    SBC RPI4 Bookworm 3.5.4 Disable Chrome Startup
    • tmreithundefined
      tmreith
      On previous DuetPi images to disable the chrome startup the autostart file would be modified by removing the @launch-dwc entry. /etc/xdg/lxsession/LXDE-pi/autostart
      Using the new build with Bookworm, how do I disable the chrome startup on the pi?
      • chrishammundefined
        chrishamm administrators @tmreith
        @tmreith It's either in ~/.config/wayfire.ini or ~/.config/labwc/autostart.
        Duet software engineer
        tmreithundefined 1 Reply Last reply Reply Quote 0
        • tmreithundefined
          tmreith @chrishamm
          @chrishamm works great! Thanks for the insight.
          Below is an excellent guide for more detail.
          https://github.com/thagrol/Guides/blob/main/bookworm.pdf
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
          • stuartofmtundefined
            stuartofmt @tmreith
            For anyone stumbling across this ...
            Looks like the correct file to edit is ~/.config/labwc/autostart
            Just comment out the line with launch-dwc &
            # Start DWC on boot
            # launch-dwc &
            • davidjryanundefined davidjryan referenced this topic
