Any tips on debugging techniques for out of memory?
@dc42 I'm a little afraid to install an alpha though. Is reverting easy?
@DonStauffer assuming you are running in standalone mode not SBC mode, reverting is very easy. To make it even easier you can install just the 3.6 Duet2CombinedFirmware.bin file and continue running DWC 3.5.2. You can ignore the warning about incompatible software versions in this case.
@DonStauffer Just running M122 in the console should provide an idea of what the memory situation is before the print starts and after your startup code has run.
@gloomyandy Echoing boards[0].freeRam at various places throughout a small, 15 minute, 8-layer print job with tool changes, it looks like this (no units given; bytes?):
Machine turn-on: 8544
Partway through job startup: 8520
Before purge in job startup: 4000
After purge: 920
Beginning of Layer 1: 920
Layer 2: 848
Layer 3: 848
Layer 4: 848
Layer 5: 848
Layer 5 before tool change: 464
Layer 6: 72
Layer 6 before tool change: 72
Layer 7: 72
Layer 7 before tool change: 72
Layer 8: 72
Layer 8 before tool change: 72
After job finished: 72It seems like I'm grazing the treetops. Most of my global data is created from config.g, so I'm not really sure why my startup script uses so much memory compared to the job proper.
@dc42 OK, I'll do that. I have the details on free memory echoing throughout a job and I recorded them. So I'll have something to compare it with.
@dc42 Same GCode file as the free RAM I posted for RRF 3.5.2, but after installing 3.6 alpha 2:
After upgrade: 22624
I couldn't believe that so I did an M999 and looked again: 22600 (where are my 24 bytes?)
Partway through job startup: 22600
Before purge in job startup: 16840
After purge: 14472
Beginning of Layer 1: 14472
Layer 2: 14472
Layer 3: 14304
Layer 4: 14280
Layer 5: 14280
Layer 5 before tool change: 13512
Layer 6: 13096
Layer 6 before tool change: 13096
Layer 7: 13096
Layer 7 before tool change: 13096
Layer 8: 13096
Layer 8 before tool change: 13096
After job finished: 13096What wizardry is this?!
