    3.6.0-beta.1 Breaking Homing Sequence
    Beta Firmware
    8
    28
    1.2k
    • AndyE3Dundefined
      AndyE3D
      @Notepad @Charlie this is the equation that uses the acceleration & velocity constants
      float PhaseStep::CalculateCurrentFraction() noexcept
      	// Driver is in assisted open loop mode
      	// In this mode the PID terms are not used and the A and V terms are independent of the loop time.
      	constexpr float scalingFactor = 100.0;
      	constexpr float scalingFactorSqr = scalingFactor * scalingFactor;
      	PIDVTerm = mParams.speed * Kv * scalingFactor;
      	PIDATerm = mParams.acceleration * Ka * scalingFactorSqr;
      	PIDControlSignal = min<float>(fabsf(PIDVTerm) + fabsf(PIDATerm), 256.0);
      	currentFraction = holdCurrentFraction + (1.0 - holdCurrentFraction) * min<float>(PIDControlSignal * (1.0/256.0), 1.0);
      	if (reprap.GetDebugFlags(Module::Move).IsBitSet(MoveDebugFlags::PhaseStep))
      		debugPrintf("v=%f, a=%f, cf=%f\n", (double)(mParams.speed * scalingFactor), (double)(mParams.acceleration * scalingFactorSqr), (double)currentFraction);
      	return currentFraction;
      The units, calculation, and tuning are almost identical to assisted open loop on the 1HCL board with the main difference being it does not have the encoder to warn about skipped steps (stall detect also does not work when phase stepping), and the Kp & Kd terms are not used.
      In YAT make sure that you have enabled DTR if you are running the latest firmware as the USB code was changed recently. I don't know if there are other difference connecting to the Duet on MacOS
      Charlieundefined 2 Replies Last reply Reply Quote 1
      • Charlieundefined
        Charlie @AndyE3D
        @AndyE3D Thank you so much for posting this code. Im pretty new to code in general, but it looks like makes sense (unless im completely mistaken which is also possible). Looks like this is in GitHub: ReprapFirmware/src/Movement/PhaseStep.cpp, line 132 for others that may be looking.
        After trying to put some of this in a spreadsheet (which Im sure is not the best way to go about this, but its what I kinda know), and putting in some velocity and acceleration values, Im struggling to get the PIDControlSignal value to be anything other than the 256 max value, which will in turn set the currentFraction to the max of 1.
        Im not sure what Im missing here. Could be that the mParams arent actually as simple as the speed and accel in mm/sec(^2), I may have calculated holdCurrentFraction wrong (in PhaseStep.h as 0.71), or the default values are really conservative. Or something else that I cant think of.
        • Charlieundefined
          Charlie @AndyE3D
          @AndyE3D And yes, making sure that DTR was enabled solved my issue with connection! Thank you so much. I can now use YAT on the PC to send and receive commands using a direct USB connection to the Duet.
          Now my issue is that, although I can connect and send an M122 command and get an output, once I send M111 P4 S1, every time I send a move command (like G91 G1 H2 X10 F3000) I get a "Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)", and then a "Warning: SPI connection has been reset". Then it seems to restart, as the machine is no longer homed.
          • gloomyandyundefined
            gloomyandy @Charlie
            @Charlie If you run M122 and post the output it may provide information that will allow Andy to see if the mcu reset or not (and why).
            Charlieundefined 1 Reply Last reply Reply Quote 0
            • Charlieundefined
              Charlie @gloomyandy
              @gloomyandy @AndyE3D I was under the (potentially incorrect) assumption that if the MCU reset, it would not be reflected in the M122 (since it restarted and reset). With that being said, here's the response to M111:
              M111 P4 S1
              Debugging enabled for modules: Move(4 - 0xffffffff)
              Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Heat(5) Kinematics(6) InputShaping(7) unused(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) SbcInterface(16) CAN(17) Expansion(18)
              Here's the M122 after sending M111 P4 S1, but before the move command:
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.6.0-beta.1 (2024-09-24 10:07:51) running on Duet 3 MB6HC v1.01 (SBC mode)
              Board ID: 08DJM-956L2-G43S8-6J9DG-3S46T-KV2LF
              Used output buffers: 2 of 40 (23 max)
              Static ram: 136444
              Dynamic ram: 96212 of which 4652 recycled
              Never used RAM 90476, free system stack 156 words
              Tasks: SBC(2,nWait 7,0.9%,795) HEAT(3,nWait 6,0.0%,325) Move(4,nWait 6,0.0%,211) TMC(5,nWait 6,11.3%,283) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,348) MAIN(2,running,87.8%,101) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,134), total 100.0%
              Owned mutexes: USB(MAIN)
              Last reset 00:13:55 ago, cause: power up
              Last software reset at 2024-11-06 20:54, reason: AssertionFailed, Gcodes spinning, available RAM 90560, slot 1
              Software reset code 0x0123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x20415a34 Task MAIN Freestk 2233 ok
              Stack: 00000001 00000000 0049941d 20426970 00000000 204207e8 20426970 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 51.7, current 52.7, max 52.9
              Supply voltage: min 26.4, current 26.5, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
              Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/88/8, gc cycles 0
              Events: 0 queued, 0 completed
              Date/time: 2024-11-07 12:46:12
              Slowest loop: 2.24ms; fastest: 0.07ms
              USB interrupts 161
              === Storage ===
              Free file entries: 20
              Segments created 38, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 26080.00/26080/0.00 1920.00/1920/0.00 2036.00/2036/0.00
              no step interrupt scheduled
              Driver 0: standstill, SG min n/a, mspos 8, reads 11116, writes 0 timeouts 0
              Driver 1: standstill, SG min n/a, mspos 8, reads 11116, writes 0 timeouts 0
              Driver 2: standstill, SG min n/a, mspos 520, reads 11117, writes 0 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 520, reads 11116, writes 0 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 520, reads 11116, writes 0 timeouts 0
              Driver 5: standstill, SG min n/a, mspos 520, reads 11116, writes 0 timeouts 0
              Phase step loop runtime (us): min=0, max=25, frequency (Hz): min=6410, max=10563
              === DDARing 0 ===
              Scheduled moves 12, completed 12, LaErrors 0, Underruns [0, 0, 0]
              === DDARing 1 ===
              Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1 -1 -1 -1 -1, ordering erHeater 1 is on, I-accum = 0.0
              HTTP* is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is ready with "M122" in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              File2 is idle in state(s) 0
              Queue2 is idle in state(s) 0
              Q0 segments left 0, axes/extruders owned 0x80000007
              Code queue 0 is empty
              Code queue 1 is empty
              === Filament sensors ===
              check 0 clear 0
              Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
              === CAN ===
              Messages queued 1329, received 3024, lost 0, ignored 0, errs 0, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 50 (min 50), ts 738/738/0
              Tx timeouts 0,0,0,0,0,0
              === SBC interface ===
              Transfer state: 5, failed transfers: 0, checksum errors: 0
              RX/TX seq numbers: 31603/31603
              SPI underruns 0, overruns 0
              State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x27f90
              Buffer RX/TX: 0/0-0, open files: 0
              ok
              The move command:
              G91
              G1 H2 X10 F3000
              And the M122 output after:
              M122
              Static ram: 136444
              Dynamic ram: 96104 of which 4652 recycled
              Never used RAM 91496, free system stack 180 words
              Tasks: SBC(2,nWait 7,0.8%,791) HEAT(3,nWait 6,0.0%,335) Move(4,nWait 6,0.0%,321) TMC(5,nWait 6,11.1%,379) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,350) MAIN(2,running,88.0%,101) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,134), total 100.0%
              Last reset 00:00:36 ago, cause: software
              Last software reset at 2024-11-07 12:49, reason: HeatTaskStuck, Gcodes spinning, available RAM 90476, slot 2
              Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0042780f BFAR 0x00000000 SP 0x2041d3d0 Task Move Freestk 958 ok
              Stack: 00000000 2041cd2c 10000000 e000e000 2041d4b8 0049a1d5 0049a9cc 61000000 204210a0 20432728 20432728 00000000 204326a0 00453cf9 001025cc 00456df5 20432728 204326a8 a5a5a5a5 a5a5a500 42576179 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 53.7, current 53.9, max 54.1
              12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
              Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/80/0, gc cycles 0
              Date/time: 2024-11-07 12:50:35
              Slowest loop: 2.11ms; fastest: 0.08ms
              USB interrupts 185
              === Storage ===
              Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
              next step interrupt due in 11 ticks, disabled
              Driver 0: standstill, SG min n/a, mspos 8, reads 7814, writes 0 timeouts 0
              Driver 1: standstill, SG min n/a, mspos 8, reads 7814, writes 0 timeouts 0
              Driver 2: standstill, SG min n/a, mspos 520, reads 7814, writes 0 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 520, reads 7814, writes 0 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 520, reads 7813, writes 0 timeouts 0
              Driver 5: standstill, SG min n/a, mspos 520, reads 7814, writes 0 timeouts 0
              Phase step loop runtime (us): min=0, max=26, frequency (Hz): min=6465, max=10416
              === DDARing 0 ===
              === DDARing 1 ===
              HTTP is idle in state(s) 0
              Q0 segments left 0, axes/extruders owned 0x80000003
              check 0 clear 0
              === CAN ===
              Messages queued 227, received 518, lost 0, ignored 0, errs 0, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 50 (min 50), ts 126/126/0
              Transfer state: 5, failed transfers: 3, checksum errors: 6
              RX/TX seq numbers: 41734/1414
              SPI underruns 4, overruns 4
              ok
                gloomyandy @Charlie
                @Charlie when the mcu resets RRF is able to capture (and store) some information about what was going on. Rather interestingly you seem to have had two on the face of it different resets the first was this:
                the second this:
                It sounds like the second reset may be the one caused by the phase stepping move with debug enabled, do you remember having any other sort of reset that may have generated the first case (looks like it was last night just before 9pm)?
                Either way hopefully @AndyE3D will be able to work out what may be happening here.
                Charlieundefined 1 Reply Last reply Reply Quote 1
                • Charlieundefined
                  Charlie @gloomyandy
                  @gloomyandy Thats really good to know. I appreciate that info!
                  Regarding the first crash, it could've either been the first attempt at capturing the debug data, me pulling the mains power in an attempt to "reset" the board, or something to do with me trying to connect to the board over YAT.
                  • Charlieundefined
                    Charlie
                    Also, I just want to note that for the Gcode Dictionary, for M970, .1, &.2, the "Example" code shows M917 instead of M970.
                    Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @Charlie
                      @Charlie said in 3.6.0-beta.1 Breaking Homing Sequence:
                      Something for @droftarts to take a look at.
                        droftarts administrators @Charlie
                        Thanks, fixed!
                        • Charlieundefined
                          Charlie @droftarts
                          @droftarts Thank you!
