    speed of bed leveling
    Using Duet Controllers
    • axiomundefined
      axiom
      How can I increase the speed of my bed leveling (G29).
      dc42undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @axiom
        @axiom use a scanning Z probe, if the bed surface is compatible.
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @dc42
          @dc42 Can't you adjust the speed somehow in g-code or in the macro?
          dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
          • oliofundefined
            oliof
            Besides scanning probes, ypu can also consider ways to reduce the dependency on bed probing:
            • build a bed mount that allows for expansion at temp without warping (maxwell / kinematic mount)
            • build a machine with a fixed bed (delta / raising gantry which can be trammed with simple endstops)
            • use a bed with high thermal mass and a low coefficient of thermal expansion
              @axiom yes you can change the speed in the M558 command that defines the probe. For conventional probing you can also reduce the dive height.
                jay_s_uk @axiom
                @axiom maybe provide more information with your question rather than just something generic
                  droftarts administrators @axiom
                  @axiom only create a bed mesh of the area of the print: https://forum.duet3d.com/topic/37242/mesh-bed-leveling-only-in-printing-area-using-orca-slicer
