could rotate them around to get the print heads fairly close).
                                            To go above 2 gantries using this approach the Y axis is going to need to be quite a lot large - 768mm for example would mean you could multiply the 20x3 - to get 60mm - which is still pretty small for current designs of extruders I know.
                                            I think I should probably stick to a maximum of 3 gantries in later examples - maybe with unequal segment sizes to take in to account the centre gantry being rotated to face one of the others.
                                            For 4 segments - pushing up the minimum size from 20 to a more practical 50mm doesn't lower the saving percentage too much - this equates to 100 on a 500mm print bed.
