Where to get fan fuses
Does anyone know where I can get these?
They are fuses that go on the Fan Jumper pins on the Duet 2
Thanks
they are not fuses they are jumper links
https://www.aliexpress.com/item/1005005414075962.html(admin: removed tracking data from link)
Not to worry solved the problem. Made one up using a dupont terminal and wire
Thanks -
@moth4017 Thank you Will look into this
Made some up using a dupont terminal but will save this link for future use
Thank you for the fast response -
