    Software bundle 3.6.0-beta.1 now available
    Beta Firmware
    8
    17
    1.4k
    • edspedundefined
      edsped
      @dc42 I'm not sure what's changed between the last alpha and the current beta but the Jubilee is once again dropping tools even with the M400's...
      edit: on a side note it primarily appears to happen after I cancel a print and it parks the tool. At this point I'm reverting to the alpha 5 as it's been pretty solid.
      • edspedundefined
        edsped
        I didn't have an M400 command after the tool park in my cancel.g file so that may be the culprit. I'll add it and retry but it won't be until tomorrow.
        • edspedundefined
          edsped
          A few prints in and it seems as if adding the M400 to cancel.g addressed the issue. I guess I haven't been cancelling prints on the alpha.. Otherwise all seems to be working as expected.
          • NeoDueundefined
            NeoDue @dc42
            @dc42 said in Software bundle 3.6.0-beta.1 now available:
            @NeoDue no we haven't implemented that yet, it's separate from input shaping.
            Thanks! Then I will wait until 3.6 is final.
            • Notepadundefined
              Notepad
              Im tracking a possible bug (hard to determine if its hardware or firmware) relating to motor idle current.
              Testing hardware is a E3D Roto
              Current working theory is when pause.g is pressed and the motors go into the lower power idle state. the Extruder motor also goes to a lower amperage mode, however when resuming or manually extruding the motor does wake up and stays at a low power mode.
              Once I'm back from the trade show I am on (1 week left) I can swap extruders to check different types to see if the behaviour is consistent or just a behaviour of the Roto
              The real bamboo printer manufacturer
              Kioliaundefined 1 Reply Last reply Reply Quote 0
              • Kioliaundefined
                Kiolia @Notepad
                @Notepad I have run into something similar to this, but I can't reproduce it yet... detailed my experience at the bottom of the earlier 3.6.0 alpha build thread.
                AWD 48V Duet 3 6HC+3HC Linear Kossel XL "CarbonShrike"
                https://www.printables.com/@Kiolia | youtube.com/@jamespray
                aka Colphaer (Discord) | aka the Deltavangelist | aka that one duct guy
                • Kioliaundefined
                  Kiolia @dc42
                  [3.6.0-beta.1]
                  Did you get around to trying to reproduce Z axis clicking on linear delta with very slow, long-lasting moves? I'm still seeing this in the beta, albeit possibly somewhat reduced from the alpha.
                  • samlogan87undefined
                    samlogan87
                    Hey @dc42
                    I can't see anything in the release notes as to whether the new input shaping/3.6 release, has been released for the 1HCL boards or is it in development?
                    Sam
                    Custom Core-XY
                      dc42 administrators @samlogan87
                      @samlogan87 yes it's implemented in 3.6beta1 on all expansion boards including 1HCL and M23CL motors.
                      samlogan87undefined 1 Reply Last reply Reply Quote 0
                        samlogan87 @dc42
                        @dc42 awesome thank you. Will update tonight and give it a try
                        Custom Core-XY
                        • Notepadundefined
                          Notepad
                          Possible bug in 3.6.b1. Once a printer is Estop'ed the PanelDue sometimes doesn't reconnect and gets stuck in a connecting state. I have absolutely no idea how to gather data for this other than an observation + the behaviour is inconsistent.
                          This may be related to another issue I am diagnosing (I am not sure its a RRF issue or just a user setup issue so I didn't mention it before) where the PanelDue connected to a D36HC w/ SBC seems to have random slow response times. Pressing a button can take up to 2 seconds before the press is registered/actioned, some other times is instant like normal. This behaviour is not present in any of my D2 machines that do not include an SBC
