    U axis and G3...Error:Intermediate Position outside machine...
    • FBGundefined
      FBG
      Duet3 HC and Duet 3 6XD. all version are in 3.5.1
      I am working in a IDEX printer that have in the same gantry X axis and U axis, T0 and T1.
      If i work with "Arcs commands" G2/G3 everything is perfect if i use T0 and the gcode you can read X command...
      But the same file, working with T1 and of course the gcode have U letter instead of X letter, Console give me and error
      Error: G3: Intermediate Position outside machine limits
      If i disable "arcs commands" all work perfectly of course.
      Is like the U axis don't support arc G2 and G3
      Any idea?
      Best Regards
        droftarts administrators @FBG
        @FBG As far as I know, no, you can't use G2/G3 with a U parameter for a U axis, only XYZ. Is your IDEX using U, rather than mapping U to X, which is the more normal way to set up an IDEX? See M563 X parameter: https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_IDEX#configuring-tools
        FBGundefined 2 Replies Last reply Reply Quote 0
        • FBGundefined
          FBG @droftarts
          @droftarts Thanks, is good idea, I will try some test as you say.
          Best Regards
          • FBGundefined
            FBG @droftarts
            @droftarts Sorry for my delay, i tested with X3 code but equal...same error...
            Any idea
              @FBG If you're still on 3.5.1, please update to 3.5.4: https://github.com/Duet3D/RepRapFirmware/releases/latest
              Please post your config.g so we can check it. Also the response to M122.
