    RRF 3.6.0-beta2: www/DuetAPI.xml not found
    Firmware installation
    267
    • gloomyandyundefined
      gloomyandy @wschadow
      @wschadow Are you running in standalone or SBC mode?
      wschadowundefined 1 Reply Last reply Reply Quote 0
        droftarts administrators @wschadow
        @wschadow I noticed this and flagged it to @chrishamm, also the 'indent comments' button is missing. I thought he fixed it (the commit is here: https://github.com/Duet3D/DuetWebControl/commit/4532d03c157fa6059c2c37c7719d9911468f5791) but perhaps it didn't make it into the current release.
        Please can you make sure that DWC is updated to beta.2? Also whether SBC or standalone, as @gloomyandy says.
        0 chrishamm committed to Duet3D/DuetWebControl
        Brought back "Indent Comments" and "GCode Reference" buttons
          @wschadow They are definitely showing up in standalone mode:
          And DuetAPI.xml.gz is in the DuetWebControl-SD.zip.
          So I'm guessing you have an SBC setup, and something, probably DWC, hasn't updated.
          wschadowundefined 2 Replies Last reply Reply Quote 0
          • wschadowundefined
            wschadow @droftarts
            @droftarts running in standalone mode
            • wschadowundefined
              wschadow @droftarts
              • wschadowundefined
                wschadow @gloomyandy
                @gloomyandy standalone, see screenshots below
                  @wschadow Ah, yes, you're right, I'm seeing the same thing in the object browser. I do have /www/DuetAPI.xml (and the .gz version) on my SD card. @chrishamm is investigating.
                  • wschadowundefined
                    wschadow @droftarts
                    @droftarts indent comments is working
                    • chrishammundefined
                      chrishamm administrators @wschadow
                      @wschadow Thanks for reporting this. I've got a bug fix tested and working. Version 3.5 is not affected.
                      Duet software engineer
                      • wschadowundefined
                        wschadow @chrishamm
                        @chrishamm Thanks Christian. Thursday I'll be at formnext, maybe we see each other.
