    Duet 2 Ethernet not connecting
    350
    • Muhammedundefined
      Muhammed
      Hi
      I have a Duet 2 board with Ethernet connection and I'm following the "Getting Connected" documentation here, and making sure that everything is set up as documented [here].
      I am using YAT and able to configure an IP address, getting the message that says the network is enabled and the configured IP address is ..... However, I am not able to connect to the Duet on the HOST interface neither seeing any devices connected to network when I check my router. Its weird that I am not seeing the Duet in the connected devices in my Router network settings. I tried another cable and network too, but no matter what I do, I just cant see the card on the network. Any recommendations or suggestions will be highly appreciated.
      Also, wanted to ask if there is a way to find the MAC address of the Duet card by contacting support? How I can reach them?
      Thanks!
      • oliofundefined
        oliof @Muhammed
        @Muhammed if you connect via YAT, the MAC address will be in the report generated by the M122 command.
        Muhammedundefined 1 Reply Last reply Reply Quote 0
        • Muhammedundefined
          Muhammed @oliof
          @oliof Thank you.
          I used M540 command and found the MAC address, I have assigned the IP address as well.
          I can see the device on the network with the assigned IP, but when I try to ping it, all the packets get lost. When I try to connect to it through the local server GUI provided by Duet using the web sockets, its not getting connected as well.
          Are there any other commands needed to start the network communication?
          oliofundefined droftartsundefined 2 Replies Last reply Reply Quote 0
          • oliofundefined
            oliof @Muhammed
            @Muhammed best to share your config.g
              droftarts administrators @Muhammed
              @Muhammed Make sure you enable HTTP with M586:
              M586 P0 S1 ; enable HTTP
              • Muhammedundefined
                Muhammed @oliof
                @oliof @droftarts Hello
                Here are the contents of my config.g files
                ; Default config.g template for Duet 2 tested with RRF3.4.5 stable 2022-11-30
                ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org)
                ;enable UART for testing
                M575 P1 B57600 S1
                ; test network enable
                M552 P192.168.1.14
                M552 S1
                ; Display initial welcome message
                M291 P"Please go to <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">this</a> page for further instructions on how to set it up." R"Welcome to your new Duet 2!" S1 T0
                  @Muhammed Actually, HTTP should be enabled by default, so ping should work. Send M586 from YAT to check what services are running.
                  Check the IP address you are giving the Duet is within the IP range of the network, or use M552 P0.0.0.0 to use DHCP to set one.
                  • Muhammedundefined
                    Muhammed @droftarts
                    @droftarts Hi, We have the service running but ping is still not working
                    M586
                    CORS enabled for site '*'
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                    ok
                      @Muhammed I would tend to think, if you're seeing the Duet in the router, that the IP address is out of range, or shared with another device. Can you not set an IP address with DHCP?
                      It's also possible that you router doesn't allow new device connections without adding devices to a 'safe' list.
                      • Muhammedundefined
                        Muhammed @droftarts
                        @droftarts We enabled HTTP and CORS then we let DHCP assign the IP and now its working fine!.
                        Thank you everyone.
                          @Muhammed What IP address did it assign? Having Cross-Origin Resource Sharing (CORS) enabled or disabled shouldn't make any difference.
                          • Muhammedundefined
                            Muhammed @droftarts
                            @droftarts The IP address was assigned by DHCP
                              @Muhammed said in Duet 2 Ethernet not connecting:
                              Yes, but what IP address was assigned? I'm interested if it was in the same domain range, ie 192.168.1.xx, or something else. Send M552 to report the IP address. It's also possible the netmask is different from the default of 255.255.255.0. Send M553 to report the current netmask in use.
                              Muhammedundefined 2 Replies Last reply Reply Quote 0
                              • Muhammedundefined
                                Muhammed @droftarts
                                @droftarts Yes, it was the same. 192.168.1.120
                                • Muhammedundefined
                                  Muhammed @droftarts
                                  @droftarts Can I ask if there is a way to connect the Duet Ethernet card directly to my PC and use the web interface? Thanks again.
                                    @Muhammed yes, see https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
                                    • Muhammedundefined
                                      Muhammed @droftarts
                                      @droftarts Thanks alot. This was really helpful. 🙂
