    Upgrade from Duet 2 wifi to Duet 3 6hc config Issues
    Firmware installation
    1.4k
    • Alijambo73undefined
      Alijambo73 @Phaedrux
      @Phaedrux I made the 2 changes. When I enter M98 P"config.g" into the console it just shows M98 P"config.g" with a green background and does not report any errors.
        Can you send M122 in the console and share the report here?
        Are you still getting that error message when homing?
        How are you triggering the homing?
        Alijambo73undefined 2 Replies Last reply Reply Quote 0
          @Phaedrux I'm still getting the both error messages.
          Im using Home Z on the DWC dashboard.
          Here is the M122 results
          9/19/2024, 2:54:10 PM m122
          RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (SBC mode)
          Board ID: 0JD2M-9P9DA-F0PS8-6JKD6-3S06P-1NUR2
          Used output buffers: 1 of 40 (17 max)
          Static ram: 155360
          Dynamic ram: 90872 of which 216 recycled
          Never used RAM 96616, free system stack 146 words
          Tasks: LASER(5,nWait 7,0.0%,235) SBC(2,ready,0.7%,837) HEAT(3,nWait 1,0.0%,341) Move(4,nWait 6,0.0%,238) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,336) TMC(4,nWait 6,9.5%,55) MAIN(2,running,89.7%,101) IDLE(0,ready,0.1%,29), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 00:38:32 ago, cause: software
          Last software reset at 2024-09-19 14:15, reason: User, Gcodes spinning, available RAM 96688, slot 2
          Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 45.1, current 45.6, max 45.8
          Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 11.2, current 11.2, max 11.3, under voltage events: 0
          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/180/180, gc cycles 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 472, reads 28165, writes 9 timeouts 0
          Driver 1: standstill, SG min 0, mspos 424, reads 28165, writes 9 timeouts 0
          Driver 2: standstill, SG min 0, mspos 520, reads 28161, writes 13 timeouts 0
          Driver 3: standstill, SG min 0, mspos 984, reads 28164, writes 9 timeouts 0
          Driver 4: standstill, SG min 0, mspos 776, reads 28160, writes 13 timeouts 0
          Driver 5: standstill, SG min n/a, mspos 8, reads 28173, writes 0 timeouts 0
          Date/time: 2024-09-19 14:54:13
          Slowest loop: 83.76ms; fastest: 0.05ms
          === Storage ===
          Free file entries: 20
          DMs created 125, segments created 3, maxWait 2048692ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          no step interrupt scheduled
          Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
          === DDARing 0 ===
          Scheduled moves 20, completed 20, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === DDARing 1 ===
          Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          File2 is idle in state(s) 0
          Queue2 is idle in state(s) 0
          Q0 segments left 0, axes/extruders owned 0x0000007
          Code queue 0 is empty
          Code queue 1 is empty
          === CAN ===
          Messages queued 2837, received 0, lost 0, errs 1493127, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 1576/0/0
          Tx timeouts 0,0,1576,0,0,1261 last cancelled message type 30 dest 127
          === SBC interface ===
          Transfer state: 5, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 7250/7250
          SPI underruns 0, overruns 0
          State: 5, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x24cfc
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Duet Control Server version 3.5.2 (2024-06-12 07:12:47, 64-bit)
          HTTP+Executed:
          Executing M122
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 39.42, max time between full transfers: 62.3ms, max pin wait times: 64.4ms/2.0ms
          Codes per second: 0.40
          Maximum length of RX/TX data transfers: 4392/316
          Alijambo73undefined 1 Reply Last reply Reply Quote 0
            Alijambo73 @Alijambo73
            @Alijambo73 Could this have anything to do with the Z-probe? I havent connected it to the board yet.![alt textScreenshot 2024-09-19 145807.png
              @Phaedrux how do I find the macros file the errors is referring to?
                droftarts administrators @Alijambo73
                @Alijambo73 Your Z-Probe is reading 1000, which means it is already triggered, and G30 won't work because it will see that the probe is already triggered. You won't get a sensible reading, going from 0 (not triggered) to 1000 (triggered) if you haven't connected the probe yet.
                Are your X and Y endstops connected? If the endstop plugin is saying they are triggered, are the X and Y axes actually touching them? Or are they incorrectly reporting triggered when they are not?
                RepRapFirmware does not currently return the name of the macro that reports an error (though this is a feature request). However, it's pretty clear it's the homez.g macro. When homing with G30, X and Y MUST be homed first. But then, without the probe connected, G30 isn't going to work either.
                  Alijambo73 @droftarts
                  @droftarts I have 5 endstops that are all switches. 1 on x 2 on y and 2 on z.
                  When I use the end stop monitor plug in they all seem to be working correctly. The screenshot shows that x and y are homed which was correct. I can manually trigger the 2 end stops Z and see that thay appear to be working too.
                  I have a probe to find 0 on the material. The 2 endstops used to home z are set to find the high end.
                  I'm thinking there is something in the config of the touchplate probe that is incorrect. I commented out the probe but the behavior remained the same.
                  Can you see where I have made a mistake with between the endstops and touch plate probe?
                  cosmowaveundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                  • cosmowaveundefined
                    cosmowave @Alijambo73
                    @Alijambo73 What type is your z probe? Is it like a switch?
                    Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                      @Alijambo73 Your home Z uses G30 to home, which is using the probe, not the Z endstops. If you want to use the Z endstops, you need to change homez.g to use them. Currently in homez.g you have:
                      ; homez.g
                      ; called to home the Z axis
                      ; generated by RepRapFirmware Configuration Tool v3.5.4 on Mon Sep 09 2024 22:47:08 GMT-0600 (Mountain Daylight Time)
                      ; increase Z
                      G91 ; relative positioning
                      G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
                      G90 ; absolute positioning
                      ; home Z
                      var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0]
                      var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1]
                      G1 X{var.xCenter} Y{var.yCenter} F7200 ; go to bed centre
                      G30 ; probe the bed
                      Change it to:
                      ; home Z
                      var zTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
                      G1 H1 Z{-var.zTravel} F600                            ; coarse home in the -Z direction
                      G1 H2 Z5 F6000                                        ; move back 5mm
                      G1 H1 Z-10 F300                                       ; fine home in the -Z direction
                      You will need to change the 'home Z' section of homeall.g too. You should also be able to home Z without having to home X and Y first.
                        @droftarts I'm using a touch plate like this.
                          @Alijambo73 You want to use a probe like that for setting tool offsets, not for homing the Z axis. Please try what I suggest in my last post.
                          Note that those type of probes are not much good for setting work offsets in X and Y. This type of probe is better: https://ooznest.co.uk/product/original-workbee-xyz-touch-probe/
                            @droftarts on my duet 2 board this all worked fine and I used the probe to determine 0 for the work peice while the microswitches were used for homing z.
                            I have changed the homez and homeall but still getting the 2 errors
                            Error: in file macro line 14: G1: target position outside machine limits
                            Error: in file macro line 14: G1: insufficient axes homed
                            This is how they read now.
                            Home z.g
                            ; home Z
                            homeall.g
                            ; homeall.g
                            ; called to home all axes
                            ; increase Z
                            G1 H2 Z5 F7200                                        ; move Z relative to current position to avoid dragging nozzle over the bed
                            ; home XY
                            var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
                            var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
                            G1 H1 X{-var.xTravel} Y{-var.yTravel} F6000           ; coarse home in the -X and -Y directions
                            G1 H2 X5 Y5 F7200                                     ; move back 5mm
                            G1 H1 X{-var.xTravel} Y{-var.yTravel} F300            ; fine home in the -X and -Y directions
                            ; home Z
                              @Alijambo73 Can you describe, from turning on the machine, exactly what you are doing, and post all the responses coming back from the console? ie of the two errors you report above, which is from running homez.g, and which is from running homeall.g?
                              Somehow, it seems some other macro is being called, and it's that macro that has got the error in it. Please could you zip your whole sys folder (so it has all the files) from your SD card and post it here? If you add '.txt' to the end after .zip, you should be able to upload it to the forum.
                                @droftarts after power up if I use home z I get " Error: in file macro line 14: G1: insufficient axes homed"
                                If I then home x and y, then use home z i get "Error: in file macro line 14: G1: target position outside machine limits"
                                After power up if I hit homeall (this is new) it will home correctly but then if I try to lower Z by -25 it tries to raise z even though the endstops are triggered.
                                This just keeps getting more weird.
                                download (1).zip.txt
                                  dc42 administrators @Alijambo73
                                  @Alijambo73 said in Upgrade from Duet 2 wifi to Duet 3 6hc config Issues:
                                  This is normal if homeZ uses the Z probe to home, because you would be probing at a random position, possibly off the bed.
                                  You are doing this:
                                  My guess is that the calculation of yCenter and/or xCenter is going wrong. Have you set up the grid in config.g? Why not use bed centre calculated from the M208 limits instead?
                                    Alijambo73 @dc42
                                    @dc42 I don't want it to use the center of the bed. I want the z to home at x0 y0.
                                    I inverted the zprobe and it now reads 0 in DWC and I changed this line
                                    to
                                    G1 H1 Z{var.zTravel} F600                            ; coarse home in the -Z direction
                                    I also reversed the direction on the Z steppers and now the homeall seems works correctly.
                                    If I try to just home Z i get "G28 Z
                                    Error: Failed to home axes Z"
                                    Here is the homeall.g that is working
                                    ; homeall.g
                                    ; increase Z
                                    ; home XY
                                    ; home Z
                                    Here is the homez.g that is giving the error
                                    ; home Z
                                    var maxTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
                                    G1 H1 Z{var.maxTravel} F600                             ; coarse home in the +Z direction
                                    G1 Z-5 F6000                                            ; move back 5mm
                                    G1 H1 Z{var.maxTravel} F300                             ; fine home in the +Z direction
                                      Phaedrux Moderator @Alijambo73
                                      Do you see the difference?
                                        @Phaedrux That was it. Thank you for your help.
