    RRF 3.6.0-beta 2 tool fan controls disappear
    Beta Firmware
    • edspedundefined
      edsped
      With the beta 2 update I'm seeing tool fan controls disappear and the cooling fans run at 100% regardless of what is set by slicer. Restarting the printer corrects this problem for a while but after a print or two fan control is no longer available. This was not an issue with beta 1 and earlier 3.6.0 releases.
      Machine: Jubilee w/4 tools attached via RRF36
      Duet MB6HC
      All fully updated to 3.6.0 b2
      Fan controls as they should be
      Fan controls after a couple of prints...
      edspedundefined 1 Reply Last reply Reply Quote 0
      • edspedundefined
        edsped @edsped
        @edsped
        Config.g attached
        config (2).g
        • edspedundefined
          edsped
          Quick follow up... I may have found the root of it but it doesn't exactly make sense to me...
          I added the following to my "machine end g-code" remarking it out and fan control has remained visible through a few test runs.
          ;M106 P10 S127 T60 H1          ; turn all part cooling fans off after hotend is below 60C
          ;M106 P12 S127 T60 H2          ; turn all part cooling fans off after hotend is below 60C
          ;M106 P14 S127 T60 H3          ; turn all part cooling fans off after hotend is below 60C
          ;M106 P16 S127 T60 H4          ; turn all part cooling fans off after hotend is below 60C
          • edspedundefined
            edsped @edsped
            I guess setting the fans to thermal mode at the end of the print is a no no as the issue is now corrected. I'll chalk this up to user malfunction. Sorry all
            o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 2
            • o_lampeundefined
              o_lampe @edsped
              @edsped IMHO it wasn't false alarm.
              I guess, when you started a new print while the fans where still running in thermal mode, they disappeared?
              Although you reconfigured them to direct control at the start of the print?
              Or was it the other way round?
              Nevertheless, the fans (and DWC) should act the same in both scenarios.
                dc42 administrators @edsped
                @edsped fans set to thermostatic mode are not intended to be controlled by the user, so they do not appear in DWC.
                • edspedundefined
                  edsped @dc42
                  @dc42 said in RRF 3.6.0-beta 2 tool fan controls disappear:
                  Yeah, I assumed, wrongly of course, that I wouldn't need to revert the fans. Was definitely a brain fart on my end. I considered deleting the post but figured I should keep it up so maybe someone else could learn from my ignorance. Thanks for the follow up.
