    IR Sensor not triggering
    IR Height Sensor
    • andyundefined
      andy
      Hello
      I purchased the IR height sensor this week, however following the setup guide I cannot get the sensor to activate. It flashes twice after power up, but that is it.
      Its on a Duet 3 Mini 5+ WiFi on V3.5.4 firmware and setup as below
      M558 K0 P8 C"io3.in" ;
      G31 P50 X0 Y0 Z1.0 ;
      I am probably missing a step somewhere.
      Thanks in advance.
      Andy
        Have you seen this page?
        https://miscsolutions.wordpress.com/mini-height-sensor-board/
        Can you take a photo of your mounting as well as a close up of the board itself?
        andyundefined 1 Reply Last reply Reply Quote 0
        • andyundefined andy marked this topic as a question
        • andyundefined
          andy @Phaedrux
          @Phaedrux Yes I had gone through that as it was referenced in the docs,
          Pic attached of board, (ignore the funky angle as its all loose) No contact allowing a shrot circuit etc, but when i put any thing under I get no readout/flashing light. (white paper was suggested)
          Kind regards
          Andy
          • andyundefined
            andy @andy
            Found the issue, The IR LED thing by C1 is not attached properly.
            If i apply slight pressure top it, then it works as expected.
              droftarts administrators @andy
              @andy Sorry you have a broken IR probe. We are happy to replace the board under warranty, but also happy if it's just a soldering issue and you want to fix it yourself.
              If you would like to replace it under warranty, please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
