    Pausing a print…
    • vbtalent
      vbtalent last edited by
      I have the need to pause a lengthy print.
      Since I've never done this before I was wondering what the process for implementing it is. Do I simply "Pause" the print and shut down the printer and laptop?
      I assume I should home the machine before restarting? How does it know what line of code to start from when I fire up the printer again?
      Any "how-to" would be great if there is one..
      Thanks.
      ampapa,
      • elmoret
        elmoret last edited by
        Are you printing on a cold bed? If not, won't the print come detached if you power down the printer?
        Why not just pause conventionally? How long are you looking to pause for?
        • vbtalent
          This is on a heated bed with PEI… I hadn't thought about the print coming loose though.
          Overnight shutdown...
          • elmoret
            Part is likely to come loose if the heated bed cools. You could pause conventionally and then turn off the hotend heater (leaving on the bed heater), I believe, though I've never tried.
              If you do want to shut down the printer completely, use firmware 1.20 and see https://duet3d.com/wiki/Setting_up_to_resume_a_print_after_a_power_failure_or_planned_power_down.
              • vbtalent
                Thanks David.
                I'll be giving that a shot before long then.
                ampapa,
