    Z Driver assignments Voron 2.4
    • SpeedyDadundefined
      SpeedyDad
      Sorry for this rudimentary question.
      In the documentation for configuring 4 driver Z axis, it references rear left, rear right, etc. Is this looking forward from the back of the machine or looking back from the front?
      I know it really doesn't make a difference in normal use but for 4 corner leveling using my BLTouch, it definitely needs to be correct.
      Thanks
      soare0undefined 1 Reply Last reply Reply Quote 0
      • soare0undefined
        soare0 @SpeedyDad
        @SpeedyDad I configured mine like looking forward, as you normally work with the printer. However, you need to have the wiring right, and the mapping right, of course.
        It worked ok.
        SpeedyDadundefined 1 Reply Last reply Reply Quote 0
          SpeedyDad @soare0
          @soare0 OK, looking forward from the back. Kind of what I thought. I wired it front looking back and thought "that can't be correct"
            https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
            See the prerequisites here, particularly
            You must use the M671 command to define the X and Y coordinates of the leadscrews. The M671 command must come after the M584 command and must specify the same number of X and Y coordinates as the number of motors assigned to the Z axis in the M584 command; and these coordinates must be in the same order as the driver numbers of the associated motors in the M584 command. The M671 command must also come after any M667 or M669 command.
              SpeedyDad @Phaedrux
              @Phaedrux Yup. This printer in its previous life was a dual Z setup so I am familiar with that but I will have to wrap my head around setting M671 up for 4 Z axis.
                It's the same as with 2 drivers, just need to have the order of the drivers used for each motor in M671 match the order used in the Z mapping of M584.
                The positions you probe and their order are arbitrary and defined in your leveling macro.
                • soare0undefined
                  soare0 @SpeedyDad
                  @SpeedyDad
                  Maybe this helps:
                  M569 P0.2 R0 S1 T5:5:10:0                        ; Z0 drive 0.2 goes backwards
                  M569 P0.3 R0 S1 T5:5:10:0                        ; Z1 drive 0.3 goes backwards
                  M569 P0.4 R0 S1 T5:5:10:0                        ; Z2 drive 0.4 goes backwards
                  M569 P0.5 R0 S1  T5:5:10:0                        ; Z3 drive 0.5 goes backwards
                  M569 P1.0 R0 S0 T5:5:10:0                        ; extruder drive 1.0 goes forwards
                  M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0               ; set drive mapping
                  M671 X-70:-70:670:670 Y70:530:530:70 S0.5		  ; POSITION OF LEADSCREW FRONT LEFT, RL, RR, FR
                  M208 X0:524 Y0:600						  ; Xcarriage move, Ycarriage move
