    [3.6.0-beta3] Duet2 WIFI SPI timeout
    Beta Firmware
    565
    • timschneiderundefined
      timschneider
      This is a split of the thread https://forum.duet3d.com/topic/37322/3-6-0-beta-3-dwc-connection-issues-duet2-duex5
      too keep both bugs, long response and WIFI SPI timeout seperated.
      It is related to https://github.com/Duet3D/RepRapFirmware/issues/1073#issuecomment-2621298665
      Printer was idle with one open session.
      Error: failed to retrieve WiFi status message: SPI timeout<\n>
      === Diagnostics ===<\n>
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-beta.3+4 (2025-02-05 09:48:00) running on Duet WiFi 1.02 or later + DueX5v0.11<\n>
      Board ID: 08DJM-9178L-L4MSJ-6J1FL-3S86J-TB2LN<\n>
      Used output buffers: 1 of 26 (21 max)<\n>
      === RTOS ===<\n>
      Static ram: 23776<\n>
      Dynamic ram: 69864 of which 0 recycled<\n>
      Never used RAM 25444, free system stack 130 words<\n>
      Tasks: NETWORK(1,nWait 6,10.1%,211) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,264) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,89.0%,698) IDLE(0,ready,0.8%,29), total 100.0%<\n>
      Owned mutexes: WiFi(NETWORK) USB(MAIN)<\n>
      === Platform ===<\n>
      Last reset 24:55:18 ago, cause: power up<\n>
      Last software reset at 2025-02-03 20:56, reason: User, Gcodes spinning, available RAM 24764, slot 1<\n>
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a<\n>
      Error status: 0x00<\n>
      MCU temperature: min 26.2, current 29.5, max 30.4<\n>
      Supply voltage: min 23.7, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes<\n>
      Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/256/120, gc cycles 4227<\n>
      Events: 0 queued, 0 completed<\n>
      Date/time: 1970-01-01 00:00:00<\n>
      Slowest loop: 202.01ms; fastest: 0.12ms<\n>
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0<\n>
      === Storage ===<\n>
      Free file entries: 9<\n>
      SD card 0 detected, interface speed: 20.0MBytes/sec<\n>
      SD card longest read time 28.9ms, write time 101.0ms, max retries 0<\n>
      === Move ===<\n>
      Segments created 38, maxWait 41665760ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00<\n>
      Pos req/act/dcf: 40320.00/40320/-0.00 -24320.00/-24320/-0.00 400.00/400/0.00<\n>
      no step interrupt scheduled<\n>
      Driver 0: standstill, SG min 177<\n>
      Driver 1: standstill, SG min 167<\n>
      Driver 2: standstill, SG min n/a<\n>
      Driver 3: standstill, SG min n/a<\n>
      Driver 4: standstill, SG min n/a<\n>
      Driver 5: standstill, SG min n/a<\n>
      Driver 6: standstill, SG min n/a<\n>
      Driver 7: standstill, SG min n/a<\n>
      Driver 8: standstill, SG min n/a<\n>
      Driver 9: standstill, SG min n/a<\n>
      Driver 10: <\n>
      Driver 11: <\n>
      === DDARing 0 ===<\n>
      Scheduled moves 15, completed 15, LaErrors 0, Underruns [0, 0, 0]<\n>
      Segments left 0<\n>
      Code queue is empty<\n>
      === Heat ===<\n>
      Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0<\n>
      === GCodes ===<\n>
      Movement locks held by null<\n>
      HTTP is idle in state(s) 0 0 0 0<\n>
      Telnet is idle in state(s) 0<\n>
      File is idle in state(s) 0<\n>
      USB is ready with "M122" in state(s) 0<\n>
      Aux is idle in state(s) 0<\n>
      Trigger is idle in state(s) 0<\n>
      Queue is idle in state(s) 0<\n>
      LCD is idle in state(s) 0<\n>
      Daemon is idle in state(s) 0<\n>
      Autopause is idle in state(s) 0<\n>
      === Filament sensors ===<\n>
      check 0 clear 319057472<\n>
      Extruder 0: pos 2160.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0<\n>
      === DueX ===<\n>
      Read count 1, 0.00 reads/min<\n>
      === Network ===<\n>
      Slowest loop: 201.38ms; fastest: 0.00ms<\n>
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)<\n>
      HTTP sessions: 0 of 8<\n>
      === WiFi ===<\n>
      Interface state: active<\n>
      Module is connected to access point <\n>
      Failed messages: pending 0, notrdy 5, noresp 261465<\n>
      Failed to get WiFi status<\n>
      Socket states: 0 0 0 6 0 0 0 0<\n>
      ok<\n>
      I was able to reset the WIFI module via USB with
      M552 S-1
      M552 S0
      M552 S1
      WiFi module stopped<\n>
      ok<\n>
      ok<\n>
      WiFi module started<\n>
      === RTOS ===<\n>
      Tasks: NETWORK(1,ready,0.9%,211) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,264) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,97.5%,698) IDLE(0,ready,1.5%,29), total 100.0%<\n>
      Owned mutexes: USB(MAIN)<\n>
      Last reset 24:57:54 ago, cause: power up<\n>
      MCU temperature: min 28.7, current 29.7, max 30.2<\n>
      Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes<\n>
      Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1164/1028, gc cycles 4234<\n>
      Slowest loop: 99.34ms; fastest: 0.22ms<\n>
      === Storage ===<\n>
      SD card longest read time 2.3ms, write time 4.7ms, max retries 0<\n>
      === Move ===<\n>
      Segments created 38, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00<\n>
      Driver 0: standstill, SG min n/a<\n>
      Driver 1: standstill, SG min n/a<\n>
      Driver 10: <\n>
      Driver 11: <\n>
      Segments left 0<\n>
      === Heat ===<\n>
      === GCodes ===<\n>
      check 0 clear 319632530<\n>
      === DueX ===<\n>
      Read count 0, 0.00 reads/min<\n>
      === Network ===<\n>
      Slowest loop: 200.20ms; fastest: 0.00ms<\n>
      === WiFi ===<\n>
      Interface state: idle<\n>
      Module is idle<\n>
      Failed messages: pending 0, notrdy 0, noresp 0<\n>
      Firmware version 2.2.1<\n>
      MAC address 00:00:00:00:00:00<\n>
      Module reset reason: Turned on by main processor, Vcc 3.47, flash size 4194304, free heap 53932<\n>
      Clock register 00002002<\n>
      ok<\n>
      ok<\n>
      WiFi module is connected to access point Meltingplot, IP address 10.42.0.2<\n>
      From the old thread
      HTTP req, command words { GET /rr_gcode HTTP/1.0 }, parameters { gcode=M122 }<\n>
      Sending JSON reply, length 12<\n>
      ResponseTimeout, pending=1<\n>
      ResponseBusy<\n>
      Bad recv status size<\n>
      WiFi: ˆ�n�P<24>|�!�-�1Ë�5‹Ðšö›X�%�ú~�)Q*!Ë�è "X*�<7>�í�×�v�'�áêI*�1�T�,�,�)�)DÐ�b9�)�5~�/�<9>�øn�z�A[�a�øºv�<5>¬�<9>�H~�1�hqh�5�5~�9<1>�êt�l�-�§�X�1�¨Y+�5�%�ûþ�<5>1�<11>�<9>�ˆò�A,�<9>�8øºö�<5>1�R�d�!y(�!�‡�z�A‹�ëy¨�%�!y¨�1�R·�v�-<\n>
      ESP reported status change<\n>
      ResponseBusy<\n>
      WiFi: �)�)DP‹�­@íy*�-�<9>�øn�z�Aì )ií�§�P�m�N8r�fP�m�Nøphy_version: 1163.0, 665d56c, Jun 24 2020, 10:00:08, RTOS new<\n>
      ResponseBusy<\n>
      Error: failed to retrieve WiFi status message: another SPI transfer is pending<\n>
      ResponseBusy<\n>
      ResponseBusy<\n>
      chrishamm created this issue in Duet3D/RepRapFirmware
      closed [Bug]: Long G-code replies can crash WiFi boards in standalone mode #1073
      • chrishammundefined
        chrishamm administrators @timschneider
        @timschneider Thanks, I've logged this one at https://github.com/Duet3D/WiFiSocketServerRTOS/issues/50
        chrishamm created this issue in Duet3D/WiFiSocketServerRTOS
        open [Bug]: Duet2 WIFI SPI timeout #50
        Duet software engineer
        timschneiderundefined 1 Reply Last reply Reply Quote 1
          timschneider @chrishamm
          @chrishamm
          today, the error appeared a little diffent no spamming of Error: failed to retrieve WiFi status message: SPI timeout<\n> in console instead a proper error message in the output of M122
          === RTOS ===<\n>
          Dynamic ram: 68336 of which 0 recycled<\n>
          Never used RAM 27884, free system stack 172 words<\n>
          Tasks: NETWORK(1,nWait 6,15.2%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,83.6%,692) IDLE(0,ready,1.1%,29), total 100.0%<\n>
          Last reset 20:16:44 ago, cause: software<\n>
          Last software reset at 2025-02-07 14:18, reason: User, Gcodes spinning, available RAM 25444, slot 2<\n>
          MCU temperature: min 28.5, current 29.4, max 30.5<\n>
          Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes<\n>
          Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1316/1180, gc cycles 3395<\n>
          Date/time: 2025-02-08 10:34:46<\n>
          Slowest loop: 11.48ms; fastest: 0.21ms<\n>
          === Storage ===<\n>
          Free file entries: 8<\n>
          SD card longest read time 8.8ms, write time 0.0ms, max retries 0<\n>
          === Move ===<\n>
          Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00<\n>
          Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00<\n>
          Driver 10: <\n>
          Driver 11: <\n>
          Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]<\n>
          Segments left 0<\n>
          === Heat ===<\n>
          === GCodes ===<\n>
          HTTP is idle in state(s) 0<\n>
          Daemon is doing "G4 P100" in state(s) 0 0, running macro<\n>
          check 0 clear 247744131<\n>
          === DueX ===<\n>
          === Network ===<\n>
          Slowest loop: 210.96ms; fastest: 0.07ms<\n>
          === WiFi ===<\n>
          Failed messages: pending 0, notrdy 0, noresp 208248<\n>
          Socket states: 0 6 0 0 0 0 0 0<\n>
          ok<\n>
          But weird things started after changing the WIFI Module state again with
          M552 S-1
          M552 S0
          M552 S1
          ok<\n>
          ok<\n>
          ok<\n>
          === RTOS ===<\n>
          Tasks: NETWORK(1,ready,0.9%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,97.7%,692) IDLE(0,ready,1.4%,29), total 100.0%<\n>
          Last reset 20:18:00 ago, cause: software<\n>
          MCU temperature: min 29.0, current 29.6, max 30.1<\n>
          Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes<\n>
          Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/596/460, gc cycles 3399<\n>
          Date/time: 2025-02-08 10:36:03<\n>
          Slowest loop: 100.04ms; fastest: 0.21ms<\n>
          === Storage ===<\n>
          SD card longest read time 2.2ms, write time 0.8ms, max retries 0<\n>
          === Move ===<\n>
          Driver 10: <\n>
          Driver 11: <\n>
          Segments left 0<\n>
          === Heat ===<\n>
          === GCodes ===<\n>
          check 0 clear 248049807<\n>
          === DueX ===<\n>
          === Network ===<\n>
          Slowest loop: 200.10ms; fastest: 0.00ms<\n>
          === WiFi ===<\n>
          Module is idle<\n>
          Module reset reason: Turned on by main processor, Vcc 3.46, flash size 4194304, free heap 53932<\n>
          ok<\n>
          === RTOS ===<\n>
          Never used RAM 27884, free system stack 170 words<\n>
          Tasks: NETWORK(1,ready,7.1%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,92.8%,692) IDLE(0,ready,0.0%,29), total 100.0%<\n>
          Last reset 20:18:18 ago, cause: software<\n>
          MCU temperature: min 29.4, current 29.5, max 30.1<\n>
          Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes<\n>
          Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/624/488, gc cycles 3400<\n>
          Date/time: 2025-02-08 10:36:20<\n>
          Slowest loop: 2.95ms; fastest: 0.21ms<\n>
          === Storage ===<\n>
          SD card longest read time 2.2ms, write time 0.0ms, max retries 0<\n>
          === Move ===<\n>
          Driver 10: <\n>
          Driver 11: <\n>
          Segments left 0<\n>
          === Heat ===<\n>
          === GCodes ===<\n>
          check 0 clear 248114856<\n>
          === DueX ===<\n>
          === Network ===<\n>
          Slowest loop: 0.33ms; fastest: 0.00ms<\n>
          === WiFi ===<\n>
          Module is idle<\n>
          ok<\n>
          ok<\n>
          === RTOS ===<\n>
          Tasks: NETWORK(1,ready,6.3%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,93.6%,692) IDLE(0,ready,0.0%,29), total 100.0%<\n>
          Last reset 20:18:29 ago, cause: software<\n>
          MCU temperature: min 28.9, current 29.0, max 29.7<\n>
          Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes<\n>
          Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/804/668, gc cycles 3400<\n>
          Date/time: 2025-02-08 10:36:32<\n>
          Slowest loop: 2.96ms; fastest: 0.21ms<\n>
          === Storage ===<\n>
          === Move ===<\n>
          Driver 10: <\n>
          Driver 11: <\n>
          Segments left 0<\n>
          === Heat ===<\n>
          === GCodes ===<\n>
          check 0 clear 248160411<\n>
          === DueX ===<\n>
          === Network ===<\n>
          Slowest loop: 0.29ms; fastest: 0.00ms<\n>
          === WiFi ===<\n>
          Interface state: changingMode<\n>
          Module is trying to connect<\n>
          Module reset reason: Turned on by main processor, Vcc 3.46, flash size 4194304, free heap 47360<\n>
          ok<\n>
          === RTOS ===<\n>
          Tasks: NETWORK(1,ready,7.5%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,92.4%,692) IDLE(0,ready,0.0%,29), total 100.0%<\n>
          Last reset 20:18:31 ago, cause: software<\n>
          MCU temperature: min 28.8, current 29.0, max 29.2<\n>
          Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes<\n>
          Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1144/1008, gc cycles 3400<\n>
          Date/time: 2025-02-08 10:36:34<\n>
          Slowest loop: 2.39ms; fastest: 0.23ms<\n>
          === Storage ===<\n>
          SD card longest read time 2.1ms, write time 0.0ms, max retries 0<\n>
          === Move ===<\n>
          Driver 10: <\n>
          Driver 11: <\n>
          Segments left 0<\n>
          === Heat ===<\n>
          === GCodes ===<\n>
          check 0 clear 248167507<\n>
          === DueX ===<\n>
          === Network ===<\n>
          Slowest loop: 0.26ms; fastest: 0.00ms<\n>
          === WiFi ===<\n>
          Module reset reason: Turned on by main processor, Vcc 3.46, flash size 4194304, free heap 47380<\n>
          ok<\n>
          Error: WiFi module reported: Authentication failed<\n>
          WiFi module is idle<\n>
          Hope this helps to track that bug down 🙂
            timschneider
            === RTOS ===<\n>
            Last reset 20:18:32 ago, cause: software<\n>
            MCU temperature: min 28.9, current 29.1, max 29.3<\n>
            Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1344/1208, gc cycles 3400<\n>
            Date/time: 2025-02-08 10:36:35<\n>
            Slowest loop: 2.41ms; fastest: 0.21ms<\n>
            === Storage ===<\n>
            SD card longest read time 2.1ms, write time 0.9ms, max retries 0<\n>
            === Move ===<\n>
            Driver 10: <\n>
            Driver 11: <\n>
            Segments left 0<\n>
            === Heat ===<\n>
            === GCodes ===<\n>
            check 0 clear 248171978<\n>
            === DueX ===<\n>
            === Network ===<\n>
            Slowest loop: 3.65ms; fastest: 0.00ms<\n>
            === WiFi ===<\n>
            Module is idle<\n>
            ok<\n>
            Error: failed to change WiFi mode: SPI timeout<\n>
            === RTOS ===<\n>
            Tasks: NETWORK(1,ready,7.2%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,92.7%,692) IDLE(0,ready,0.0%,29), total 100.0%<\n>
            Last reset 20:19:27 ago, cause: software<\n>
            MCU temperature: min 28.7, current 28.9, max 29.5<\n>
            Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1116/980, gc cycles 3403<\n>
            Date/time: 2025-02-08 10:37:30<\n>
            Slowest loop: 3.15ms; fastest: 0.21ms<\n>
            === Storage ===<\n>
            SD card longest read time 2.3ms, write time 2.6ms, max retries 0<\n>
            === Move ===<\n>
            Driver 10: <\n>
            Driver 11: <\n>
            Segments left 0<\n>
            === Heat ===<\n>
            === GCodes ===<\n>
            check 0 clear 248378409<\n>
            === DueX ===<\n>
            === Network ===<\n>
            Slowest loop: 102.55ms; fastest: 0.00ms<\n>
            === WiFi ===<\n>
            Interface state: disabled<\n>
            Module is disabled<\n>
            Failed messages: pending 0, notrdy 0, noresp 3<\n>
            ok<\n>
            ok<\n>
            ok<\n>
            ok<\n>
            WiFi module is connected to access point Meltingplot_A1_539,3, IP address 10.42.0.2<\n>
            === RTOS ===<\n>
            Tasks: NETWORK(1,ready,8.0%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,91.7%,692) IDLE(0,ready,0.1%,29), total 100.0%<\n>
            Last reset 20:20:30 ago, cause: software<\n>
            MCU temperature: min 28.6, current 29.1, max 29.4<\n>
            Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/764/628, gc cycles 3406<\n>
            Date/time: 2025-02-08 10:38:32<\n>
            Slowest loop: 99.79ms; fastest: 0.20ms<\n>
            === Storage ===<\n>
            SD card longest read time 2.3ms, write time 4.1ms, max retries 0<\n>
            === Move ===<\n>
            Driver 10: <\n>
            Driver 11: <\n>
            Segments left 0<\n>
            === Heat ===<\n>
            === GCodes ===<\n>
            check 0 clear 248611287<\n>
            === DueX ===<\n>
            === Network ===<\n>
            Slowest loop: 25.22ms; fastest: 0.00ms<\n>
            HTTP sessions: 2 of 8<\n>
            === WiFi ===<\n>
            MAC address bc:dd:c2:31:9a:40<\n>
            Module reset reason: Turned on by main processor, Vcc 3.46, flash size 4194304, free heap 43088<\n>
            WiFi IP address 10.42.0.2<\n>
            Signal strength -21dBm, channel 11, mode 802.11n, reconnections 0<\n>
            Socket states: 0 0 0 0 0 0 0 0<\n>
            ok<\n>
              timschneider
              I'm almost certian that it is some sort of use-after-free bug.
              I got the following responses with the command M111 M122
              Debugging on for modules:
              Debugging off for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) Debug(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) SbcInterface(16) CAN(17) Expansion(18)
              Used output buffers: 2 of 26 (26 max)
              Static ram: 23776
              Never used RAM 27884, free system stack 164 words
              Tasks: NETWORK(1,ready,32.3%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,66.3%,692) IDLE(0,ready,1.4%,29), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 23:01:56 ago, cause: software
              Error status: 0x04
              MCU temperature: min 29.0, current 29.1, max 29.4
              Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1204/1068, gc cycles 3854
              Date/time: 2025-02-08 13:19:58
              Slowest loop: 8.41ms; fastest: 0.22ms
              === Storage ===
              SD card longest read time 2.4ms, write time 0.0ms, max retries 0
              Driver 10:
              Driver 11:
              === DDARing 0 ===
              Segments left 0
              Code queue is empty
              HTTP is ready with "M122" in state(s) 0
              USB is idle in state(s) 0
              check 0 clear 281113629
              === DueX ===
              === Network ===
              Slowest loop: 21.88ms; fastest: 0.07ms
              HTTP sessions: 3 of 8
              === WiFi ===
              Module reset reason: Turned on by main processor, Vcc 3.45, flash size 4194304, free heap 42524
              Signal strength -19dBm, channel 11, mode 802.11n, reconnections 0
              Static ram: 23776
              Tasks: NETWORK(1,ready,44.7%,217) HEAT(3,nWait 5,0.1%,283) Move(4,nWait 5,0.0%,361) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,53.8%,692) IDLE(0,ready,1.4%,29), total 100.0%
              Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
              Last reset 23:01:58 ago, cause: software
              Error status: 0x04
              MCU temperature: min 28.9, current 29.3, max 29.4
              Supply voltage: min 23.9, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/7, heap memory allocated/used/recyclable 2048/1424/1288, gc cycles 3854
              Date/time: 2025-02-08 13:20:00
              Slowest loop: 7.44ms; fastest: 0.23ms
              === Storage ===
              SD card longest read time 2.6ms, write time 0.0ms, max retries 0
              Sedded 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 0.00/0/0.gments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Driver 10:
              Driver 11:
              === DDARing 0 ===
              Segments left 0
              Code queue is empty
              check 0 clear 281117052
              === DueX ===
              === Network ===
              Slowest loop: 22.33ms; fastest: 0.08ms
              === WiFi ===
              Module reset reason: Turned on by main processor, Vcc 3.45, flash size 4194304, free heap 42700
              Signal strength -20dBm, channel 11
              pay close attention to the line 31:
              for the macro M98 P"0:/macros/test-bufferoverflow3.g" I got the following
              123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
              123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
              pay attention to line 9
                timschneider
                i can provide more examples where random data / new line characters are added, sometimes also binary data. But the binary data will not make it through as it is nothing the browser would expect.
                line 9, 10 and 25
                12345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234345678901234567890
                1234567890123456789012345678901234567890123456789012345678901234567895678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
                  timschneider
                  This post is deleted!
                    timschneider
                    @chrishamm
                    I found that adding an overflow check in void HttpResponder::HandleGCodeReply(const char *_ecv_array reply) noexcept will help to mitiage the problem. I don't know yet if it is solved in the long run.
                    From e4799bc4e3343878d035cb0074b2f37cfbf524be Mon Sep 17 00:00:00 2001
                    Date: Tue, 11 Feb 2025 12:03:55 +0100
                    Subject: [PATCH] - check for OutputBuffer overflow in
                     src/Networking/HttpResponder.cpp    | 14 ++++++++++++++
                     src/Networking/NetworkResponder.cpp |  2 +-
                     src/Networking/NetworkResponder.h   |  2 +-
                     3 files changed, 16 insertions(+), 2 deletions(-)
                    diff --git a/src/Networking/HttpResponder.cpp b/src/Networking/HttpResponder.cpp
                    index b9deb5e6..b0ed4e51 100644
                    --- a/src/Networking/HttpResponder.cpp
                    +++ b/src/Networking/HttpResponder.cpp
                    @@ -1536,6 +1536,20 @@ void HttpResponder::Diagnostics(MessageType mt) const noexcept
                     		buffer->cat(reply);
                    +		if (buffer->HadOverflow())
                    +			// We ran out of buffers at some point.
                    +			ReportOutputBufferExhaustion(__FILE__, __LINE__);
                    +			// Discard pending replies
                    +			while (!gcodeReply.IsEmpty())
                    +				OutputBuffer *buf = gcodeReply.Pop();
                    +				OutputBuffer::ReleaseAll(buf);
                     		clientsServed = 0;
                     		seq++;
                    diff --git a/src/Networking/NetworkResponder.cpp b/src/Networking/NetworkResponder.cpp
                    index a4c025d3..aeaee3c7 100644
                    --- a/src/Networking/NetworkResponder.cpp
                    +++ b/src/Networking/NetworkResponder.cpp
                    @@ -192,7 +192,7 @@ IPAddress NetworkResponder::GetRemoteIP() const noexcept
                     	return (skt == nullptr) ? IPAddress() : skt->GetRemoteIP();
                    -void NetworkResponder::ReportOutputBufferExhaustion(const char *_ecv_array sourceFile, int line) noexcept
                    +/*static*/ void NetworkResponder::ReportOutputBufferExhaustion(const char *_ecv_array sourceFile, int line) noexcept
                     	if (reprap.Debug(Module::Webserver))
                    diff --git a/src/Networking/NetworkResponder.h b/src/Networking/NetworkResponder.h
                    index 97633ac2..47324738 100644
                    --- a/src/Networking/NetworkResponder.h
                    +++ b/src/Networking/NetworkResponder.h
                    @@ -69,7 +69,7 @@ protected:
                     	virtual void ConnectionLost() noexcept;
                     	IPAddress GetRemoteIP() const noexcept;
                    -	void ReportOutputBufferExhaustion(const char *_ecv_array sourceFile, int line) noexcept;
                    +	static void ReportOutputBufferExhaustion(const char *_ecv_array sourceFile, int line) noexcept;
                     	static Platform& GetPlatform() noexcept { return reprap.GetPlatform(); }
                     	static Network& GetNetwork() noexcept { return reprap.GetNetwork(); }
                    2.39.2.windows.1
                    you can see in the following debug log for Module Webserver that this line is triggered sometimes
                    Ran out of output buffers at ../src/Networking/HttpResponder.cpp(1543)<\n>
                    HTTP req, command words { GET /rr_gcode HTTP/1.1 }, parameters { gcode=M98 P"0:/macros/test-bufferoverflow4.g" }<\n>
                    HTTP connection accepted<\n>
                    Sending reply, file = no<\n>
                    HTTP req, command words { GET /rr_reply HTTP/1.1 }, parameters { }<\n>
                    Sending G-Code reply to HTTP client 3 of 5 (length 5065)<\n>
                    Sending JSON reply, length 2915<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { flags=d99fn }<\n>
                    Sending G-Code reply to HTTP client 1 of 5 (length 844)<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { key=inputs flags=d99vn }<\n>
                    Ran out of output buffers at ../src/Networking/HttpResponder.cpp(1112)<\n>
                    Sending G-Code reply to HTTP client 1 of 5 (length 4432)<\n>
                    Sending G-Code reply to HTTP client 2 of 5 (length 4432)<\n>
                    Sending G-Code reply to HTTP client 3 of 5 (length 4432)<\n>
                    Sending G-Code reply to HTTP client 4 of 5 (length 4432)<\n>
                    Sending G-Code reply to HTTP client 5 of 5 (length 4432)<\n>
                    Sending JSON reply, length 3119<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { key= flags=fvnd99a0 }<\n>
                    Sending JSON reply, length 3123<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { key=inputs flags=vnd2a0 }<\n>
                    Sending JSON reply, length 65<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { key=inputs flags=vnd2a12 }<\n>
                    Sending JSON reply, length 312<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { key=volumes flags=vnd2a0 }<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { key=inputs flags=d99vna12 }<\n>
                    Sending JSON reply, length 66<\n>
                    Sending JSON reply, length 308<\n>
                    HTTP req, command words { GET /rr_model HTTP/1.1 }, parameters { key=volumes flags=d99vn }<\n>
                    Sending JSON reply, length 2914<\n>
                    Sending G-Code reply to HTTP client 1 of 5 (length 1688)<\n>
                    Sending JSON reply, length 2912<\n>
                    Sending JSON reply, length 2918<\n>
                    Sending G-Code reply to HTTP client 1 of 5 (length 1266)<\n>
                      @timschneider Did you have a look at our latest firmware improvements? The culprit was the fact that buffer->cat(reply); could use up all available remaining buffers which has been changed. Hence I'm no fan of your extra check there. Even if it "overflows" in the latest build, there will be enough spare output buffers available to send out the G-code reply with an HTTP header to waiting clients, which was not the case before.
                      timschneiderundefined 1 Reply Last reply Reply Quote 0
                        @chrishamm
                        I used the code with your adjustments to the output buffer and tested it (https://github.com/Duet3D/RepRapFirmware/commit/ddfeb63af628e5c0c47979c96d97ecacdddebcfa). As I said, it works as long as only one client is connected. As soon as several clients are connected, the firmware can crash again.
                        What happens more often, though, is that the output is corrupted, as shown above (stuffed with random data / truncated somewhere and so on).
                        I'm aware that the OutputBuffer and OutputStack code is quite complicated and complex and has many dependencies.
                        I suspect that the bug is related to the reference count, but I'm really not sure.
                        The reference count is increased in SendGCodeReply if there is more than one client connected and only reduced when all clients requested the reply or a client timed out.
                        void HttpResponder::SendGCodeReply() noexcept
                        		// Do we need to keep the G-Code reply for other clients?
                        		bool clearReply = false;
                        		MutexLocker Lock(gcodeReplyMutex);
                        		if (!gcodeReply.IsEmpty())
                        			clientsServed++;
                        			if (clientsServed < numSessions)
                        				// Yes - make sure the Network class doesn't discard its buffers yet
                        				// NB: This must happen here, because NetworkTransaction::Write() might already release OutputBuffers
                        				gcodeReply.IncreaseReferences(1);
                        But with an increased reference count, no buffer is actual freed up, only the reference count is reduced.
                        /*static */ OutputBuffer *OutputBuffer::Release(OutputBuffer *buf) noexcept
                        	TaskCriticalSectionLocker lock;
                        	OutputBuffer * const nextBuffer = buf->next;
                        	// If this one is reused by another piece of code, don't free it up
                        	if (buf->references > 1)
                        		buf->references--;
                        		buf->bytesRead = 0;
                        	else
                        		// Otherwise prepend it to the list of free output buffers again
                        		buf->next = freeOutputBuffers;
                        		freeOutputBuffers = buf;
                        		usedOutputBuffers--;
                        	return nextBuffer;
                        If a large request follows an request with OutputBuffer with hadOverflow == true the request can cause problems as seen above. You have more insight and know the code in depth - maybe you have already a solution in mind. The reason why I use the large output, even if it looks constructed, is just to reproduce a situation where a high load is on the board, like printing a job with object labling and serving an large object model query. I think it's okay to fail in fulfilling the request, but not to lose the Wi-Fi connection or to re-establish the DWC connection.
                        0 dc42 committed to Duet3D/RepRapFirmware
                        In touch mode report the probe reading to DWC
                        • T3P3Tonyundefined
                          T3P3Tony administrators @timschneider
                          @timschneider Separate to the discussion above about the buffers. Is there an straightforward way for us to reproduce the WIFI SPI timeout bug (that does not interact with these other issues preferably)?
                          Github issue form your report here:
                          www.duet3d.com
                            timschneider @T3P3Tony
                            @T3P3Tony
                            the printer was just sit in idle (not printing - state busy) with a blocking message box up like 6-12h - but i'll see if I can find a reproducable way on how to get it timed out.
                            The M122 bomb was one way to do it, but this will also interact with the buffers. Repeating a Gcode request very fast (even if it is a small one) was also able to trigger it (with more than one client connected).
                            I'll let you know.
                            • T3P3Tonyundefined
                              @timschneider thanks!
                              www.duet3d.com
                                @T3P3Tony @chrishamm @dc42
                                Hi Tony,
                                I think the bug is gone, to be honest.
                                I even deleted the overflow check as Chris suggested, and with the latest changes from Chris (OutputBuffer) and David (Stack of Main Task / M122) the bug is gone. I can construct a case where there is an SPI timeout – but that is far beyond normal use and a corner case. I tested it with this Git tag: https://github.com/Duet3D/RepRapFirmware/commit/4974c4cf3a4d1f1cd1fb1c28599e44ee2c412caa
                                I think the bug was related to the bug in OutputBuffer and filled the stack over time, causing the SPI timeout error from the RRF side – not WIFI. Now that the behaviour has been improved, I can no longer realistically reproduce the bug.
                                Although a M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 M122 can still sometimes trigger the timeout. If in doubt, do it twice and the printer is gone, but as I said this is unrealistic.
                                Increased main task stack size
