    [Bug / Feature Request]: negative temperatures in chart
    Duet Web Control wishlist
    • pixelpieperundefined
      pixelpieper
      I am using a Duet board as a temperature controller for a measurement setup, using a peltier element for subzero temperatures. Unfortunately the temperature chart in DWC doesn't scale down to negative temperatures right now:
      My proposal would be to extend the lowest temperature down to either
      min(0, min(active_tooltemp_list),min(active_bedtemp_list),min(active_chambertemp_list))
      or
      min(0, active_tool_temperature,active_bed_temperature, active_chamber_tamperature)
      This keeps the behavior as is for normal users while extending the chart down if required.
      Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
      Voron V0.250 / Duet 2 Maestro
      oliofundefined chrishammundefined 2 Replies Last reply Reply Quote 1
      • oliofundefined
        oliof @pixelpieper
        @pixelpieper maybe check the BtnCmd plugin for a customized UI and temp chart
        • chrishammundefined
          chrishamm administrators @pixelpieper
          @pixelpieper I'm going to adjust the minimum of the temperature chart dynamically in the next build. It will be the lowest value of the configured temperature presets or heaters[].min.
          Duet software engineer
