    MFM_enclosureV3.scad to .step/.f3d: issues
    Filament Monitor
    • TheTurboGuyundefined
      TheTurboGuy
      Wish you all a happy new year!
      For the integration of the MFM in a bracket I'd favour an editible object in fusion360.
      Is the MFM_enclosurev3_release.scad https:// github
      .com/Duet3D/FilamentMonitors/blob/master/Filament_Monitor_Magnetic/version3/enclosure/MFM_enclosurev3_release.scad as provided in the github available as .step/.stp or f3d?
      I tried to convert it myself according to this procedure: https://
      forums.autodesk .com/t5/fusion-manage-ideas/how-to-import-openscad-file-into-fusion360-as-a-solid-body/idi-p/10174834.
      This workflow does not work for the hull structure of the MFM enclosure, but it works a charm for basic geometric bodies like for this example https://
      wiki.freecad .org/Import_OpenSCAD_code.
      Regards, Fabian
      PS: sorry for the spaces in the links, I'm not allowed to post links.
      T3P3Tonyundefined droftartsundefined 2 Replies Last reply Reply Quote 2
      • T3P3Tonyundefined
        T3P3Tony administrators @TheTurboGuy
        @TheTurboGuy not sure what the issue is with import to fusion. You could try opening the scad file in freecad?
        www.duet3d.com
          droftarts administrators @TheTurboGuy
          @TheTurboGuy FreeCAD doesn't like the Hull command, I think. You can import the .stl files into Fusion 360 directly, then follow a tutorial to convert the mesh to solid body. I've done this plenty of times when needing to adjust models from Printables/Thingiverse et al.
          • oliofundefined
            oliof
            its probably easier, faster, and will garner a better file if one were to remodel in fusion from the reference openscad model. I personally think its great to have the reference files in an open, almost human readable format (I cant run fusion, but I can run OpenSCAD on a tomato class computer if the need be).
