    Accelerometer wiring on Duet2
    accelerometer
    • sungod3kundefined
      sungod3k
      I just bought the Duet Accelerometer 0.2 for a Modix with a Wifi2.
      The wiring guide here https://docs.duet3d.com/en/Duet3D_hardware/Accessories/Duet3D_Accelerometer has pictures of the Duet 3
      The guide mentions "Duet3D Accelerometer, using the LIS3DH, designed to plug into the SPI Daughterboard header on Duet 2 and 3 mainboards."
      Is that the connector that is described here https://docs.duet3d.com/duet_boards/duet_2_wifi_ethernet_maestro/duet2ndgen_connections_v1.0-1.5_d2.1.png as the "temp daughterboard"? and I directly plug it in or do I need another daughterboard for the accelerometer as well?
      Cheers
      F.
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
        droftarts administrators @sungod3k
        @sungod3k said in Accelerometer wiring on Duet2:
        Is that the connector that is described ... as the "temp daughterboard"? and I directly plug it in?
        Yes, that's correct. See this thread for an example of an accelerometer plugged in. Also that thread has identified an issue if you have a PanelDue plugged in using both cable; if possible just use one. https://forum.duet3d.com/post/338543
        sungod3kundefined 1 Reply Last reply Reply Quote 0
        • sungod3kundefined
          sungod3k @droftarts
          @droftarts great, thanks for the pic, very handy!
