    DUET3D Accelerometer Ribbon Cable flipped
    • guitartoysundefined
      guitartoys
      Just a word of warning.
      I'm used to the red stripe on a ribbon connector annotating pin 1.
      Whelp, I got my DUET3D Accelerometer in the mail, and went to hook it up, and came to find the ribbon is installed on the connectors flipped.
      Since you can only plug the cable into the Accelerometer one way, you need to be careful, and install the connector on the Duet3D M/B with pin 1 flipped to pin 10.
        droftarts administrators @guitartoys
        @guitartoys Thanks for posting. What Duet are you connecting it to? Can you take a picture of both ends of your cable in situ, and post it?
