    6hc-eNDSTOPS
    • kmjr20undefined
      kmjr20
      i HAVE BEEN TRYING TO GET THE MECHANICAL 2 WIRE END STOPS WORKING, THE WIRING PART HAS BEEN CHECKED WITH VOLTMETER AND TRIGGERS WHEN PRESSED, IT DOE OT STOP THE MOTOR FROM MOVING AND WHEN i RUN m119, IT SAYS OT END STOPS FOUND.
      HERE IS THE CONFIG;
      droftartsundefined kmjr20undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @kmjr20
        @kmjr20 Please post your config.g, send M122 in the DWC console and post the response, and send M98 P"config.g" and post the response.
        kmjr20undefined 1 Reply Last reply Reply Quote 0
        • kmjr20undefined
          kmjr20 @kmjr20
          @kmjr20
          THE CONFIG
          M552 I1 S0
          M552 I1 S1
          M587 S"Comstat-1QVR3" P:art7206row2unnamed!"
          M552 P0.0.0.0 S1 ; configure Ethernet adapter
          M586 P0 S1 ; configure H
          ; Smart Drivers
          M569 P0.0 S1 D2 ; driver 0.0 goes backwards (X axis)
          M569 P0.1 S1 D2 ; driver 0.1 goes backwards (Y axis)
          M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis)
          M569 P0.3 S1 D2 ; driver 0.3 goes forwards (Z axis)
          M569 P0.4 S1 D2 ; driver 0.4 goes backwards (extruder 0)
          M569 P0.5 S1 D2 ; driver 0.5 goes backwards (extruder 1)
          ; Motor Idle Current Reduction
          M906 I30 ; set motor current idle factor
          M84 S30 ; set motor current idle timeout
          ; Axes
          M584 X0.0 Y0.1 Z0.2:0.3 ; set axis mapping
          M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
          M906 X1000 Y1000 Z1300 ; set axis driver currents
          M92 X80 Y80 Z400 ; configure steps per mm
          M208 X0:1000 Y0:1000 Z0:1000 ; set minimum and maximum axis limits
          M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
          M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
          M950 S0 C"121.io7.out" ; create servo pin 0 for BLTouch
          M558 P9 C"121.io7.in" H-5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z-2.5 ; set Z probe trigger value, offset and trigger height
          M557 X15:990 Y15:990 S20 ; define mesh grid
          ; Extruders
          M584 E0.4:0.5 ; set extruder mapping
          M350 E16:16 I1 ; configure microstepping with interpolation
          M906 E1000:1000 ; set extruder driver currents
          M92 E420:420 ; configure steps per mm
          M566 E120:120 ; set maximum instantaneous speed changes (mm/min)
          M203 E3600:3600 ; set maximum speeds (mm/min)
          M201 E250:250 ; set accelerations (mm/s^2)
          M591 D0 P1 C"e0_stop" S1 ; filament monitor connected to E0_stop
          M591 D0 ; display filament sensor parameters for extruder drive 0
          M591 D1 P1 C"e1_stop" S1 ; filament monitor connected to E0_stop
          M591 D1 ; display filament sensor parameters for extruder drive 0
          ; Kinematics
          M669 K0 ; configure Cartesian kinematics
          ; Probes
          M558 K0 P9 C"io7.in" H5 F120 T6000 ; configure BLTouch probe via slot #0
          G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height
          M950 S0 C"io7.out" ; create servo #0 for BLtouch
          M574 X2 S1 P"^io3.in" ; configure X axis endstop
          M574 Y2 S1 P"^io4.in" ; configure Y axis endstop
          M574 Z2 S2 P"^io1.in" ; configure Z axis endstop
          M574 Z2 S2 P"^io2.in" ; configure Z axis endstop
          ; Mesh Bed Compensation
          M557 X50:975 Y50:975 S40:40 ; define grid for mesh bed compensation
          ; Sensors
          M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
          M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
          M950 H0 C"out0" T0 ; create heater #0
          M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0
          M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0
          M950 H1 C"out1" T1 ; create heater #1
          M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1
          M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
          ; Heated beds
          M140 P0 H0 ; configure heated bed #0+
            jay_s_uk @kmjr20
            @kmjr20 can you post a photo of your wiring?
            • kmjr20undefined
              kmjr20 @droftarts
              @droftarts
              to M98 P'config.g"
              Drive 0 standstill SG min n/a mspos 8, reads 31374 writes 16 time outs
              Drive 1 standstill SG min n/a mspos 520, reads 31375 writes 19 time outs
              Drive 2 standstill SG min n/a mspos 520, reads 31372 writes 19 time outs
              Drive 3 standstill SG min n/a mspos 520, reads 31374 writes 16 time outs
              Drive 4 standstill SG min n/a mspos 8, reads 31376 writes 16 time outs
              M119
              X:no endstop Y: no endstop Z: no endstop Z:probe at min stop
                @kmjr20 That is a very strange response to M98 P"config.g". Are you sure you typed it correctly? You should get something like:
                M98 P"config.g"
                HTTP is enabled on port 80
                FTP is enabled on port 21
                TELNET is disabled
                Warning: Heater 1 predicted maximum temperature at full power is 477°C
                This is also an odd response:
                M119
                As you have endstops defined in your config.g. What does it report if you send M574? eg mine says:
                M574
                Endstop configuration:
                X: high end switch connected to pin io1.in
                Y: low end switch connected to pin io2.in
                Z: none
                You also don't appear to have done the changes to the config.g that I suggested here: https://forum.duet3d.com/post/341415
                You also haven't posted the response to M122, please do.
                jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                • jumpedwithbothfeetundefined
                  jumpedwithbothfeet @droftarts
                  @kmjr20 It may help to also define a tool - M563: Define or remove a tool
                  6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
