    Illegal parameter and have no idea where to look or what to do.
    Duet Web Control
    • frnknstn518undefined
      frnknstn518
      i have everything updated to 3.5.1. this happens when i try to upload to print.
      • oliofundefined
        oliof @frnknstn518
        @frnknstn518 my best guess is that you are using startup macros written for Klipper since they have names like DO_THING_OR_OTHER. But we can only be sure if you share at least the first couple dozen lines of your gcode file.
        frnknstn518undefined 1 Reply Last reply Reply Quote 1
          frnknstn518 @oliof
          @oliof here is some of the g code, hopefully this is what you needScreenshot 2024-05-30 085144.png
          marvineerundefined 1 Reply Last reply Reply Quote 0
          • marvineerundefined
            marvineer @frnknstn518
            @frnknstn518 line 132 is where you should be looking. Try to comment it out like the other lines in green (put a semicolon in front) as it's not valid gcode for rrf.
            It should work nevertheless, because M109/M190 are the right commands to set temps the lines before.
              What slicer are you using? Have you set it to RepRap gcode flavour?
