    AuruMMS - multi colour/material unit running on Duet
    3D Printing General Chat
    • Aurimasundefined
      Aurimas
      Hi Guys,
      I thought I will share with you unit that we developed 🙂
      • 5 colours
      • active heating
      • rewind of the filament
      https://youtu.be/X2Cqmb0qTWI
      Australian design and build large scale 3d printers
      https://aurarum.com.au
      o_lampeundefined 1 Reply Last reply Reply Quote 4
      • o_lampeundefined
        o_lampe @Aurimas
        @Aurimas Impressive 1st video.
        Does it work with different spool diameters? They're still not standarized after so many years of 3d printing.
        The difficult part of MM feeders is forming a decent filament tip.
        Hope to see more of your machine in the future. 👍
        Aurimasundefined 1 Reply Last reply Reply Quote 0
        • Aurimasundefined
          Aurimas @o_lampe
          @o_lampe said in AuruMMS - multi colour/material unit running on Duet:
          The cutter is independent - on the extruder in this case similar to Bambu/Voron setups.
          Also have designed actuator activated cutter that can sit just above the extruder 🙂
