    Z scanning probe point error
    267
    • ortondaleundefined
      ortondale
      Finally got the Z probe to scan the bed but not returning a reading. At each probe point the message
      (Skipping grid point X=# Y=# because the Z probe cannot reach it). The height map shows 0 at each point across the bed. Can someone point me in the right direction?
      • oliofundefined
        oliof @ortondale
        @ortondale what version of RepRapFirmware and DWC are you running?
        ortondaleundefined 1 Reply Last reply Reply Quote 0
          Please share your full config.g and the results of sending M122 and M98 P"config.g"
          @ortondale said in Z scanning probe point error:
          This usually means your M557 grid definition isn't taking your G31 probe offset into account. You can only scan areas of the bed that the probe can physically reach.
            ortondale @oliof
            @oliof Hi, running latest ver. 3.5.2
              ortondale @Phaedrux
              @Phaedrux ;
              Hi
              Config files ect: RepRap Firmware and DWC ver 3.5.2
              Define mesh M557 X and Y is the position of the coil probe, G31 X and Y being nozzle offset to probe coil.
              Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Jul 27 2023 15:43:08 GMT+0200 (Central European Summer Time)
              M550 P"HyperCube" ; set printer name
              M669 K1 ; select CoreXY mode
              G4 S2 ; Wait a moment for the CAN expansion boards to start
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0.0 S0 ; physical drive 0.0 goes backward (left hand X Y axis motor)
              M569 P0.1 S0 ; physical drive 0.1 goes backward (right hand X Y axis motor)
              M569 P0.2 S0 ; physical drive 0.2 goes backward (left hand Z axis motor)
              M569 P0.4 S0 ; physical drive 0.4 goes backward (right hand Z axis motor)
              M569 P121.0 S0 ; physical drive 121.0 goes backwards (Toolboard) (extruder motor)
              M584 X0.0 Y0.1 Z0.2:4 E121.0 ; set drive mapping
              M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
              M566 X600.00 Y600.00 Z50.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X10000.00 Y10000.00 Z180 E5000 ; set maximum speeds (mm/min)30000
              M201 X2000 Y2000 Z650 E3200 ; set accelerations (mm/s^2) Moded from 20 to 200
              M906 X1150 Y1150 Z800 E560 I60 ; set motor currents (mA) and motor idle factor in per cent ( moded X Y from 900 to 700) (E 500 to 400)
              M84 S30 ; Set idle timeout
              M208 X290 Y260 Z280 S0 ; set axis maxima
              M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io2.in
              M574 Y2 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io6.in
              M574 Z1 S2 ; configure Z-probe endstop for low end on Z
              M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
              M558 P9 C"121.io0.in" H5 F120 T3000 A5 S0.05 B1 ; set Z probe type to bltouch and the dive height + speeds
              ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
              G31 P500 X30 Y0 Z1.099 ; set Z probe trigger value, offset and trigger height
              ;M557 X5:290 Y2:260 S38 ; define mesh grid
              ; Scanning Z Probe
              M558 K1 P11 C"120.i2c.ldc1612" F36000 T36000 ; K1 parameter configures it as Z probe 1 so as to leave primary probe Bltouchh as 0
              M308 A"SZP coil" S10 Y"thermistor" P"120.temp0" ; thermistor on coil
              G31 K1 Z1.9 X15.796 Y-21.5 ; define probe 1 offset and trigger height
              M558.2 K1 S16 R131621 ; set drive current and reading offset
              M557 X1.5:260 Y5:255 S13.6 ; define mesh grid for probe 1 (overwrites probe 0 mesh grid)
              M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
              M307 H0 R0.198 K0.244:0.000 D4.63 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
              M143 H0 S70 ; set temperature limit for heater 0 to 70C
              M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
              M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
              M307 H1 R1.840 K0.414:0.000 D5.70 E1.35 S1.00 B0 V24.2 ; disable bang-bang mode for heater and set PWM limit
              M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
              M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
              M563 P0 S"E3D V6" D0 H1 F0 ; define tool 0
              M955 P121.0 I52 ; Configure Accelerometer
              ; Tuning
              ;M593 P"ZVDDD" F60 S0 ; accelerometer setting
              ;M572 D0 S0.04 ;pressure advance setting
              ; Accelerometer Settings
              M375 ; load bed mesh
              ;G29 S1 ; load bed mesh
              9/10/2024, 8:51:07 PM M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Warning: the height map was loaded when the current Z=0 datum was not determined by probing. This may result in a height offset.
              9/10/2024, 8:50:21 PM m122
              RepRapFirmware for Duet 3 Mini 5+ version 3.5.2 (2024-06-11 17:14:16) running on Duet 3 Mini5plus WiFi (standalone mode)
              Board ID: M8JRG-KQ6KL-K65J0-409NL-2B02Z-RK245
              Used output buffers: 3 of 40 (22 max)
              Static ram: 103368
              Dynamic ram: 122864 of which 0 recycled
              Never used RAM 12232, free system stack 148 words
              Tasks: NETWORK(2,nWait 7,14.6%,203) LASER(5,nWait 7,0.0%,169) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.1%,278) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.9%,67) MAIN(1,running,83.4%,665) IDLE(0,ready,0.1%,29) AIN(4,delaying,0.9%,259), total 100.0%
              Owned mutexes:
              Last reset 00:11:10 ago, cause: software
              Last software reset at 2024-09-10 20:39, reason: User, Gcodes spinning, available RAM 12184, slot 2
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              MCU revision 3, ADC conversions started 670622, completed 670622, timed out 0, errs 0
              MCU temperature: min 34.5, current 34.9, max 36.2
              Supply voltage: min 23.6, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/12/12, gc cycles 0
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 88, reads 35260, writes 15, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 89, reads 35260, writes 15, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 83, reads 35259, writes 15, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 35264, writes 10, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 80, reads 35260, writes 15, timeouts 0, DMA errors 0, CC errors 0
              Driver 5: not present
              Driver 6: not present
              Date/time: 2024-09-10 20:50:17
              Cache data hit count 1300134961
              Slowest loop: 33.95ms; fastest: 0.15ms
              === Storage ===
              Free file entries: 20
              SD card longest read time 3.6ms, write time 2.8ms, max retries 0
              DMs created 83, segments created 4, maxWait 14712ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
              no step interrupt scheduled
              Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
              === DDARing 0 ===
              Scheduled moves 357, completed 357, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
              === DDARing 1 ===
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              File2 is idle in state(s) 0
              Queue2 is idle in state(s) 0
              Q0 segments left 0, axes/extruders owned 0x0000007
              Code queue 0 is empty
              Code queue 1 is empty
              === CAN ===
              Messages queued 6443, received 19161, lost 0, errs 0, boc 0
              Longest wait 2ms for reply type 6053, peak Tx sync delay 60, free buffers 26 (min 24), ts 3353/3352/0
              Tx timeouts 0,0,0,0,0,0
              === Network ===
              Slowest loop: 11.50ms; fastest: 0.00ms
              Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              === WiFi ===
              Interface state: active
              Firmware version 2.1.0
              MAC address c4:5b:be:ce:95:c3
              Module reset reason: Power up, Vcc 3.46, flash size 2097152, free heap 42632
              WiFi IP address 192.168.1.246
              Signal strength -44dBm, channel 1, mode 802.11n, reconnections 0
              Clock register 00002001
              Phaedruxundefined ortondaleundefined 3 Replies Last reply Reply Quote 0
                Phaedrux Moderator @ortondale
                Since you have two probes now you need to define the BLtouch as K0 as the scanning probe is K1. And whenever you use a command that uses or modifies the probe you need to specify K0 or K1. Exp, G29, G30, G31,
                You should remove M375 from your config.g as you don't want to load a mesh until you've homed Z.
                  ortondale @ortondale
                  @ortondale
                  Specified K0 K1 in G29, G30, G31 commands and removed M375 in config.g
                  Reset the probe area to within the probe reach.
                  The bed scanned without any error messages showing 324 points but still no height readings
                  ;M558 H30
                  G31 K0 P500 X30 Y0 Z1.099
                  ; Scanning Z Probe
                  M557 X28.7:259.9 Y5:236.2 S13.6
                  Does this prove that the coil and board are working ok and the error is in the coding?
                    @ortondale
                    What is the effective scanning distance from the bed? With the present scanning the coil is 4mm above the bed, is this distance to great.
                    Also I notice I’m not using the M558.1 command, not sure the effect this has
                      droftarts administrators @ortondale
                      @ortondale Yes, you need to calibrate the probe. 4mm above the bed is fine. Send M558.1 K1 and it will probably say "Error: M558.1: Probe has not been calibrated". Without calibrating, it doesn't know how to convert the SZP reading into a height, so you're getting the same default height for each point.
                      I've just updated the calibration section to hopefully make the M558.1 section clearer. See https://docs.duet3d.com/en/User_manual/Tuning/scanning_z_probe_calibration#calibration
                        @ortondale
                        Hi Thanks for the help, up a running ok.
                        Looks like a new bed plate called for!
