    Jog Speed on Web Interface
    CNC
    • flopesundefined
      flopes
      Hi guys
      I changed the units on my laser cutter from mm to microns, once I am cutting very small parts.
      The system behaves well when running g-codes. However when jogging from the web interface, I reach a speed limit of about 1000 microns per minute (do not know exactly). The speeds and accelerations are set to go much faster than that and on G-code they run just fine. How can I increase the maximum speed at jog interface?!
      flopesundefined 1 Reply Last reply Reply Quote 0
      • flopesundefined
        flopes @flopes
          droftarts administrators @flopes
          @flopes Feedrate for move buttons (mm/min) is in the Settings > Machine-Specific > General > Machine-Specific
          • flopesundefined
            flopes @droftarts
            @droftarts Thank you very much
