TWO WiFi address
I think I know the answer but thought I'd confirm my thoughts first.
We are changing our internet supplier and i hoped I can send the new WiFi router address & password using the old router address?
This assumes I'm present when the change over happens and/or the old router is left behind!From what I've read it seems that I can scan for any WiFi, but it seems to need the WiFi off during the up-dating, then connect with a cable via USB & YATT on the PC?
So this is 'hope' maybe more than anything . . . .
@Bridge-Of-Don you could send your new wifi credentials using M587 to the wifi module before you disconnect the old wifi. then when you turn the new wifi on it should just connect to that
@jay_s_uk
OK, I'll try that, sods law will mean that I'm away on holidays when it gets changed over My worry was this bit on Configuring Network in the Commissioning section . . . .
It is the local 'Men's Shed' so a communal area for like minded blokes to have a news, natter , no knittingPS thanks for super swift reply
@Bridge-Of-Don you can connect over USB and send the command to connect to the new wifi otherwise.
@T3P3Tony said in TWO WiFi address:
Aye, I assumed I could do that, but wanted to avoid the USB option as it was flakey when we were initially setting it up!!!
