Help tramming z axis with 4 motors and multiple endstop types
307
  • undefined
    p8blr
    I home z with a probe, however, I have optical endstops at the low-end of the 4 screws on my z-axis to assist with tramming if the screws get out of sync. This is necessary because the bed is too large and rigid to safely level the 4 screws if they are too far out of alignment. My issue is that my macro works, however, the printer will not home z with the probe after I run this. It is also preventing my brakes from turning back on after I run this. (Honestly, the brakes don't behave very well at all, but that's a different issue.) So I would like a more robust solution. Suggestions please?
    Z-Tramming Macro
    G1 X600 Y600 F10000 ; go to center of bed
    G92 Z1201 ; set fake z posistion 1mm away from max to ensure it travels far enough
    G91 ; relative mode
    G1 Z5 ; move z 5mm away to ensure sensors are not blocked
    M574 Z1 S1 P"0.io3.in+0.io4.in+0.io5.in+0.io6.in" ;configure active-high endstops for low end on z via those pins
    G1 H1 Z-1300 F100 ; home fast
    G1 Z5 ; move 5mm
    G1 H1 Z-1300 F50 ; home slow
    G1 Z10 F400 ; move 5mm away
    G90 ; absolute mode
    config.g
    ; Configuration file for Duet 3 MB 6XD (firmware version 3.5.0 Release Candidate 1)
    ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 09 2022 12:10:26 GMT-0600 (Central Standard Time)
    M550 P"myPrinter" ; set printer name
    ; Declare global variables
    M98 P"variables.g"
    ; Wait a moment for the CAN expansion boards to start
    G4 S2
    ; Drive Setup
    M18 ; disable steppers to disable old axes config
    ; Drive setup
    ; TX:X:X:X Min stp pls width, stp ple interval, dir setup time, dir hold time, in microseconds
    M569 P121.0 S1 R1 T1:2:1:1 ; physical drive X dc42 recommends T1:1:0.5:0 but we were using T1:2:1:1 for everything, 0.75:1.5:0.025:1 might make y stall
    M569 P0.0 S1 R1 T1:2:1:1 ; physical drive Y1
    M569 P0.1 S1 R1 T1:2:1:1 ; physical drive Y2
    M569 P0.2 S0 R1 T1:2:1:1 ; physical drive Z1
    M569 P0.3 S0 R1 T1:2:1:1 ; physical drive Z2
    M569 P0.4 S0 R1 T1:2:1:1 ; physical drive Z3
    M569 P0.5 S0 R1 T1:2:1:1 ; physical drive Z4
    M569 P3.1 S1 R1 ; physical drive E1 Mosquito 1 extruder
    M569 P3.2 S1 R1 ; physical drive E2 Mosquito 2 extruder
    M569 P122.0 S1 R0 ; physical drive E0 primary Extruder
    M569 P4.0 S1 R1 ; physical drive actuator 1
    M569 P4.1 S1 R1 ; physical drive actuator 2
    G4 S1 ; wait for drive to setup
    ; Drive mapping
    M584 X121.0 ; set drive mapping for x axis
    M584 Y0.0:0.1 ; set drive mapping for y axis
    M584 Z0.2:0.3:0.4:0.5 ; set drive mapping for z axes
    M584 E3.1:3.2:122.0 ; set drive mapping for extruder axes
    M584 U4.0 ; set drive mapping for mosquito actuator 1
    M584 V4.1 ; set drive mapping for mosquito actuator 2
    G4 S1 ; wait for drives to be mapped to letters
    ; Drive config
    M350 E16:16:16 U1 V1 ; configure microstepping with interpolation
    M92 X64 Y128 Z6400 E410:410:224.6 U200 V200 ; set steps per mm
    M566 X4000.00 Y2000.00 Z60.00 E600:600:7001 U600 V600 P1 ; set maximum instantaneous speed changes (mm/min)
    M203 X35000 Y76050 Z1500 E1200:1200:9000 U300 V300 ; set maximum speeds (mm/min), XYZ speeds based on cont. torque curve and RMS limit, currently at max values, e value set by Dyze
    M201 X2000 Y2000 Z1000 E3000:3000:5000 U100 V100 ; set accelerations (mm/s^2) X300 Y300 looks best for mosquitos, Y8000 is RMS risk, not tested above 13000 but could cause coupler failure, e was 5000
    M906 E600:600 U500 V500 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ; Brakes
    M569.7 P0.2 C"out3" S100 ; driver 2 on board 6XD uses port out3 to control the brake
    M569.7 P0.3 C"out4" S100 ; driver 3 on board 6XD uses port out4 to control the brake
    M569.7 P0.4 C"out5" S100 ; driver 4 on board 6XD uses port out5 to control the brake
    M569.7 P0.5 C"out6" S100 ; driver 5 on board 6XD uses port out6 to control the brake
    M574 X1 S1 P"3.io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 3.io0.in
    M574 Y1 S1 P"0.io1.in+io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in and io2.in
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M574 U1 S1 P"3.!io3.in" ; configure actuator 1 endstop, high end, microswitch
    M574 V1 S1 P"3.!io5.in" ; configure actuator 2 endstop, high end, microswitch
    ; Hobby Servos ; no longer used b/c ooze control not necessary
    ;M950 S0 C"3.io1.out" ; create servo 1 output on 3.io2 for mosquito acutator 1
    ;M950 S1 C"3.io4.out" ; create servo 1 output on 3.io3 for mosquito acutator 2
    ;Bed Leveling
    M671 X1205:1205:-285.1:-285.1 Y-207.2:1451.4:1451.4:-207.2 S1.5 P5 F1.0 ;Define Z screw X Y locations, max correction, pitch, fudge factor
    M208 X0 Y0 Z-0.5 U0 V0 W0 S1 ; set axis minima
    M208 X1184 Y1175 Z1200 U17 V17 W100 S0 ; set axis maxima true X max is 1204 so we are using 1184 for safety. true Y max is 1195 so we are using 1175 for safety
    ; servo pin defined in accessories section ; create servo pin for BLTouch
    M558 P8 C"!0.io8.in" H5 F{global.probeSpeeds} T99999999 R0.75 A{global.probeCycles} S0.03 ; set Z probe type and the dive height + speeds R0.5 b/c probe needs time to deploy without triggering.
    G31 P1000 X{global.probeXOffset} Y{global.probeYOffset} Z5.27 ; set Z probe trigger value, offset and trigger height. Z4.07 for 5mm nozzle
    M557 X{{global.probeXOffset},{1184+{global.probeXOffset}}} Y{{global.probeYOffset},1175} P10:10 ; define mesh grid
    M308 S0 P"0.temp0" Y"PT1000" A"Bed Inner" ; configure bed A sensor 0 as thermistor on pin temp0
    M308 S7 P"0.temp2" Y"PT1000" A"Bed Outer" ; configure bed B sensor 9 as thermistor on pin temp2
    M950 H0 C"0.out0" T0 ; create bed heater output on out0 and map it to sensor 0
    M307 H0 R0.033 K0.020:0.000 D182.23 E1.35 S1.00 B0 ; disable bang-bang for bed and set pwm
    M140 P0 H0 S0 R0 ; bed heater 0 uses heater 0
    M143 H0 S255 P0 T0 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition
    M308 S1 P"0.temp1" Y"PT1000" A"Chamber Inner" ; configure chamber A sensor 1 as thermistor on pin temp1
    M308 S8 P"0.temp3" Y"PT1000" A"Chamber Outer" ; configure chamber B sensor 10 as thermistor on pin temp3
    M950 H1 C"0.out1" T1 ; create chamber heater output on out1 and map it to sensor 1
    M307 H1 R0.078 K0.081:0.000 D38.73 E1.35 S1.00 B0 ; disable bang-bang for chamber and set pwm
    M141 P0 H1 S0 R0 ; chamber heater 1 uses heater 1
    M143 H1 S255 P0 T1 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition
    M308 S2 P"3.spi.cs0" Y"rtd-max31865" A"primary Top" ; configure primary sensor top as PT100 on pin spi.cs0
    M950 H2 C"3.out8" T2 ; create primary heater output on out3 and map it to sensor 2
    M307 H2 A940 C810 D22 S1.0 B0 ; disable bang-bang for primary and set pwm
    M143 H2 S480 P0 T2 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition
    M308 S3 P"3.spi.cs1" Y"rtd-max31865" A"primary Middle" ; configure primary sensor middle as PT100 on pin spi.cs1
    M950 H3 C"3.out7" T3 ; create primary heater output on out4 and map it to sensor 3
    M307 H3 A940 C810 D22 S1.0 B0 ; disable bang-bang for primary and set pwm
    M143 H3 S480 P0 T3 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition
    M308 S4 P"4.spi.cs0" Y"rtd-max31865" A"primary Nozzle" ; configure primary sensor nozzle as PT100 on pin spi.cs0 - WAS P"4.spi.cs0" Y"rtd-max31865"
    M950 H4 C"4.out8" T4 ; create primary heater output on out0 and map it to sensor 4
    M307 H4 A795 C920 D10 S1.0 B0 ; disable bang-bang for primary and set pwm
    M143 H4 S480 P0 T4 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition
    M308 S5 P"3.temp1" Y"PT1000" A"Mosquito 1" ; configure mosquito sensor top as PT1000 on pin 3.temp0 - other thermistor is shorted
    M950 H5 C"3.out0+out1" T5 ; create primary heater output on out3 and map it to sensor 2
    M307 H5 R2.262 K0.361:0.160 D7.99 E1.35 S1.00 B0 V24.1 ; disable bang-bang for primary and set pwm
    M143 H5 S505 P0 T5 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition
    M308 S6 P"4.temp0" Y"PT1000" A"Mosquito 2" ; configure mosquito sensor top as PT1000 on pin 3.temp0
    M950 H6 C"4.out0+out1" T6 ; create primary heater output on out3 and map it to sensor 2
    M307 H6 R2.364 K0.493:0.022 D7.12 E1.35 S1.00 B0 V24.1 ; disable bang-bang for primary and set pwm
    M143 H6 S505 P0 T6 A2 C0 ; Max heater temp: Heater number, max temp, monitor number, sensor number, action, condition
    ; Heater Faults
    M570 H0 P60 T15 R10
    M570 H1 P60 T15 R10 ;commented out because of test of combined heaters
    M570 H2 P60 T15 R10
    M570 H3 P60 T15 R10
    M570 H4 P60 T15 R10
    M570 H5 P60 T15 R10
    M570 H6 P60 T15 R10
    ; Redundant Sensors
    M308 S9 P"2.temp0" Y"PT1000" A"Bed Strip 1" ; configure bed strip array 1 sensor
    M308 S10 P"2.temp1" Y"PT1000" A"Bed Strip 2" ; configure bed strip array 2 sensor
    M308 S11 P"2.temp2" Y"PT1000" A"Bed Strip 3" ; configure bed strip array 3 sensor
    M308 S12 P"1.temp0" Y"PT1000" A"Chamber Coil 1" ; configure chamber coil 1 sensor
    M308 S13 P"1.temp1" Y"PT1000" A"Chamber Coil 2" ; configure chamber coil 2 sensor
    M308 S14 P"1.temp2" Y"PT1000" A"Chamber Coil 3" ; configure chamber coil 3 sensor
    ; Outputs
    M950 F0 C"0.out7" ; create chassis fan 0 on relay
    M106 P0 S0 H-1 C"Chassis Fan" ; set fan 0 value, thermostatic control off
    M950 F1 C"5.io1.out" ; create chamber fan 1 was !5.out3
    M106 P1 S0 H-1 C"Chamber Fan" ; set fan 1 value, thermostatic control from sensor 1 H12:13:14 T50
    M950 F2 C"0.out2" ; create primary pc fan 2
    M106 P2 S0 H-1 C"primary Fan" ; set fan 2 value, thermostatic control off
    M950 F3 C"1.out1" ; create mosquito pc fan 3
    M106 P3 S0 H-1 C"Mosquito Fan" ; set fan 3 value, thermostatic control off
    M950 P0 C{global.vacZone1Pin} ; create bed vac valve 1
    M42 P0 S0 ; set output value to off
    M950 P1 C{global.vacZone2Pin} ; create bed vac valve 2
    M42 P1 S0 ; set output value to off
    M950 P2 C{global.vacZone3Pin} ; create bed vac valve 3
    M42 P2 S0 ; set output value to off
    M950 P3 C{global.vacZone4Pin} ; create bed vac valve 4
    M42 P3 S0 ; set output value to off
    M950 P4 C"2.out6" ; create door locks on relay
    M42 P4 S0 ; set output value to off
    M950 F4 C"2.out4" ; create radiator on relay
    M106 P4 S1 H2:3:4:5:6 T50 C"Radiator" ; set fan 8 value, thermostatic control on
    M950 P5 C"1.out4" ; create probe on relay
    M42 P5 S0 ; set output value to off
    M950 P6 C"2.out3" ; create venturi valve was 1.out0
    M42 P6 S0 ; set output value to off
    M950 F5 C"4.out6" ; create head electronics fan
    M106 P5 S255 H-1 C"Head Fan 1" ; set fan 12 value, thermostatic control off
    ;M950 F6 C"4.out7" ; create head electronics fan REMOVED
    ;M106 P6 S255 H-1 C"Head Fan 2" ; set fan 12 value, thermostatic control off
    M950 P7 C"1.out8" ; create yellow stack led
    M42 P7 S0 ; set output value to off
    M950 P8 C"1.out7" ; create green stack led
    M42 P8 S0 ; set output value to off
    M950 P9 C"1.out6" ; create white stack led
    M42 P9 S0 ; set output value to off
    M950 P10 C"1.out3" ; create beep stack led
    M42 P10 S0 ; set output value to off
    M950 P11 C"2.io1.out" ; create secondary extruder reverse for mosquito 1
    M42 P11 S0 ; set output value to off
    M950 P12 C"2.io2.out" ; create secondary extruder reset/forward for mosquito 1
    M42 P12 S0 ; set output value to off
    M950 P13 C"2.out7" ; create chamber lights
    M42 P13 S0 ; set output value to off
    M950 P14 C"2.io4.out" ; create secondary extruder reverse for mosquito 2
    M42 P14 S0 ; set output value to off
    M950 P15 C"2.io5.out" ; create secondary extruder reset/forward for mosquito 2
    M42 P15 S0 ; set output value to off
    M950 P16 C"2.out5" ; create garage door on/off
    M42 P16 S0 ; set output value to off
    M950 P17 C"1.out5" ; create garage door direction
    M42 P17 S0 ; set output value to off
    M950 P18 C"121.out1" ; create speaker wait sound - piano
    M42 P18 S0 ; set output value to off
    M950 P19 C"2.out8" ; create speaker startup sound - Alert
    M42 P19 S0 ; set output value to off
    M950 P20 C"121.out0" ; create speaker notification sound - Notify
    M42 P20 S0 ; set output value to off
    M950 P21 C"1.out0" ; create speaker alarm sound - spaceship
    M42 P21 S0 ; set output value to off
    M950 P22 C"5.out0" ; create air pressure override relay
    M42 P22 S0 ; set output value to off
    M950 P23 C"5.out1" ; create duet reset enable relay
    M42 P23 S0 ; set output value to off
    G4 S2 ; adding this seems to prevent the fans from blipping on during startup
    ; Trigger Inputs
    M950 J0 C"2.io0.in" ; assign input J0 to 2.io0.in for emergency stop
    M581 P0 T0 S0 R0 ; configur external trigger, pin 0, trigger 0, inactive-active, any time
    M950 J1 C"2.io1.in" ; assign input J1 to 1.io1.in for pause button
    M581 P1 T1 S0 R1 ; configure external trigger, pin 1, trigger 1, inactive-active, during print
    ; Other Inputs
    M950 J3 C"1.io0.in" ; create door lock gpio input
    M950 J4 C"1.io1.in" ; create door lock gpio input
    M950 J5 C"1.io2.in" ; create door lock gpio input
    M950 J6 C"1.io3.in" ; create door lock gpio input
    M950 J7 C"1.io4.in" ; create door lock gpio input
    M950 J8 C"1.io5.in" ; create door lock gpio input
    M950 J9 C"5.io0.in" ; create air pressure input gpio input
    M950 J10 C"5.io1.in" ; create vacuum zone 1 input gpio input
    M950 J11 C"5.io2.in" ; create vacuum zone 2 input gpio input
    M950 J12 C"5.io3.in" ; create vacuum zone 3 input gpio input
    M950 J13 C"5.io4.in" ; create vacuum zone 4 input gpio input
    M950 J14 C"5.io5.in" ; create garage door close input gpio input
    M950 J15 C"2.io3.in" ; create garage door open input gpio input
    M563 P0 S"primary" D2 H2:3:4 F2 ; define tool 0 as primary, extruder 2, Heaters 2 3 4, Fan 2
    M568 P0 R0 S0 ; set tool 0 active and standby temperatures to 0C
    G10 P0 X0 Y0 Z0 U0 V0 W0 ; set tool 0 axis offests
    M563 P1 S"Mosquito 1" D0 H5 F3 ; define tool 1 as Mosquito 1, extruder 0, Heaters 5, Fan 3 was H5:6
    M568 P1 R0 S0 ; set tool 1 active and standby temperatures to 0C
    G10 P1 X-71.815 Y-10.976 Z{global.T1ZOffset} U0 V0 W0 ; set tool 1 axis offests
    M563 P2 S"Mosquito 2" D1 H6 F3 ; define tool 2 as Mosquito 2, extruder 1, Heaters 6, Fan 3 was H7:8
    M568 P2 R0 S0 ; set tool 2 active and standby temperatures to 0C
    G10 P2 X-71.815 Y41.411 Z{global.T2ZOffset} U0 V0 W0 ; set tool 2 axis offests
    G4 S1
    T0 ; switch to T0 when first booting up
    M98 P"soundAlert.g" ; alert that config.g has ran
    M98 P"0:/sys/startup.g"
    undefined 1 Reply Last reply 28 Aug 2024, 17:26 Reply Quote 0
    • undefined
      p8blr @p8blr
      @p8blr I hit the 2000 character limit so here's variables.g
      ; this file declares global variables and is ran by config.g
      if !exists(global.T1ActuationDist)
      global T1ActuationDist = 17
      global T2ActuationDist = {global.T1ActuationDist}
      global T12FeedRt = 1000
      global T1ZOffset = -6.34 ; used to be 7.55
      global T2ZOffset = {global.T1ZOffset} + 0.11
      global layerSpeed = 2400
      global pulsarFanSpeed = 0
      global mosqFanSpeed = 0
      global vacZone1Pin = "1.out2"
      global vacZone2Pin = "2.out0"
      global vacZone3Pin = "2.out1"
      global vacZone4Pin = "2.out2"
      global pressureAdvanceT0 = 0
      global pressureAdvanceT1 = 0.25
      global pressureAdvanceT2 = 0.25
      global probeCycles = 5
      global errorFlag = false
      global bedStripTempMin = 0
      global bedStripTempMax = 0
      global bedStripErrorCount = 0
      global heaterFaultBedEnabled = true
      global chamberCoilTempMin = 0
      global chamberCoilTempMax = 0
      global chamberCoilErrorCount = 0
      global heaterFaultChamberEnabled = true
      global lockStatus = ""
      global airStatus = ""
      global vacStatus = ""
      global vac1Status = ""
      global vac2Status = ""
      global vac3Status = ""
      global vac4Status = ""
      global probeSpeeds = {1000,100} ; fast:slow probing speeds
      global doorLockStatus = ""
      global probeXOffset = -47.8 ; probe offset from nozzle
      global probeYOffset = 15.2 ; probe offset from nozzle
      global bedProbeXMin = 122 ; minimum x posistion for 4 point leveling probing
      global bedProbeXMax = 1050 ; maximum x posistion for 4 point leveling probing
      global bedProbeYMin = 141 ; minimum y posistion for 4 point leveling probing
      global bedProbeYMax = 1065 ; maximum y posistion for 4 point leveling probing
      global fudge = 1 ; a small offset used in between G30s used in bed.g
      global chamberFanMaxSpeed = 1
      global userPrompt = 0
      else
      set global.T1ActuationDist = 17
      set global.T2ActuationDist = {global.T1ActuationDist}
      set global.T12FeedRt = 1000
      set global.T1ZOffset = -6.34
      set global.T2ZOffset = {global.T1ZOffset} + 0.11
      set global.layerSpeed = 2400
      set global.pulsarFanSpeed = 0
      set global.mosqFanSpeed = 0
      set global.vacZone1Pin = "1.out2"
      set global.vacZone2Pin = "2.out0"
      set global.vacZone3Pin = "2.out1"
      set global.vacZone4Pin = "2.out2"
      set global.pressureAdvanceT0 = 0
      set global.pressureAdvanceT1 = 0.25
      set global.pressureAdvanceT2 = 0.25
      set global.probeCycles = 5
      set global.errorFlag = false
      set global.bedStripTempMin = 0
      set global.bedStripTempMax = 0
      set global.bedStripErrorCount = 0
      set global.heaterFaultBedEnabled = true
      set global.chamberCoilTempMin = 0
      set global.chamberCoilTempMax = 0
      set global.chamberCoilErrorCount = 0
      set global.heaterFaultChamberEnabled = true
      set global.lockStatus = ""
      set global.airStatus = ""
      set global.vacStatus = ""
      set global.vac1Status = ""
      set global.vac2Status = ""
      set global.vac3Status = ""
      set global.vac4Status = ""
      set global.probeSpeeds = {1000,100} ; fast:slow probing speeds
      set global.doorLockStatus = ""
      set global.probeXOffset = -47.8
      set global.probeYOffset = 15.2
      set global.bedProbeXMin = 122 ;150
      set global.bedProbeXMax = 1050 ;1034
      set global.bedProbeYMin = 141 ;150
      set global.bedProbeYMax = 1065 ;1025
      set global.fudge = 1
      set global.chamberFanMaxSpeed = 1
      set global.userPrompt = 0
      droftartsundefined 1 Reply Last reply 29 Aug 2024, 12:20 Reply Quote 0
        droftarts administrators @p8blr
        @p8blr Please post your homeall.g and/or homez.g if the following doesn't work. Also, what firmware version?
        In your config.g, you define the Z endstop as using a probe:
        If you're using a G1 H2 move to home Z in homeall.g/homez.g, when you redefine the Z endstop in your macro as:
        it then uses this for the G1 H2 move in homeall.g/homez.g.
        Either:
        • Use G30 to home Z with the probe. You don't need M574 Z1 S2 in config.g, this can just set the other endstops. Or
        • At the end of the Z tramming macro, set the Z endstop back to M574 Z1 S2.
        undefined 2 Replies Last reply 30 Aug 2024, 14:44 Reply Quote 0
        • undefined
          p8blr @droftarts
          @droftarts I'm currently struggling to get my printer working in SBC mode again after running a firmware update. I appreciate your suggestions and I'll be sure try them as soon as I get back to an operational state. Thanks.
          • undefined
            p8blr @droftarts
            @droftarts I was able to get my printer running again if I changed it to standalone mode, rather than SBC, and upgraded to 3.5.3-rc.1. Here's some new code that I tried, the idea is creating a new axis A will stop it from interfering with the z probe, but what I'm noticing is the brakes quit working after this is run. Thoughts?
            zTramming.g
            ; new z tramming routine
            ; if it works explain how here
            M18 Z ; disable drive so it can be reassigned
            ; Drive mapping
            M584 A0.2:0.3:0.4:0.5 ; set drive mapping for new A axis - same as z is defined in driveSetup.g, note the order matters
            ; Drive config - same as z is defined in driveSetup.g
            M92 A6400 ; set steps per mm
            M566 A60 ; set max instantaneous speed changes
            M203 A1500 ; set max speed
            M201 A1000 ; set max acceleration
            ; Brakes are assigned at drive level in driveSetup.g
            M574 A1 S1 P"0.io3.in+0.io4.in+0.io5.in+0.io6.in"
            M208 A-2 S1 ; set axis minima
            M208 A1205 S0 ; set axis maxama
            ; perform tramming
            M17 A ; enable
            G4 S1 ; wait
            M98 P"soundNotifyShort.g" ; beep
            G4 S1 ; wait
            M402 ; retract probe to be safe
            M98 P"uvHomeCond.g" ; home u and v if they aren't homed
            G1 U0 V0 F999999 ; retract tools
            M98 P"doorLock.g" ; ensure doors are locked befor moving
            if {global.errorFlag}
            M99 ; exit current file
            G91 ; relative mode
            G1 H1 A-5 F500 ; try moving A just a little bit
            G1 H2 A5 F500 ; move in positive A now that we know it's safe
            G1 H1 A-1205 F200 ; move quickly in A to the endstop
            G1 H2 A5 F200 ; back off 5mm
            G1 H1 A-6 F50 ; home slowly for accurate homing
            G1 H2 A10 F500 ; back off 10mm
            G90 ; absolute mode
            M98 P"soundAlertShort.g"
            G4 S1 ; wait
            ; restore axis back to normal
            M18 A ; disable drive so it can be reassigned
            M98 P"driveSetup.g" ; restore default setup
            M584 P5 ; hide unused axes
            driveSetup.g (this is also called to setup the drives in config.g)
            ; Drive setup
            M569 P122.0 S1 R0 ; physical drive E0 Pulsar Extruder
            ; Drive mapping
            ; Drive config
            ; Brakes
            M569.7 P0.2 C"out3" S10 ; driver 2 on board 6XD uses port out3 to control the brake - was a 10ms delay but increased to a second to help with position recovery
            M569.7 P0.3 C"out4" S10 ; driver 3 on board 6XD uses port out4 to control the brake
            M569.7 P0.4 C"out5" S10 ; driver 4 on board 6XD uses port out5 to control the brake
            M569.7 P0.5 C"out6" S10 ; driver 5 on board 6XD uses port out6 to control the brake
            undefined 1 Reply Last reply 5 Sept 2024, 14:48 Reply Quote 0
            • undefined
              p8blr @p8blr
              @timschneider @chrishamm Is this issue here also related to the other brake issues we've been having? I'm running 3.5.3-rc.1 and still have the issue of the brakes not working after being re-mapped to different axes.
              gloomyandyundefined droftartsundefined 2 Replies Last reply 5 Sept 2024, 18:18 Reply Quote 0
              • gloomyandyundefined
                gloomyandy @p8blr
                @p8blr You still have the probe mapped as an endstop:
                Do you actually need to do this? You do not need to define the probe as an endstop if you are using G30 to home/probe the bed. See Ian's post above, it may well be that this is causing the interference with the z probe you are seeing.
                  @p8blr I don't see how remapping the Z axis would change the behaviour. A G1 Z# H1 move will use the defined endstop to home. A G30 command will use the probe. Can you post your homeall.g and/or homez.g?
                  The issue with the brakes not re-engaging should have been fixed, though it hasn't been closed, as is marked as 'requires testing': https://github.com/Duet3D/RepRapFirmware/issues/1023
                  It's mentioned as a bug fix in the 3.5.3-rc.1 release notes https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#reprapfirmware-353-rc1-changes-since-352
                  M17 did not energise the motor brake solenoid (issue 1023)
                  Are you saying there's also an issue with M18, that the brake doesn't come on when the drives are disabled? If you are sure it's not working for you, can you post to the Github issue?
                  dc42 created this issue 2 Jul 2024, 15:06 in Duet3D/RepRapFirmware
                  closed M17 doesn't re-engage motor brake #1023
                  undefined 1 Reply Last reply 6 Sept 2024, 15:12 Reply Quote 0
                  • undefined
                    p8blr @droftarts
                    @droftarts so here's my code after making the changes: (this is 3.5.3-rc.1 in standalone mode)
                    config.g
                    ; Configuration file for RepRapFirmware on Duet 3 Main Board 6XD
                    ; generated by RepRapFirmware Configuration Tool v3.5.4 on Thu Aug 29 2024 08:20:24 GMT-0500 (Central Daylight Time)
                    ; General
                    G90 ; absolute coordinates
                    M83 ; relative extruder moves
                    M550 P"MyPrinter" ; set hostname
                    M98 P"variables.g"
                    G4 S2
                    M552 P0.0.0.0 S1 ; configure Ethernet adapter
                    M586 P0 S1 ; configure HTTP
                    ; Drive setup
                    M569 P122.0 S1 R0 ; physical drive E0 Primary Extruder
                    ; Drive mapping
                    ; Drive config
                    ; Brakes
                    ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                    ;Bed Leveling
                    ; Kinematics
                    M669 K0 ; configure Cartesian kinematics
                    M308 S2 P"3.spi.cs0" Y"rtd-max31865" A"Primary Top" ; configure Primary sensor top as PT100 on pin spi.cs0
                    M950 H2 C"3.out8" T2 ; create Primary heater output on out3 and map it to sensor 2
                    M307 H2 A940 C810 D22 S1.0 B0 ; disable bang-bang for Primary and set pwm
                    M308 S3 P"3.spi.cs1" Y"rtd-max31865" A"Primary Middle" ; configure Primary sensor middle as PT100 on pin spi.cs1
                    M950 H3 C"3.out7" T3 ; create Primary heater output on out4 and map it to sensor 3
                    M307 H3 A940 C810 D22 S1.0 B0 ; disable bang-bang for Primary and set pwm
                    M308 S4 P"4.spi.cs0" Y"rtd-max31865" A"Primary Nozzle" ; configure Primary sensor nozzle as PT100 on pin spi.cs0 - WAS P"4.spi.cs0" Y"rtd-max31865"
                    M950 H4 C"4.out8" T4 ; create Primary heater output on out0 and map it to sensor 4
                    M307 H4 A795 C920 D10 S1.0 B0 ; disable bang-bang for Primary and set pwm
                    M950 H5 C"3.out0+out1" T5 ; create Primary heater output on out3 and map it to sensor 2
                    M307 H5 R2.262 K0.361:0.160 D7.99 E1.35 S1.00 B0 V24.1 ; disable bang-bang for Primary and set pwm
                    M950 H6 C"4.out0+out1" T6 ; create Primary heater output on out3 and map it to sensor 2
                    M307 H6 R2.364 K0.493:0.022 D7.12 E1.35 S1.00 B0 V24.1 ; disable bang-bang for Primary and set pwm
                    ; Heater Faults
                    M570 H0 P60 T15 R10
                    M570 H1 P60 T15 R10
                    M570 H2 P60 T15 R10
                    M570 H3 P60 T15 R10
                    M570 H4 P60 T15 R10
                    M570 H5 P60 T15 R10
                    M570 H6 P60 T15 R10
                    ; Redundant Sensors
                    ; Outputs
                    M950 F2 C"0.out2" ; create Primary pc fan 2
                    M106 P2 S0 H-1 C"Primary Fan" ; set fan 2 value, thermostatic control off
                    ; Trigger Inputs
                    ; Other Inputs
                    M563 P0 S"Primary" D2 H2:3:4 F2 ; define tool 0 as Primary, extruder 2, Heaters 2 3 4, Fan 2
                    ; Misc
                    G4 S1 ; wait
                    T0 ; switch to T0
                    M98 P"soundAlert.g" ; beep
                    M98 P"startup.g"
                    zTramming.g
                    ; disable axis
                    M18 Z
                    G4 S2 ; wait
                    M574 Z1 S1 P"0.io3.in+0.io4.in+0.io5.in+0.io6.in" ; configure actice high endstops at low-end
                    ; check brakes
                    M17 Z
                    G4 S2 ; wait
                    M291 P"Are brake lights illuminated?" S3
                    ; perform tramming
                    G91 ; relative mode
                    G1 H1 Z-5 F500 ; try moving Z just a little bit
                    G1 H2 Z5 F500 ; move in positive Z now that we know it's safe
                    G1 H1 Z-1205 F200 ; move quickly in Z to the endstop
                    G1 H2 Z5 F200 ; back off 5mm
                    G1 H1 Z-6 F50 ; home slowly for accurate homing
                    G1 H2 Z0 F500 ; back off 10mm
                    G90 ; absolute mode
                    This all works and the brakes keep working. But if I unmap the brakes and re-map the brakes, or remap the drive that uses brakes to a different axis, the brakes... break. The only way to get them to work again is to reboot.
                    Also on the M569.7 command, if the S parameter is too high, it causes SPI issues in the DWC console.
                    1 out of 9
