Macro Line 84 error after updating to 3.5.2
I have the Duet 2 Wifi and I just updated the Firmware to 3.5.2 and now at start up, I get an error in the Console "Error in start-up file macro line 84: Pause the print before attempting to cancel it". I'll post my config file below. Thanks in advance!
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.7 on Wed Jan 15 2020 19:00:04 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Ender5" ; set printer name ; Network M552 S1 ; connect to strongest network with known SSID ;M552 S1 P"mywifi" ; enable network ;M552 S2 ; M554 PmyIP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X256 Y256 I0 ; configure microstepping without interpolation M350 Z16 E16 I1 ; configure microstepping with interpolation M92 X1254.21 Y1251.72 Z392.53 E483.27 ; set steps per mm M566 X480.00 Y480.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X60000.00 Y60000.00 Z800.00 E3000.00 ; set maximum speeds (mm/min) M201 X800.00 Y800.00 Z100.00 E5000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits ;M208 X0:225 Y0:205 Z0:300 ; set axis minima M208 X-3:234 Y0:205 Z0:300 ; set axis minima ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Filament Sensor M591 D0 P3 C"e0stop" S1 R30:150 L24.84 E3.0 ; E0 endstop, D3D magnet sensor, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y-38 Z2.08 ; set Z probe trigger value, offset and trigger height ;M557 X20:225 Y0:167 S102.5:83.5 ; define mesh grid M557 X10:225 Y0:167 P3 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ;M307 H1 R5.086 K0.545:0.000 D1.38 E1.35 S1.00 B0 V24.2 ; Heater Tune see config override ; Fans M950 F1 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P1 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F0 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P0 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S19.8 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M0 T0
@Sgt-G-294 you have an M0 is your config which is the command thats ran at the end of a print as stop. Remove it
@jay_s_uk
Thanks for the quick reply! I'll try removing that -
SOLVED - thank you
undefined jay_s_uk marked this topic as a question
undefined jay_s_uk has marked this topic as solved
