    Problem with Z Driver phase B
    • Woody78undefined
      Woody78
      Hi there,
      i´m using Duet 2 Wifi FW 3.5.3 on my hypercube setup.
      now when i home x axis (i drive first z a little bit down) become a warning: Driver 2 warning: phase B may be disconnected
      the bed doesn´t move and it´s very load on the z steppers, they are shaking...
      few hours ago it´s run normal. then i put the stepper out from the printer, change against other stepper, change back to the old stepper, and everything looks fine. i put the stepper back in the printer, and then works.
      after few hours with power off from the printer, i want to test something, first start G28 X and same again.
      i don´t know what can i do....
        jay_s_uk @Woody78
        @Woody78 that's usually a wiring issue. Check the crimps between the board and the motor and maybe install a new cable if the motor allows
        Woody78undefined 1 Reply Last reply Reply Quote 0
        • Woody78undefined
          Woody78 @jay_s_uk
          @jay_s_uk okay, thanks thats easy to make.
