M280: Probe already triggered at start of probing move BLTouch
Hi, i have been given a printer which is awesome, but it was on a very old firmware.
I've got everything on 3.5.4 (wifi 2.2.0) but i had to rebuild the sd card from scratch.
I havn't touched the cabling and i printed a benchy which was acceptable before i changed anything.
It has a bltouch which i observed working.
Now in the new config when i try to home z i get the errorG30 Error: M280: Probe already triggered at start of probing move sending g31 gets me
G31 Z probe 0: current reading 1000, threshold 500, trigger height 2.200, offsets X-19.7 Y-8.4 The original config.g had this as the bltouch section
; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds G31 P500 X-19.7 Y-8.4 Z2.2 ; Set Z probe trigger value, offset and trigger height M557 X20:190 Y15:190 S60 ; Define mesh grid and this is the new one
; Probes M558 K0 P9 C"^exp.thermistor6" H5 F120 T6000 ; configure BLTouch probe via slot #0 G31 P500 X-19.7 Y-8.4 Z2.2 ; set Z probe trigger value, offset and trigger height M950 S0 C"exp.heater7" ; create servo #0 for BLtouch I haven't changed the wiring, i'm using Pin 31 HEATER7 on the expansion slot
The file for deployprobe0.g says; deployprobe0.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.5.8 on Sun Dec 29 2024 16:23:01 GMT+1100 (Australian Eastern Daylight Time) M280 P0 S10 ; deploy BLTouch M401 and M402 deploy and retract the probe successfully.
any ideas? -
ok, chatgpt helped me get the right gcode, and it helped that it turns out i have a 5 wire bltoush not a three wire one.
; Z-Probe Configuration M950 S0 C"exp.heater7" ; Assign Heater7 (pin 31) for BLTouch control M558 P9 C"zprobe.in" H5 F120 T6000 ; Configure Z-Probe signal pin G31 P500 X-19.7 Y-8.4 Z2.2 ; Set trigger value, offsets, and trigger height M574 Z1 S2 ; Set Z endstop controlled by the probe the bed isn't stopping in testing, but no more errors when trying to home so i'm marking this one as solved.
ok, i've got a bit further, i had the wrong pin which didn't help.
It should be pin 31 which is heater 7.
and it is a 3 wire harness i think. so i changed it to; Probes M950 S0 C"exp.heater7" ; Assign Heater7 as the control pin for BLTouch M558 K0 P9 C"^exp.heater7" H5 F120 T6000 ; Configure BLTouch probe, using Heater7 for signal G31 P500 X-19.7 Y-8.4 Z2.2 ; Set trigger value, offsets, and trigger height but now i'm getting pin exp.heater7 is not free
error invalid z probe indexi'm going to go triple check that i have a three wire system.
@magnets99 said in M280: Probe already triggered at start of probing move BLTouch:
The probe is only used when you send G30. It won't work on a normal G1 H1 homing move. So make sure your homing files are correct for using a probe.
@Phaedrux
Thanks, in the end there was lots wrong, i'm not sure how i got it so wrong to start with.
original:; Probes M558 K0 P9 C"^exp.thermistor6" H5 F120 T6000 ; configure BLTouch probe via slot #0 G31 P500 X-19.7 Y-8.4 Z2.2 ; set Z probe trigger value, offset and trigger height M950 S0 C"exp.heater7" ; create servo #0 for BLtouch Final fixed one:
; Z-Probe Configuration M950 S0 C"exp.heater7" ; Assign Heater7 (pin 31) for BLTouch control M558 P9 C"^zprobe.in" H5 F120 T6000 ; Configure Z-Probe signal pin G31 P500 X-19.7 Y-8.4 Z2.2 ; Set trigger value, offsets, and trigger height M574 Z1 S2 ; Set Z endstop controlled by the probe Issues were (as i went along):
assumed 3 wire config not 5 wire.
wrong pin for sensor
missing ^ (pullup) on zprobe.inI actually found chatGPT pretty good for getting me to check stuff, it seems to know rrf 3+ pretty good.
Definitely double check anything it gives you against the actual gcode dictionary. Last time I looked at it, it started to make stuff up very quickly.
@Phaedrux
I think because i was doing basic stuff it was ok, but yes, it did get a few things wrong:*3. Test Manual Pin Movement
Manually deploy the probe pin and push it gently into the housing while sending:gcode
Copy code
M119
If the probe doesn't register as triggered when pushed, the issue may be:
A wiring problem.
A faulty BLTouch.
A configuration issue with the signal pin.*Which would be good advice if i was using it as an end stop, but i wasn't.
But got me looking at the wiring...
