    Weid stuff when homing.
    148
    • Snippyundefined
      Snippy
      Printter does not home, just mooves abit towards the endstops when told to home all.
      ; General
      G90 ; absolute coordinates
      M83 ; relative extruder moves
      M550 P"Duet 3" ; set hostname
      ; Smart Drivers
      M569 P0.0 S1 D3 V2000 ; driver 0.0 goes forwards (extruder 0)
      M569 P0.1 S1 D3 V2000 ; driver 0.1 goes forwards (Z axis)
      M569 P0.2 S1 D3 V2000 ; driver 0.2 goes forwards (Z axis)
      M569 P0.3 S1 D3 V2000 ; driver 0.3 goes backwards (X axis)
      M569 P0.4 S1 D3 V2000 ; driver 0.4 goes backwards (Y axis)
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.3 Y0.4 Z0.1:0.2 ; set axis mapping
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M906 X1040 Y1040 Z1040 ; set axis driver currents
      M92 X80 Y80 Z800 ; configure steps per mm
      M208 X0:400 Y0:400 Z0:220 ; set minimum and maximum axis limits
      M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z360 ; set maximum speeds (mm/min)
      M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K1 ; configure CoreXY kinematics
      M574 X1 P"io1.in" S0 ; configure X axis endstop
      M574 Y1 P"io2.in" S0 ; configure Y axis endstop
      M574 Z1 P"io3.in" S0 ; configure Z axis endstop
      (Normal open switches)
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.5.10 on Sat Feb 15 2025 02:19:33 GMT+0200 (Itä-Euroopan normaaliaika)
      ; increase Z
      G91 ; relative positioning
      G1 H2 Z5 F6000 ; move Z relative to current position to avoid dragging nozzle over the bed
      G90 ; absolute positioning
      ; home XY
      var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
      var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
      G1 H1 X{-var.xTravel} Y{-var.yTravel} F600 ; coarse home
      G1 H1 X{-var.xTravel} F600 ; coarse home in the -X direction
      G1 H1 Y{-var.yTravel} F600 ; coarse home in the -Y direction
      G1 X5 Y5 F6000 ; move back 5mm
      G1 H1 X{-var.xTravel} Y{-var.yTravel} F300 ; fine home
      G1 H1 X{-var.xTravel} F300 ; fine home in the -X direction
      G1 H1 Y{-var.yTravel} F300 ; fine home in the -Y direction
      ; home Z
      var zTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
      G1 H1 Z{-var.zTravel} F600 ; coarse home in the -Z direction
      G1 Z5 F6000 ; move back 5mm
      G1 H1 Z-10 F300 ; fine home in the -Z direction
      ; homex.g
      ; called to home the X axis
      ; increase Z
      G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
      ; home X
      var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
      G1 H1 X{-var.maxTravel} F600 ; coarse home in the -X direction
      G1 X5 F6000 ; move back 5mm
      G1 H1 X{-var.maxTravel} F300 ; fine home in the -X direction
      ; decrease Z again
      G1 H2 Z-5 F6000 ; move Z relative to current position
      ; homey.g
      ; called to home the Y axis
      ; increase Z
      ; home Y
      var maxTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
      G1 H1 Y{-var.maxTravel} F600 ; coarse home in the -Y direction
      G1 Y5 F6000 ; move back 5mm
      G1 H1 Y{-var.maxTravel} F300 ; fine home in the -Y direction
      ; decrease Z again
      ; homez.g
      ; called to home the Z axis
      ; home Z
      var maxTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
      G1 H1 Z{-var.maxTravel} F600 ; coarse home in the -Z direction
      G1 H1 Z{-var.maxTravel} F300 ; fine home in the -Z direction
        jay_s_uk @Snippy
        @Snippy if they are NO switches, add a ! to each pin name. E.g. M574 X1 P"!io1.in" S0 ; configure X axis endstop
        Snippyundefined 1 Reply Last reply Reply Quote 1
        • Snippyundefined
          Snippy @jay_s_uk
          @jay_s_uk
          No difference
            jay_s_uk @Snippy
            @Snippy how do you have them wired? can you post photos of the wiring?
            Snippyundefined 1 Reply Last reply Reply Quote 0
            • Snippyundefined
              Snippy @jay_s_uk
              @jay_s_uk Screenshot 2025-02-17 at 17-15-59 duet_3_mb6hc_wiring_diagram_v1.0_v1.01.png (PNG-kuva 3092 × 2478 kuvapistettä) — Pienennetty (51 % alkuperäisestä).png
              Io0.in
              GND
                jay_s_uk @Snippy
                @Snippy just noticed you've also configured them as S0 in M574. You should be using S1 for switches
                • Snippyundefined
                  Snippy @jay_s_uk
                  @jay_s_uk
                  Lol thanks, allso it was homing in the wrong direction
                  So S1 to S0
                  dc42undefined 1 Reply Last reply Reply Quote 1
                    dc42 administrators @Snippy
                    @Snippy all working now?
