    X axis not at zero when at home
    • Chris Sundefined
      Chris S
      Hay everyone so got a Ender 6 modded out with a duet wifi 2 and when I home the printer it shows that the x axis is 215.0 out and not zero got the stock end stops Y shows zero and can't find where to change it any help would be great thanks.
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Chris S
        @Chris-S
        M574 defines whether you're homing to the low or high end.
        It sounds like you're homing to the high end, so the value when the stop triggers should be max travel as set by M208
        You'd need to post your config.g so that it can be examined properly.
        Chris Sundefined 1 Reply Last reply Reply Quote 0
          Also please post your homing files.
          • Chris Sundefined
            Chris S @OwenD
            @OwenD
            Thanks for the help it was on the high end fixed it appreciate your time it was frustrating me thank you so much.
            • T3P3Tonyundefined T3P3Tony marked this topic as a question
            • T3P3Tonyundefined T3P3Tony has marked this topic as solved
