    Accelerometer not found
    Using Duet Controllers
    • axiomundefined
      axiom
      have connected a duet accelerator V 0.2 to my duet 2 wifi dwc 3.4.6 and the control lamp is also green. Then I read that you should unplug the panel, which I did. But the accelerator is still not recognized. What is wrong? I have attached a few pictures!IMG_5340.jpg IMG_5341.jpg IMG_5342.jpg IMG_5343.jpg IMG_5344.jpg IMG_5345.jpg IMG_5346.jpg IMG_5347.jpg
        jay_s_uk @axiom
        @axiom you need 3.5 I think
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @jay_s_uk
          @jay_s_uk
          Thankj you.... I updated to 3.5.4, that wasn't the solution, it brings up the error message: macro line 87: Unknown pin name "spi.cs0"
            jay_s_uk @axiom
            @axiom can you post your whole config please?
            • axiomundefined
              axiom @jay_s_uk
              @jay_s_uk
              I'm happy, I took the code from the instructions...if the indicator light on the acelerator lights up green, couldn't it be the wiring?
              ; Configuration file for Duet WiFi (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun May 28 2023 15:23:44 GMT+0200 (Mitteleuropäische Sommerzeit)
              M575 P1 S1 B57600                              ; enable support for PanelDue
              G90                                            ; send absolute coordinates...
              M83                                            ; ...but relative extruder moves
              M550 P"DUKA1300"                               ; set printer name
              M552 S1                                        ; enable network
              M586 P0 S1                                     ; enable HTTP
              M586 P1 S1                                     ; enable FTP
              M586 P2 S1                                     ; enable Telnet
              ;M569 P4 R-1                                    ; Treiber 4 deaktivieren
              ;M569 P3 R-1                                    ; Treiber 4 deaktivieren
              M569 P0 S1                                      ; physical drive 0 goes forwards
              M569 P1 S1                                      ; physical drive 1 goes forwards
              M569 P2 S1                                      ; physical drive 2 goes forwards
              M569 P3 S1                                      ; physical drive 3 goes forwards
              M569 P4 S0                                      ; physical drive 3 goes forwards
              M569 P5 S1                                     ; physical drive 3 goes forwards Expansionboard
              M569 P6 S1                                     ; physical drive 3 goes forwards Expansionboard
              M569 P7 S1                                     ; physical drive 3 goes forwards Expansionboard
              M569 P8 S1                                     ; physical drive 3 goes forwards Expansionboard
              ;M584 X0 Z2 E1                                  ; set drive mapping
              ;M584 X0:4 Y1 Z2 E3                              ; set drive mapping
              M584 X0:4 Y1 Z5:6:7:8 E3                              ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                         ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z640 E322.58                  ; set steps per mm
              M566 X900.00 Y900.00 Z100.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z300.00 E1200.00         ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z40.00 E250.00             ; set accelerations (mm/s^2)
              M906 X1800 Y1800 Z1800 E1700 I30                ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                         ; Set idle timeout
              M208 X0 Y0 Z0 S1                                 ; set axis minima
              M208 X750 Y643 Z1220 S0                         ; set axis maxima
              M574 X1 S1 P"xstop + e0stop"        ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop"        ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M574 Z1 S2 ;S1 P"duex.e2stop+duex.e3stop+duex.e4stop+duex.e5stop"                                  ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M558 K0 P5 C"!zprobe.in" H5 F120 T6000           ; set Z probe type to unmodulated and the dive height + speeds (Kapazitiver Sensor)
              M558 K1 P8 A2 S7 C"duex.e6stop" H5 F80 T3000
              G31 P1000 K0 X0 Y-25 Z0.9  ; set Z probe trigger value, offset and trigger height (Kapazitiver Sensor)
              M557 X0:735 Y-25:573 S35                        ; define mesh grid
              ; Bed
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138              ; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bedheat" T0                                       ; create bed heater output on bedheat and map it to sensor 0
              M307 H0 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0            ; enable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                                     ; map heated bed to heater 0
              M143 H0 S280                                                ; set temperature limit for heater 0 to 120C
              ;Hotend
              M308 S1 P"e0temp" Y"thermistor" T100000 B4138            ; configure sensor 1 as thermistor on pin e0temp
              M950 H1 C"e0heat" T1                                     ; create nozzle heater output on e0heat and map it to sensor 1
              M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8   ; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S400                                             ; set temperature limit for heater 1 to 400C
              M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1                                ; set fan 0 value. Thermostatic control is turned off
              M950 F2 C"fan1" Q350                          ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H1 T60                             ; set fan 2 value. Thermostatic control is turned on
              M563 P0 D0 H1 F0                               ; define tool 1
              G10 P0 X0 Y0 Z0                                ; set tool 1 axis offsets
              G10 P0 R0 S0                                   ; set initial tool 1 active and standby temperatures to 0C
              ; Filamentsensor
              M591 D0 P1 C"e1stop" S1                      ;R40:120 E3.0 S1  Filament Sensor
              ;Inputshaper/Accelarator
              M955 P0 C"spi.cs1+spi.cs0" I10 ; configure accelerometer on mainboard using SPI pins and specify orientation
              ;Auto Z-Offset
              M501
                jay_s_uk @axiom
                @axiom you should be using
                M955 P0 C"spi.cs2+spi.cs1"
                The line you have is for the 6HC
                axiomundefined 1 Reply Last reply Reply Quote 2
                • axiomundefined
                  axiom @jay_s_uk
                  @jay_s_uk
                  wow, thank you so much! That was the solution, now I just have to figure out the input shaping....have a nice Sunday, cheers, Don
