    Scanning Z Probe Max points?
    • charliedrumsundefined
      charliedrums
      So I have a scanning z probe on a duet 3 6hc on FW 3.5.3. A bed that is 24 x 24in and I was wondering what is the maximum amount of points I can configure the probe to read? I have it set to 900 points. Can I go higher than 900?
      M557 X29:609 Y40:603 P30:30
      I was reading the wiki under M557 but it states "There is a firmware-dependent maximum number of probe points supported. Currently this is 441 for the Duet 2 and Duet 3 (enough for a 21x21 grid), and 121 on the Duet 06/085 (enough for a 11x11 grid)."
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @charliedrums
        @charliedrums IIRC the max number of points is something like 991 for the scanning probe. But if you set a much denser mesh, RRF will complain and tell you what the maximum number of points you are allowed anyway.
        @droftarts the max number of scanning points needs to be added to M557. I couldn't find it anywhere
          droftarts administrators @charliedrums
          @charliedrums It's 961 points on 6HC in RRF 3.5, ie a 31 x 31 grid. See https://docs.duet3d.com/User_manual/RepRapFirmware/RepRapFirmware_overview#firmware-configuration-limits
          You can also check by opening the 'Object Model' plugin in DWC, and checking the 'limits' section.
          @jay_s_uk I'll update M557.
          charliedrumsundefined 1 Reply Last reply Reply Quote 1
            charliedrums @droftarts
            @droftarts Thanks for the reply. I'll switch it to a 31x31 then.
