    original Bl touch always triggered
    Third-party add-ons
    • damaged_goodsundefined
      damaged_goods
      After the BL Touch pin ways damaged and replaced, the sensor flashes red and says it is triggered. Probe self test retracts and deploys pin but then just flashes red.
      Thanks in advance 🙂
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @damaged_goods
        @damaged_goods sounds to me like replacing the pin wasn't successful in fixing the BLTouch, so it's probably time to buy a replacement. There's not much you can do on the Duet side if the probe itself is broken!
        i3 clone with a bunch of mods
