    CNC Lathe using stepper as spindle
    • flopesundefined
      flopes
      I am making a small lathe and using a stepper motor as spindle. I am using the Duet2 wifi running Duet Web 3.4.6.
      How can I control the rpm of the motor in such a way it stays spinning until commanded to stop?
      Thanks
        jay_s_uk @flopes
        @flopes thats not currently supported
        flopesundefined 1 Reply Last reply Reply Quote 0
        • flopesundefined
          flopes @jay_s_uk
          @jay_s_uk Thanks
          What about producing a 0-10V output, specified at tool definition?
          flopesundefined droftartsundefined 2 Replies Last reply Reply Quote 0
          • flopesundefined
            flopes @flopes
            @flopes or pwm?
              jay_s_uk @flopes
              @flopes you could define a spindle and use PWM in CNC mode
                droftarts administrators @flopes
                @flopes a DC motor controlled by a VFD would be a much better choice for a lathe. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_CNC#connecting-a-spindle
                The rest of that page will also be useful setting up the lathe in CNC mode.
