Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard
@CrazyCreator the V2 is inverted so your second config is correct
@jay_s_uk
And this
is ok? -
@jay_s_uk and maybe @jumpedwithbothfeet said in Fly-SHT36 Max V3 RP2040 Based CAN-FD Toolboard:
... , watch out for the ribbon connectors I found them quite tricky!
I managed to get the ribbon cable in on the side of the probe, but on the board itself... No chance. It doesn't slide in deep enough to stay in place. It keeps falling out.
Do you have any tips that might make this easier or even possible?
Is there nothing on the socket itself that you need to unlock or open before inserting the ribbon cable?
@CrazyCreator
For anyone who has the same problem after me, here's how to connect or insert the ribbon cable.
You have to flip the small black bracket upwards, then insert the cable, and then flip the bracket back down. This secures the cable.
Of course, you should have known beforehand that there is a bracket on these mini jacks.
