    Getting error from Cura gcode: Error: Bad command: -1 M110
    • westechundefined
      westech
      Greetings!
      I sliced from Cura 2.8. It printed fine but the console gave me this error at the start : Error: Bad command: -1 M110.M110 is not in my start or end Gcode. So not sure were in Cura I can turn it off? Any idea what it is trying to do?
      Weird, I just did a search of the gcode in GCODE ANALYZER, and M110 can't be found?
      Thanks
      Max
        dc42 administrators @westech
        @westech is it repeatable if you start printing the same file again?
        westechundefined 1 Reply Last reply Reply Quote 0
        • westechundefined
          westech @dc42
          @dc42 Yes, I printed three versions. Like I said it printed fine. I double checked my start GCODE from Cura and no M110. Not a big deal since it prints. Just curious what Cura was trying to execute that Duet didn't like.
          So no worries:-)
            jay_s_uk @westech
            @westech can you post a sample gcode file?
            what firmware version are you running? what board? standalone or SBC?
            • westechundefined
              westech @jay_s_uk
              @jay_s_uk Hi Jay!!! Its a Mellow FLY RRF E3 V1.0 (I have several of you boards:-)
              DWC 3.5.2,
              STMWIFI 3.3.0_14
              Duet Wifi Server 1.26-05S-D
              Endcap 96.5 v101.5 1.2mm.gcode
                jay_s_uk @westech
                @westech wow, the version of your firmware is old. you should also avoid mismatching the version of the firmware and DWC.
                I would suggest you upgrade to the latest stable
                https://teamgloomy.github.io/fly_e3_upgrading_3_5.html
                • westechundefined
                  westech @jay_s_uk
                  @jay_s_uk Thanks will do.
