    delta Z motor goes clunk, regardless of motor or driver
    30
    1.4k
    • achrnundefined
      achrn
      It occurred to me to check some other input shapinng:
      M593 P"zvd" F37 clunks more softly and at different movements: in the 1200 acceleration case (which clunks under zvddd other than 12-26) it clunks for movements above xval=22
      M593 P"zvdd" F37 clunks intermediately loudly, but at different movements: in the 1200 acceleration case (which clunks under zvddd other than 12-26) it clunks other than xval=8-24
      So I also tried varying teh frequency
      M593 P"zvddd" F74 and M593 P"zvddd" F18 both clunk and not-clunks differently to F37
      droftartsundefined T3P3Tonyundefined 3 Replies Last reply Reply Quote 1
        droftarts administrators @achrn
        @achrn Thanks. I've raised an issue for this on Github: https://github.com/Duet3D/RepRapFirmware/issues/1015
        droftarts created this issue in Duet3D/RepRapFirmware
        closed Input shaping on linear delta causes Z motor clunking at specific bed locations #1015
        SPAXundefined 1 Reply Last reply Reply Quote 1
        • SPAXundefined
          SPAX @droftarts
          Hello. I have a duet2Wifi Delta. Have the same problem after update on 3.5.2, 3.5.3 Release Candidate 1 problem too. When I switch off input shaping M593 P"none" all axis moving without clunk.
          Do you have solve for this bug?
            dc42 administrators @SPAX
            @SPAX thanks for your report.
            TBH although it appears that there is a bug in this area, we might not fix it for the following reasons:
            • Input shaping has been completely reimplemented 3.6 than in 3.5 and works much better. We have no reports of a similar bug in 3.6.
            • It's likely that tracking this bug down would require substantial effort, which ultimately would be wasted because the 3.6 code is completely different.
            • Delta printers typically have little or no need for input shaping because their resonant frequencies tend to be higher.
            Of course, if anyone else tracks this down and supplies a fix that we can validate, we will gladly include it in a future 3.5.x release.
            If you are brave enough then I suggest you try RRF 3.6.0-alpha.5 on your machine. Or you can wait for 3.6.0-beta.1 which I estimate is 2 weeks away.
            SPAXundefined 1 Reply Last reply Reply Quote 0
            • SPAXundefined
              SPAX @dc42
              @dc42 Hello!
              I updated firmware to 3.5.4 and have same problem still...
                droftarts administrators @SPAX
                @SPAX Please try RRF 3.6.0-beta.2: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.6.0-beta.2
                • T3P3Tonyundefined
                  T3P3Tony administrators @achrn
                  @achrn @SPAX
                  Please try 3.6Beta3 to confirm if the issues is resolved or not
                  https://forum.duet3d.com/topic/37289/software-version-3-6-0-beta-3-now-available
                  www.duet3d.com
                  achrnundefined 1 Reply Last reply Reply Quote 0
                    @achrn @SPAX I've gone back and tested this 'Delta clunking' issue. I set up a 6HC with 3.5.3 and reproduced the clunking, updated to 3.6.0-beta.4 and reran, no clunking. I don't think we're planning on fixing this in 3.5.x, as IS has been rewritten in 3.6.
                    If you're facing this issue in 3.5.x, it can be resolved by turning off input shaping.
                    • achrnundefined
                      achrn @T3P3Tony
                      @T3P3Tony said in delta Z motor goes clunk, regardless of motor or driver:
                      @achrn @SPAX
                      Apologies for the long delay to get back to this. I didn't try any of the betas, but I've done some multiple test cases now with 3.6.0-rc.1 and no clunks for any case. I've only tried ZVDDD input shaping (that's what I was using that clunked), but I have tried varying the other things that seemed to influence it and not triggered anything untoward.
                      Thanks.
                      apakundefined 1 Reply Last reply Reply Quote 3
                      • apakundefined
                        apak @achrn
                        @achrn I can confirm that I have also ZVDDD configured on a 3.5.4 delta, and also have some clunks issues.
                        Will update this afternoon to 3.6 RC and test
