    Just upgraded SBC/Duet 6HC now have error connecting.
    • bug2k22undefined
      bug2k22
      I have just ran an upgrade on my pi5/6HC printer and am now getting the "Connecting....." and the error "Failed to open IO device: Error 2. Cannot open GPIO device file '/dev/gpiochip4'" when opening the wen interface.
      I had forgotten I was still configured to update from the 'unstable/testing' channel so have probably picked up an issue not yet resolved for the next release.
      Seems it has upgraded from 3.5.2 to 3.5.3-rc.1, the printer was working fine before the upgrade. How would I fix this issue?
      Thanks.
      [Edit]
      I've tried downgrading the duet packages to the previous version with:
      sudo apt-get install duetcontrolserver=3.5.2 reprapfirmware=3.5.2-1 duetsoftwareframework=3.5.2 duetwebserver=3.5.2 duetpluginservice=3.5.2 duetruntime=3.5.2 duettools=3.5.2 duetpimanagementplugin=3.5.2 duetwebcontrol=3.5.2
      This completes, but with the error:
      Setting up reprapfirmware (3.5.2-1) ...
      [fatal] Failed to open IO device: Error 2. Can not open GPIO device file '/dev/gpiochip4'.
      So I presume the Pi cannot communicate with the Duet board since upgrading the firmware of the board to 3.5.3-rc.1.
      A look at /dev shows only the following gpiochip values:
      gpiochip0
      gpiochip10
      gpiochip11
      gpiochip12
      gpiochip13
      bug2k22undefined 1 Reply Last reply Reply Quote 0
      • bug2k22undefined
        bug2k22 @bug2k22
        I found another article on setting up the DSF software and found that there is a reference to gpiochip4 in the file /opt/dsf/conf/config.json, editing the value of of following line resolved the issue:
        "GpioChipDevice": "/dev/gpiochip4",
        Changing this to /dev/gpiochip0 and restarting resolved the issue and I can now access the web interface.
        • gloomyandyundefined gloomyandy referenced this topic
